Supertech vs Sealed Power VS855 Valve Springs
Old Nov 5, 2016 | 01:28 PM
d k's Avatar
d k
Why is that?
Originally Posted by NiklasFalk
softer springs would be better in the long run
Old Nov 5, 2016 | 02:03 PM
AndrewG's Avatar
Total Cats: -4
because stiffer springs "push" lifter stronger agains camshaft, so it wears quicker. not something I´m worried about as I do 3k Miles a year.
Old Nov 5, 2016 | 02:12 PM
d k's Avatar
d k
LOL
it doesnt exactly work like that
Old Nov 5, 2016 | 02:26 PM
AndrewG's Avatar
Total Cats: -4
your post have probably less value than my bad answer. Please explain
Old Nov 5, 2016 | 02:38 PM
d k's Avatar
d k
If the springs are too light, they will let the valves bounce and slam into the seats which causes a lot of wear and damage.
There is a great thread here somewhere about all the valvetrain issues..
Old Nov 5, 2016 | 03:52 PM
NiklasFalk's Avatar
Total Cats: 63
Originally Posted by d k
Why is that?
Loose less power in the valvtrain, I'm not boosted and run under regulations, so it's better to do it right.
The soft ST duals could most probably been enough in my case, but as mentioned, don't copy part of a design.
When you have (good enough in your judgement) control of your valve movement, extra springs is just waste.
Old Feb 9, 2017 | 04:02 PM
albumleaf's Avatar
Total Cats: 92
So.. getting back to this before I order my things for my relatively low-rpm (~7800max) BP6D w 264 cams build, should I just avoid the ST light doubles and just buy the VS855s?
Old Feb 9, 2017 | 04:21 PM
psyber_0ptix's Avatar
I completely forgot about this thread and had already ordered supertech heavy doubles for my spare head. *ponder ponder*
Old Feb 9, 2017 | 06:34 PM
stormin'norman's Avatar
Total Cats: 8
fwiw I went with the ST singles for 7,800 rpm on my Tomeis.
Old Feb 9, 2017 | 06:41 PM
Erat's Avatar
Total Cats: 830
I'm running the super double heavys. I am also using the OEM 99+ retainers for some reason that forgot about.
So many 8200rpm + moments. Less than 20psi levels though.
Old Feb 18, 2017 | 12:34 PM
albumleaf's Avatar
Total Cats: 92
Any modification needed to use the stock retainers with the supertech duals? Quite a few failures reported with the ST Ti retainers in other applications. Don't feel like checking whatever I install every 5-10k to see if it's holding up.
Old Feb 18, 2017 | 11:17 PM
Madjak's Avatar
ʎpunq qoq
Total Cats: 202
ST retainer has a wider center extrusion that tightly holds the inner spring. So snug the spring clips and holds on to it. The stock retainer is smaller and doesnt hold the inner spring and also the flat seat only covers 2/3rds of the spring. It's loose enough that the spring can move sideways around 2mm.
They would bolt up, but I'm not sure if things would get damaged with the inner spring not held in place fully. It might rub or chatter against the outer spring.
ST retainer
Oem BP05 retainer
Side by side
Old Feb 19, 2017 | 04:32 AM
NiklasFalk's Avatar
Total Cats: 63
Made custom steel retainers for my ST duals, but the cost was about 3x the Ti retainers.
Machine time is not cheap here.
Old Feb 19, 2017 | 05:28 AM
Madjak's Avatar
ʎpunq qoq
Total Cats: 202
How do the Ti retainers fail. Do they deflect upwards, crack or just wear?
They are a good amount lighter than steel so they are attractive for anyone chasing revs like myself.
Old Feb 19, 2017 | 06:23 AM
NiklasFalk's Avatar
Total Cats: 63
The failure I've seen was due to wear, all the way through (only inner spring holding the valve), possibly due to not tight enough so the spring rotates against the retainer wearing the soft Ti.
Old Feb 19, 2017 | 01:49 PM
Miater's Avatar
Total Cats: 27
I've been running the VS855 for several thousand miles without issue. 18psi, 7800rpm.
Over reved once to 8000+, wasn't logging but wasn't that bad of a miss. No issues from that so far. Factory valves, keepers, etc.
Old Feb 19, 2017 | 09:09 PM
Madjak's Avatar
ʎpunq qoq
Total Cats: 202
If that's the case, maybe a thin washer between the TI and retainer to stop any wear. I was actually thinking of shimming them up a bit tighter, maybe it's not a bad idea to stop them rotating.
Old Aug 21, 2017 | 11:50 AM
Schroedinger's Avatar
Total Cats: 188
Time for a necro-post. Lots of speculation above, but very little experience with the VS-855. Can I get an update from the people using the cheap Volvo springs? I'll buy the ST doubles if I have to, but I'd rather put that money towards a BE oil pump, tires, prostitutes or cocaine. Thanks
Old Aug 21, 2017 | 08:58 PM
StanTheMan's Avatar
I put some in about 4 weeks ago.
its a tired B6
port matched & polished general clean up of ports
Genie headers
272/264 220/215@0.05" cams 10/9 lift
CR10.5:1
MS2
max RPM 7500
running HLA's
spring pressure recommended by manufacturer 66lbs
initial reaction after running cams in again....smoother at low RPM. More vibrations at the top. But it seems to have smoothed out a little over a few weeks and a few high rpm runs.
will not get a chance to dyno it as the engine now needs replacing. But unlikely because of the springs.
that's as much as i can tell you.
mntech
Feb 27, 2016 03:42 AM
tenthe
11
Feb 21, 2016 03:48 PM
bbundy
Engine Performance
15
Feb 18, 2016 07:35 AM
