My Angry Tic-Tac
Old Jan 24, 2019 | 08:26 AM
s0n1cm0nk3y's Avatar
Default My Angry Tic-Tac
Hey Folks,
I've read a lot of build threads lately, and I've decided it's a great way to document and learn how to turbo this car. It's a great platform and so far its more fun than my previous VW's in the corners and autocross.
I definitely bought this car to track/autocross, which has been a lot better since I PCS'd to Las Vegas from North Dakota.
So far it's been a great starter car and despite being my second Miata, has taught me a lot more than my GTI's are proper handling and fluidity through a course.
I bought the car relatively stock with a set of Tien S-Tech springs on blown shocks. From there I've swapped out for a set of AGX's just to get it running right. The roll bar, wheels and tires were my doing.
Still a VW guy, but now the wife has this her daily. Decided what better way to have a dedicated fun car, then a nice daily for the wife and kiddo.
Cleaned up a 96 4.1 Torsen from Florida that had some surface rust. The carrier sadly had some damage, but I have a spare with new seals and comp mounts to put it in.
As I still needed a kid mover I thought why not buy a dedicated tow/kid mover.
Old Jan 24, 2019 | 08:33 AM
It is a bit late in the game but I've acquired a lot of parts thanks to my reading and lurking. Heres what I have so far:
  • Krakens T25 kit with 3" exhaust and inconel studs
  • Rebuilt SR20's T25G (From what I see its just a larger T25) - I figured it would be a great starter turbo and easily rebuildable.
  • MSLabs MS3 Basic + Singular Mount
  • LS2 Coils with the Flow Force Harness kit and a sadfab mounting system
So far besides my thoughts of swapping to AN lines I believe all I'm missing is my wideband, clutch, intercooler setup and injectors. I plan to go the FF960 route as I'm thinking of setting up E85 as well for extra safety on higher boost days. My goals with this current setup arent too high as I'd be happy to be around 230whp/210-220wtq. I have a spare VVT engine and a BE stage 2 pump ready for rebuilding on the side while I run this current setup.
For clarification, I have a 2002 Miata with the 5 speed and a 4.3 open diff. I know I'll likely need the 6 speed later on, but I really love the flow of the 5 speed so far and hoping to keep it for a while until I go bigger and faster.
Old Jan 24, 2019 | 01:42 PM
BMWidmer's Avatar
Total Cats: 12
Welcome! That's a great looking NB and looks like you're off to a good start!
Old Jan 24, 2019 | 04:23 PM
Thank you! Right now I'm working on deciding the wideband and I'm strongly considering the AEM 30-4900 to use as a one stop gauge for boost and AFR. My goal is to have the necessities such as boost and AFR readily available, but to have the rest such as oil-temp, coolant-temp, oil-pressure, and etc readily available via MSDroid/ShadowDash on my android head unit.
Once I have it all set up, I'll add the FF960s, then clutch, then start my way down the turbo kit route
Old Feb 7, 2019 | 09:25 PM
Started working on my harness to install my MS3. I really enjoy building stuff like this and even component level work. For those who are looking for wire to build their own harness, check out 25 pair 22 AWG phone wire. It's single stranded, but it works great for a cheap and easy source for wiring up a DB37.
Building the harness for my ECU has been a good bit of fun. Nothing like getting back to the basics of my work in the AF.
Old Feb 8, 2019 | 05:30 PM
Total Cats: 146
Originally Posted by s0n1cm0nk3y
Any plans to drop your seat?
Old Feb 8, 2019 | 08:12 PM
Lol definitely. I've been experimenting with different seats and I think I'm stuck with going aluminum. Lol sorry old photo.
Old Feb 9, 2019 | 11:07 PM
Total Cats: 3,591
Ouch. Yeah, you need Kirkeys. I rode in a stock seat recently and felt like I was sitting on the car instead of in it.
Old Feb 12, 2019 | 12:51 PM
Amen to that. I had a Kirkey before, but I was after the make it comfortable and low goal. I kick myself for trading it, but at least I got a spare engine out of the ordeal.
Old Feb 14, 2019 | 05:35 PM
Pressing out the old bushings!
In with the new hotness. A Press make this job cake and took a total of 10 minutes.
Old Feb 15, 2019 | 08:01 PM
Harness before
Harness after
So I finished up the harness, and this is the pretty heat shrinking before I threw on the split loom. All wires are checked and it looks good, but I'm starting to wonder if I bit the bullet on my single strand wire I had available. No worries, I'll hunt for a 90 degree adapter or something of the sorts to aid in the fitment, and as always this isn't a deal breaker. I have the AEM 30-4900 in the car, wired to a tempory fuse-in to make sure everything lights up right. After install, I'll wire it directly to the available ports on the DB37. As the 30-4900 is only wideband, I'll wait till the holiday for when I actually install the ECU. So far its just testing fitting the wires as this car runs secondary daily duty to the Suburban.
Old Feb 18, 2019 | 01:49 PM
Default Class change
Finally got to enjoy the Miata at an Auto-x event again. Possibly the last run on this brake setup, but a good bit of fun. Oddly enough I seem lower in these photos than my last one.
I'm waiting to see how things go once I install my ECU. I was watching the competition in my next class and I'm thinking I might need to look at some stickier tires.
Old Mar 1, 2019 | 08:17 AM
Decided to build a second harness with stranded cable to make sure I don't have issues in the tough bends. Turns out my AEM Wideband (30-4900) had a damaged heater circuit, so I should be able to pick up the repaired gauge today. It is also time for a new set of brakes, so I picked up a set of HPS pads to get my toes wet with more performance oriented pads, and a set of fresh rotors. Shooting to get the brakes and differential in before the next autox event.
Old Mar 2, 2019 | 08:10 AM
SamM_UK's Avatar
Total Cats: 11
What are your wheel/tyre specs?
Old Mar 2, 2019 | 03:12 PM
Konig wideopens 15x8 with Nitto NT05's. There are much better tires in the world.
Old Mar 2, 2019 | 04:18 PM
SamM_UK's Avatar
Total Cats: 11
they look good, which offset and tyre size are you running?
Old Mar 2, 2019 | 04:20 PM
25 on the offset and 205/50/15. I've contemplated wider and closer but I think I'll try a better tire first. I'll wear these out this season and get some more seat time, then move to something like RE71's to be a bit more competitive in Autox.
Old Mar 3, 2019 | 08:23 AM
Note to self and others reading this, don't buy bullet connectors made of chinesium.....
Old Sep 9, 2019 | 06:07 PM
Default Sadness
Frame damage.
Sadly right after getting a pretty comfortable base tune, this happened. Looks like I'm back to square one on the next car, but luckily I was able to get my parts off it.
Old Sep 9, 2019 | 08:50 PM
90LowNSlo's Avatar
Total Cats: 28
What happened?
