Dorman (short) vs OEM (tall) Shifter Turret Lower Boot w/ Pics!
Old Aug 31, 2019 | 11:31 AM
Enginerd's Avatar
Total Cats: 77
Default Dorman (short) vs OEM (tall) Shifter Turret Lower Boot w/ Pics!
Wow. I had a nice two write up explaining this, then the forum deleted all of it when I went to upload the picture. So....here’s a picture of the OEM lower boot vs the lower boot from the Dorman kit on Amazon.
This is on my 1994.
The Dorman is not a tight seal and it’s super short.
Old Aug 31, 2019 | 11:43 AM
Enginerd's Avatar
Total Cats: 77
Old Aug 31, 2019 | 06:10 PM
Total Cats: 861
Thanks.
Old Sep 3, 2019 | 10:47 AM
huesmann's Avatar
Total Cats: -15
Huh? Where is the Dorman not tight, and how is it short?
Old Sep 3, 2019 | 10:33 PM
hks_kansei's Avatar
Total Cats: 44
The two are side by side in the first picture.
It's pretty clear how much shorter the Dorman one is.
as for where it's not tight, by the looks of it the Dorman one tries to seal against the straight shaft section instead of the bulge up top that the OEM one seals against (which is exactly why the bulge is there)
Old Sep 4, 2019 | 07:45 AM
Enginerd's Avatar
Total Cats: 77
Yep ^^^
There is a visible separation between the shaft and the seal if you look down over it.
Maybe the Dorman fits the NB shifter designs better? I have never owned an NB, so I don’t know if it’s the same shifter or not. The parts listing said it fits 90-05.
Old Sep 11, 2019 | 09:09 AM
huesmann's Avatar
Total Cats: -15
Ah I see. OP failed to identify which boot was which in his photos. Apologies for not reading far enough into your post to figure it out on my own.
Old Sep 11, 2019 | 09:13 AM
whiprsnapr's Avatar
Zip tie for the win. . .
Old Sep 11, 2019 | 07:03 PM
2manyhobyz's Avatar
Total Cats: 42
On the NB's it's a non issue. I've run one with the rubber trimmed
And there is no splash creating a leak.
Old Sep 12, 2019 | 04:21 PM
Enginerd's Avatar
Total Cats: 77
!!!THE SHORT ONE IS THE DORMAN!!!
is that better?
Old Sep 13, 2019 | 08:44 AM
masterjr33's Avatar
Total Cats: 29
I am using the dorman piece with a zip tie around it.
and a ebay manzo short shifter .
and a new OEM lower rubber cover plate.
Works great. super shifts. short and solid.
Old Sep 13, 2019 | 10:24 AM
Enginerd's Avatar
Total Cats: 77
Good suggestion to use a zip tie. Maybe too soon to tell, but did you experience any issues with the zip tie distorting the rubber when you tightened it or the edges eating into the rubber over time? Thanks for the insight.
Old Sep 26, 2019 | 05:36 PM
brainzata's Avatar
Total Cats: 17
I would use heat shrink or gates heat shrink hose clamps. Seal best, and look best. IMO
SteyrTMP
Oct 5, 2012 01:08 PM
psreynol
Apr 11, 2012 10:24 PM
Meola
12
Nov 18, 2008 12:32 PM
mazda/nissan
14
Apr 18, 2008 12:53 PM
