Need to know what kind of turbo I have!
Old Jun 29, 2017 | 03:57 AM
dopehaydo's Avatar
Total Cats: -8
Default Need to know what kind of turbo I have!
Need to know what kind of turbo I have!-img_2411.jpgNeed to know what kind of turbo I have!-img_2410.jpgNeed to know what kind of turbo I have!-img_2409.jpgNeed to know what kind of turbo I have!-img_2408.jpgI just recently got this Turbo in a trade, was wondering what exact model it is as I'm looking to run an internal waste gate. Any knowledge of either the turbo or what waste gate actuator I need would be great!
Old Jun 29, 2017 | 08:20 AM
You need to google the numbers on the tag on the CHRA.
Old Jun 29, 2017 | 09:34 AM
chicksdigmiatas's Avatar
This. And thanks for taking such a shitty picture that we cant read them and google it for you. I really wanted to bust out lmgtfy on you, but you ruined my day.
If I were to make an semi-educated guess, I would say it is probably a smaller t3 used in 80's or 90's turbo cars. Could be anywhere from a 45-60 trim.
Whatever the case, you need to build a turbo kit around this immediately. Even if it doesn't fit any readily available manifolds, you should buy the cheapest ebay one, and take it somewhere and pay someone $200 to weld on the correct flange. Have them make a downpipe for you while they're at it.
Piece together oil and water supply lines out of rubber fuel hose from autozone and pipe fittings from lowes. It should only cost about 20 bucks and you will really love the clean look of black rubber under your hood.
Then you need to get one of those universal ebay intercooler kits, and make as many cuts as you need to in the piping to make it fit. Buy extra couplers, you will need them. Shinier intercoolers reject more heat, so you need a polished one.
You need something to hold all that power, an ebay unsprung 6 puck will work great. Get one for a 1.6 and the 1.6 flywheel. It will make your car revvier.
Finally, engine management. Contact any of the Miata supercharger manufacturers and request power cards. One for fuel, and one for timing. Stacked power cards are the **** yo.
Whatever you do, don't buy a prefabricated kit based around the turbos the man has been using for years, and are proven to work. Don't listen to those uppity snobs with their standalones, telling you that a megasquirt is as cheap as bandaids and works better. MAF sensors are the only truly accurate way to fuel your car. Wideband o2 sensors are a crutch for those who are not wise enough to buy power cards, and have to know their air fuel ratio to tune their car.
Old Jun 29, 2017 | 09:39 AM
​​​​​​​I 100% agree with this post. It is the best answer, maybe even the greatest answer.
Old Jun 29, 2017 | 03:02 PM
dopehaydo's Avatar
Total Cats: -8
this?
Old Jun 29, 2017 | 03:31 PM
did you google the numbers?
do everything chicks said. can't go wrong
Old Jun 29, 2017 | 03:35 PM
Girz0r's Avatar
Total Cats: 323
Originally Posted by dopehaydo
this?
That.
Old Jun 29, 2017 | 08:40 PM
Your Turbo. Just click and look at the very top of the link.
Old Jun 29, 2017 | 09:36 PM
andyfloyd's Avatar
Total Cats: 97
Garrett tb0363 50 trim. So its probably a 50 trim t3 with a standard stage 1 turbine wheel. Good for a miata. Just bolt it on in place of the air box it youll be golden.
