Popcorn: Miata/Datsun PL521 Hybrid Build
Old Apr 4, 2023 | 05:13 PM
Satisaii's Avatar
Total Cats: 125
It rolls. A little too low, but then the shocks are a couple of inches too short. Will fix that here in a bit. Currently on the Tecna protos with travel limiting chips instead of springs. We are going to have a custom set of Tecnas made for it.
It was a pain to get off the lift due to the extreme ride height. The center braces are going to have to be replaced.
After being in the sun for a few minutes, it got rained on.
Old Apr 6, 2023 | 11:58 AM
Satisaii's Avatar
Total Cats: 125
This crossmember is stupid low. It will have to go.
We removed a bunch of Arizona desert from the cab before bringing it back in.
Getting close to fitting the cab (ignore the piece of wood.)
This engine bay is smaller than I remember. I hope I don't have to remove the balance shafts and dry sump the EcoBoost in order to get it to fit in there.
I should get the cab on this week, the bed on next week, and then I am going to give it to a friend to do the roll cage and chassis work. I am not pro enough (and don't have the right tools) for that job. I will strip the 'Stang while he has it.
Old Apr 6, 2023 | 05:59 PM
Satisaii's Avatar
Total Cats: 125
I couldn't wait for the weekend.
Is it too low?
Maybe I will get the bed on this weekend.
Old Apr 7, 2023 | 09:24 AM
doward's Avatar
Total Cats: 821
This is awesome John!
Is that cowl vent and second/forward firewall on the chopping block already?
Old Apr 7, 2023 | 02:02 PM
Satisaii's Avatar
Total Cats: 125
I was thinking about putting the A/C from a Miata in it. That would pretty much eliminate the cowl vent.
After getting the Mustang, I thought it would be cool to incorporate as much of the OEM Ford electronics as I can. It would probably be too hard to get the Miata A/C to work with the Ford touchscreen controls, so I may try to use the Ford climate controls. Which would also kill the vent.
Not sure what the firewall is going to be like. I have the 95 Miata floor sitting out back to swap in, but I think I am going to try and use the Ford steering. I also see a way to use the Ford EPS in it. I think it will mean cutting out part of the subframe to push the engine forward. Still lots of questions to be answered now that the first steps have been completed.
Old Apr 13, 2023 | 05:19 PM
Satisaii's Avatar
Total Cats: 125
Wheel test fit with some 17" wheels we have here. I am leaning towards 17" over 15"
This is close to the ride height I am shooting for and it should have 3" of bump travel from here.
Old Apr 13, 2023 | 05:26 PM
turbofan's Avatar
Total Cats: 1,095
I still like the 15's best
Ed@949Racing/Supermiata
www.949racing.com
Old Apr 13, 2023 | 05:50 PM
Total Cats: 2,621
Guess it will depend on how much room there is. I'd like to see 17x10 with 255/40 in back but skeptical there will be enough room. For sure 15x11 with 275/35 Nankangs will have enough bump travel. That would look hawt with 15x10 and 245's up front.
.33 SNR
Old Apr 14, 2023 | 01:43 PM
HarryB's Avatar
Total Cats: 155
Needs 15" with high sidewall; the 17s look too modern to my eyes
Old Apr 17, 2023 | 11:07 AM
Zaphod's Avatar
Total Cats: 106
15s all the way
Old May 13, 2023 | 08:16 PM
Satisaii's Avatar
Total Cats: 125
Probably going with the 17's for gearing and MPH/RPM reasons. 19's would be even better, but good luck with 4x100 19" wheel choices.
Parted out the Mustang a couple of weekends ago. Kicked it out of the shop and hopefully have it sold.
This week is about getting the engine sitting in the truck. Not really in, but at least close enough for the time being.
I set it in there and then made some cuts to the subframe and crossmember.
Placed it again, made a couple of more cuts, and figured it is close enough.
It needs to move about an inch to the driver's side, but it is hard up against the steering rack mount. I will address this later since I am planning on using the Ford EPS anyways.
Tomorrow I will drop the cab back on. I think there may be quite a bit of cutting going on.
Old May 14, 2023 | 05:13 PM
Satisaii's Avatar
Total Cats: 125
It fits! (extra cats to you if you know the anime I am thinking about when saying this line) I was worried that the high pressure fuel pump was not going to clear the cowl (it is the highest non-negotiable point on the engine.) But it clears with more than an inch to spare.
