Stuck master cylinder
I wanted to change my brake master cylinder yesterday. After removing the 3 brake lines and 2 nuts, the damn thing wouldn't come out. It's not stuck to the booster. I can wiggle it. What can be holding it?
I remember (I think) doing an NA and it just pulled out. Now removing the pedal pin is necessary for just the master and not the booster? I can't see where the pushrod would attach to the master. It appears to just fit in there. I'm stumped and I put the car back together. I want to understand what I'm doing before I try again. My stupid Haynes manual says just pull it out.
It's always pissed me off when an op doesn't come back and post if they solved a problem. So I'm back. The pushrod was corroded into the mc due to the mc leaking at the rear. I just loosened the nuts, till they were on by a few threads and hit the area with blaster. After about 5 minutes I just stomped on the brake pedal and it popped loose. It was just a matter of changing it normally after that.
owenwilliams
34
Apr 20, 2020 05:08 PM
Lincoln Logs
Good-Win-Racing - Miata Accessories
Jul 8, 2015 03:35 PM
gshemaka
11
Mar 8, 2014 12:00 AM
