mkturbo kit review
Old Aug 22, 2024 | 09:28 AM
bahurd's Avatar
Total Cats: 316
The pic you showed of the cracked downpipe also showed the replacement cast manifold. I can assure you the location of the v-band flange is not in exactly the same spot as the MK manifold so you can’t blame Lars “skills” or “welds” on the cracks in the downpipe.
Even a minimal change in mating location or angle will put stress into the downpipe causing it to crack wherever the stress (and heat) is greatest.
So now you’ll need to have a downpipe “fabricated” to match the cast manifold and everything will be good again.
Old Aug 22, 2024 | 10:53 AM
ragtag93's Avatar
Total Cats: -2
Appreciate the copper anti seize tip.
Engine mounts are stock and agree that engine moves more than it should. I've only cracked manifolds and downpipes on the track, which makes me think the Gs don't help.
The tune started out as a 1.6 MS basemap with some additional street runs using tunerstudio tune analyze feature. Advance is set to 4 degrees (from basemap) with 100% ethanol content. Agree that it could use a better tune, but AFR seemed stable and didn't see any issues on the logs. I'm not sure what a tuner could do different to help with EGTs. I always assumed running on the track for 1+h is just a different level of heat than any street driving.
Agree that mani location is probably shifted slightly and the plan is as you said, to refab the downpipe to fit it better. If it's due to movement though, I'm still thinking it will crack. I'll post when I have an update.
If you read my 1st post, the whole reason for switching to cast mani is b/c original welded MK miata one kept cracking at the welds. I've told Lars that the cast one seems to hold up better. Every time I email Lars he does not seem to have the manifold or the downpipe in stock - that's the frustration.
Either way, there r plenty of posts about cracked downpipes, even w/ the FM kit before they went with a cast piece:
I just cracked my FM Downpipe, Suggestions please - MX-5 Miata Forum
Old Aug 22, 2024 | 03:38 PM
Total Cats: 3,591
I stopped reading at engine mounts are stock. Don't throw rocks at a vendor for your mistakes. Not cool.
Old Aug 22, 2024 | 06:55 PM
Newaza's Avatar
Total Cats: 129
If I read your post #18 correct you said you added a flex joint and a custom hard bracket to solid brace the downpipe to the transmission, with the brace being between the turbo and flex joint? Try placing the flex joint between any solid exhaust bracing and turbo to see if that helps. Maybe after the first downward bend after the turbo if there is room. Combine that with stiffer motor mounts may be the ticket.
Also what is your timing like when on e85 at 10 psi? excessively retarded timing and/or too lean mixtures can put a lot of additional heat in exhaust.
Old Aug 23, 2024 | 10:11 AM
ragtag93's Avatar
Total Cats: -2
Thx for the feedback. Yes, will try adding a bracket just after the flex joint. There is only one exhaust hanger roughly where the trans ends. It allows it to move a lot, so extra bracing can't hurt. Adding my timing and flex sensor pic:
Old Aug 23, 2024 | 08:24 PM
Newaza's Avatar
Total Cats: 129
In my opinion any bracing between the turbo outlet and flex joint maybe should be removed. That will help alleviate stress in the hottest parts of the downpipe as it expands from heat. That will also help with the stress from engine movement and vibrations as well I would think.
Might want to also look to what some others on here are successfully running in so far as timing when on e85 with a similar setup to you and tracking there car as well.
I would post one of my spark maps but mine is a very different animal from yours and used for a very different purpose.
Old May 29, 2026 | 10:59 AM
ragtag93's Avatar
Total Cats: -2
Hiya folks. 2 yr tracking/drifting update and mods to this mkturbo setup to not fail at the track:
Cast Ebay mani:
Cast Iron Turbo Manifold Fit1990-1993 Mazda Miata MX5 NA Eunos Roadster 1.6L B6 | eBay
Serviceable 90 elbow from turbo to DP (in case it cracks at the track, so you can swap out on the go if you have an extra; have exhaust shop cut off the cracked DP section, add the 90 w/ v-band connections; make sure exhaust is flush and not stressed when tightened down):
2.5“ V Band Downpipe Exhaust Dump pipe
Last part (not shown but very important), secure the back half of the exhaust/muffler from side to side movement w/ Gs (I used steel straps; rubber exhaust hangers are too soft).
2 yrs of trackdays and no issues or cracks. My fugly, yet functional setup below:
Still rocking those 30+ yr old engine mounts. To be fair, you should replace yours, I don't care since I'm going 1.8. If anybody wants some old 1.6 manis/paperweights, ping me.
charge Stainless Steel Project | eBay
Old May 30, 2026 | 02:40 PM
Total Cats: 3,591
Yeah, if the engine is flopping around and the exhaust's weight is being supported by the turbo and manifold, things will definitely break.
Minty
May 17, 2017 05:29 AM
davelkim
Prefabbed Turbo Kits
17
Feb 19, 2012 11:09 PM
jc_rotor
168
Oct 11, 2008 09:05 PM
UrbanSoot
Jan 10, 2008 08:40 PM
hustler
33
Apr 9, 2007 04:00 PM
