Skunk2 BP intake manifold
Old Oct 26, 2017 | 10:31 PM
  #41
99mx5's Avatar
Total Cats: 526
Needs moar soundclip.
Old Oct 27, 2017 | 06:13 PM
  #42
Total Cats: 2,619
Default stock NB2 comparison
First of several test we plan to run. These runs about an hour apart.
Optimum spark table didn't change at all. VVT table changed quite a bit but resulted in about the same power. Square top obviously wanted less fuel past 7k.
Ran out of time on dyno today so we didn't try the spacers. We'll go back next week and do that. As expected, a bit more power on top with the S2, no significant gains in midrange.
What is key to note for folks who set their redline at 7000 (stock redline) is that there are no gains below that. We don't yet know if it will make more power below 7k with the spacers.
More to come.
.33 SNR
Leave a poscat 39 Leave a negcat
Old Oct 27, 2017 | 06:17 PM
  #43
6speed's Avatar
Total Cats: -6
Did you retune for the new manifold or just swap and run?
Old Oct 27, 2017 | 06:28 PM
Total Cats: 2,619
One guess
.33 SNR
Old Oct 27, 2017 | 06:32 PM
  #45
Ryan_G's Avatar
Total Cats: 217
So I'm not that versed in intake plenum theory but doesn't the physics change dramatically for boosted engines (kind of like exhaust scavenging)? I am just curious if this will show more gains on a boosted motor than an N/A where the engineering is more important instead of plenum volume and flow.
Old Oct 27, 2017 | 06:33 PM
  #46
ooja3k's Avatar
Total Cats: 22
Need to re-read the post
Old Oct 27, 2017 | 06:34 PM
  #47
doward's Avatar
Total Cats: 817
Uh...
...Optimum spark table didn't change at all. VVT table changed quite a bit but resulted in about the same power. Square top obviously wanted less fuel past 7k.
Old Oct 27, 2017 | 06:44 PM
  #48
NUMBERS! PLOTS!
You has a cat
Great job guys keep the info coming for science.
Old Oct 27, 2017 | 07:05 PM
  #49
phocup's Avatar
It seems from that dyno that folks with stock red line should stay away. You lose more between 5-6 than you gain anywhere else in the rev range < 7.
Oh, and thanks for doing this. for you from me as well.
Old Oct 27, 2017 | 07:12 PM
  #50
DeerHunter's Avatar
Total Cats: 2,329
Looking forward to results on boosted engine. My redline is currently set at 7.7K but I generally shift, even when driving in anger, at just past 7K.
Old Oct 27, 2017 | 07:13 PM
  #51
6speed's Avatar
Total Cats: -6
I don't think the blurb about the tune was in the post when I posted. But whatever.
Old Oct 27, 2017 | 07:27 PM
  #52
Lokiel's Avatar
All-round "Good Guy"
Total Cats: 266
CRAP - I've got a port-matched Flat-top and now have one of these because I was POSITIVE that the Skunk2 intake manifold would flow better due to the Flat-top's narrow channel to the plenum chamber behind the TB.
Wont spend much time beyond 7,200rpm so there's no point switching manifolds for me - at least I won't have to go through the manifold installation hassle again :P
Pos-cat added for Dyno results, looking forward to more.
Old Oct 27, 2017 | 07:47 PM
  #53
1993z32's Avatar
TheCarPassionChannel
Total Cats: 138
Awesome to see some real results. Now, I'm wondering if on a turbo car the gains will start once the engine is moving 150whp worth of air. Subbed
  #54
vteckiller2000's Avatar
Total Cats: 68
Funny, this is exactly my experience with my home brew one. Sound increase and all. Thanks for the data, looking forward to spacer dynos!
Old Oct 27, 2017 | 08:43 PM
  #55
phocup's Avatar
This is exactly what I'm waiting for as well. If results are good for boosted cars, 949 should start selling these.
Old Oct 27, 2017 | 09:02 PM
  #56
99mx5's Avatar
Total Cats: 526
Props! Thanks for sharing the info Emilio.
Old Oct 27, 2017 | 09:05 PM
  #57
Stealth97's Avatar
Yes Thanks Emilio.
Old Oct 27, 2017 | 09:16 PM
  #58
LukeG's Avatar
Total Cats: 166
Great info!
Old Oct 27, 2017 | 09:23 PM
  #59
nitrodann's Avatar
Total Cats: 66
I bet it makes more power everywhere on boost, when the outright airflow requirements are higher at all rpm above boost threshold.
Dann
Old Oct 28, 2017 | 12:12 AM
  #60
Mobius's Avatar
Total Cats: 365
∆ my thoughts as well.
