Stolen Turbo Miata
Old Aug 31, 2016 | 02:52 PM
  #81
Total Cats: 1,870
I'm always serious about buying miatas. It sucks. I really need a different hobby.
Old Aug 31, 2016 | 02:53 PM
  #82
ScrapinMX5's Avatar
Where you located?
  #83
Total Cats: 1,870
Portland. But have access to a truck and flatbed.
Old Aug 31, 2016 | 03:09 PM
  #84
neogenesis2004's Avatar
Originally Posted by Girz0r
Gotcha
No oil is odd, but then again I bet they were having a 'good ole time' in your car. In for more photos.
Looks like the oil bandits have moved and struck again...
Leave a poscat 10 Leave a negcat
Old Aug 31, 2016 | 03:13 PM
  #85
Girz0r's Avatar
Total Cats: 323
Old Aug 31, 2016 | 03:18 PM
  #86
Have you put new oil in the car and see what happens when you run it?
Old Aug 31, 2016 | 03:43 PM
  #87
ScrapinMX5's Avatar
No I don't have extra oil atm. When I tried cranking it I was definitely getting oil pressure. I'm not really going to mess with it until insurance comes out and looks at it.
Old Aug 31, 2016 | 04:18 PM
  #88
leboeuf's Avatar
Total Cats: 57
You just made my day.
Old Aug 31, 2016 | 05:53 PM
  #89
he comes back after 3 years of silence to post this.
and it's a flawless victory is what it is
you sir get a couple cats. welcome back
Old Aug 31, 2016 | 06:43 PM
  #90
turbofan's Avatar
Total Cats: 1,093
That is fantastic.
OP, talk to Aidan or me. We're both in Portland. I might not have money but can help facilitate stuff. Get your stuff sorted and your buyback amount and we can all figure something out.
Ed@949Racing/Supermiata
www.949racing.com
Old Aug 31, 2016 | 06:59 PM
  #91
Slider's Avatar
Total Cats: 10
Originally Posted by 2slow
$129 Automatic Blutooth ODBII scanner with built-in GPS modul and free 3G data cservice. No monthly fees plus it works as a code reader, engine monitoring, MPG, trip logging and many other things. Would have been easy to find those ******** with one of these.
That's pretty sweet, most trackers used to have a yearly or monthly subscription, this one is good for 5 years. I wasn't aware of this. All the thing really needs for tracking is a power and ground, so you can make it work with any car just need to pin 2 wires.
So pin 4 would be ground and pin 16 would be 12V. Might need to ground 5 too but most likely not.
Old Aug 31, 2016 | 07:02 PM
  #92
ScrapinMX5's Avatar
This seems like a really solid tracking unit, but my biggest concern would be if a theif is under the dash trying to hot wire, they'll notice it in the OBDII port and most likely take it.
Old Aug 31, 2016 | 07:11 PM
  #93
Slider's Avatar
Total Cats: 10
Yeah it's super obvious and would probably get removed, but you can pop the obd2 out and buy an obd2 extension and hide it. Or could even splice into it to make a t harness and keep all the obd2 features. Just for tracking I would probably just hide it somewhere deep and run a power and ground to it and forget about the engine code monitoring and other stuff.
Can buy one of these https://www.amazon.com/Docooler-Obd-.../dp/B000SBCHCA to make it easier and just cut off one end so you don't have to pin any wires, and wire up whatever you need.
Old Aug 31, 2016 | 07:17 PM
  #94
ScrapinMX5's Avatar
They sell units such as the Spark Nano that are completely separate from obd and you could hide it anywhere you want. I think it's battery powered and runs for ~two weeks. And it will only track while the car is in motion.
Old Sep 1, 2016 | 05:06 PM
  #95
ScrapinMX5's Avatar
So I went to try and start it. Filled it up with gas and oil. Crank and no start for multiple trys. Check megasquirt and I guess the guy unpluged part of the harness. It fired up but wanted to die and idled rough. A big thing I notice was the lifters are REALLY loud. I drove it around my neiborhood and I can hear it over the engine and exhaust. What do you think could be damaged or what would I need to fix it? Motor toast? It seems like this guy drove it without oil for a while because I think I put 2 to 2.5 quarts of oil in.
Old Sep 1, 2016 | 05:21 PM
  #96
ryansmoneypit's Avatar
Total Cats: 458
That's not low on oil. That's normal. I can't count t the amount of times my car had less than 2 quarts on the stocker. Lifters are empty. Drive it. Or let it idle. They will pump back up.
Old Sep 1, 2016 | 05:25 PM
  #97
ScrapinMX5's Avatar
I also filled it up to the half mark and just driving it around my neiborhood it dropped to to a quater
Old Sep 1, 2016 | 05:34 PM
  #98
Girz0r's Avatar
Total Cats: 323
Nothing on the ground? Maybe oil coming out of turbo?
Old Sep 1, 2016 | 05:37 PM
  #99
ScrapinMX5's Avatar
I can see a little line in the gravel but it's hard to tell. And no, turbo and lines seem drip free.
Old Sep 1, 2016 | 05:41 PM
  #100
Girz0r's Avatar
Total Cats: 323
Er, I meant leaking into the exhaust.
I would be under the car already trying to look for wet spots lol