I see lots of problems in my future. But I will worry about those tomorrow. Next up: motor / transmission mounts, diff / driveshaft, and fitting the EPS.
Old Jun 28, 2023 | 04:20 PM
Satisaii's Avatar
Total Cats: 125
It has been a while. Many printed revisions of the motor mounts to get it to this point. Ditched the idea of using the Ford EPS. There was not enough room between the frame and the engine to fit it in. Going with the manual Miata rack and will consider doing an EPS conversion kit in the cab (if there is room.)
I like to start my CAD with manila folder material. It is easy to cut and manipulate to get the contours correct. A
Contour Gauge Tool Contour Gauge Tool
is helpful to get the profiles close to start. I then transfer the designs to balsa wood. I like balsa over cardboard since it is easy to cut and you can sand it down for a more precise fit. You can get it McMaster Carr.
Next I will scan the parts to get them into Solidworks before sending them off to be made out of steel. I will also epoxy the parts together to help get it all just right in my model. The driver's side is a pain. It will probably take 3 supports to get it strong enough while avoiding the steering stuff.
Old Apr 20, 2024 | 03:16 PM
Satisaii's Avatar
Total Cats: 125
Hey. How's it going? Long time, no see.
So I took some time off of this, ostensibly to save up some money such that I could pay a guy to do the things I am not so good at. Like all the welding that needs to be done. Stuck the truck on the 4 post lift and then proceeded to store a bunch of stuff under the truck. Saved up a lot of money, and then gave it to the government. Decided I was going to have to do a lot of the welding myself. Borrowed a welder, practiced a small bit, ran out of gas. Bought a new big tank of gas, practiced a small bit, discovered I bought the wrong gas. Got the small tank refilled, practiced a small bit, ran out of wire. Finally got everything lined up and got enough practice to feel reasonably confident in my work. Then I made the motor mounts. My welds look like ***. I may have to go back, grind them out, and redo them. Once I get some more practice. You tube videos make it look easy.
Here are some pictures of the motor mounts. I also cut out the inner fenders so that I can redo them to tie in the shock towers. I also made some room up front for the Ford radiator.
Next week I will start on the inner fenders. I will be paying a friend to build the cage. That requires more skills than I will ever have.
Old Apr 20, 2024 | 05:37 PM
Total Cats: 2,621
.33 SNR
Old Apr 23, 2024 | 07:12 PM
turbofan's Avatar
Total Cats: 1,095
This sparks joy.
www.949racing.com
Old Apr 23, 2024 | 09:55 PM
Total Cats: 2,621
Originally Posted by turbofan
This sparks joy.
.33 SNR
Old Apr 24, 2024 | 03:55 PM
Fireindc's Avatar
Total Cats: 915
Love seeing the progress here. That front end design looks pretty awesome with the notched frame for the lower A arm. And that drivetrain fits like a glove.
Old Apr 24, 2024 | 03:56 PM
turbofan's Avatar
Total Cats: 1,095
A very, very tight glove.
www.949racing.com
Old May 29, 2024 | 01:48 PM
Satisaii's Avatar
Total Cats: 125
More progress. My welding is still bad, but I am seeing improvements. I will be going back and welding everything up after I get the engine bay packaging done.
Upper radiator mounts done. Welded a bolt inside the head light bucket to create the mounting stud. I really wish I had not cut that much out of the buckets. When I first went to fit the radiator, I set it on top of the buckets, marked for my cuts, and then went to town. I then realized that the radiator is way wider at the bottom than it is at the top. I had to replace most of what I cut out, and those buckets are like tissue paper. I just keep blowing through them. There is lots of hole filling to be done.
Lower radiator mounts. I am not planning on doing any body work (beyond fender flares to fit the tires.)
Inner fender template. Worked on both sides with little modifications.
A couple of shots under the inner fenders. I will be welding these in fully.
Some more pictures from above.
An interior shot. I will be redoing all of this when I create the toe box. And you can see some of the problems I will have with the steering.
I bought a cheap intercooler on Temu. I am not impressed with the mounting kit.
That is about it for now. The sway bar is clamped in and waiting for install. I have a bunch of parts coming in next week to start putting in charge pipes, intercooler, transmission cooler, move the oil filter, and an expansion tank. Steering is going to be interesting. I might have to use 2 offset steering adapters (https://wizardsteerclear.com/) to get it to work. Or steer by wire, but I have not seen anything that I would trust.
