AMP MS3 Pro Mini standalone install for 01-05 VVT
Old Jan 24, 2026 | 02:03 PM
58nate's Avatar
Default AMP MS3 Pro Mini standalone install for 01-05 VVT
I thought it would be a good idea to make a thread on the MS3 Pro Mini that I installed on a 1994 miata with a 01-05 VVT engine before I forget everything that I have done. I'll probably be constantly updating things to this thread.
Firing order 1-3-4-2
INJ & Coils A-B-C-D
There are 4 dip switches inside the MS3 for cam/crank and tach output. Switches 2,4,5 need to be in the ON position.
AMP MS3 Pro Mini pin #'s
12v switched power #1 (Connected at original ECU connector to power relay) (Used fused dedicated 12v line from battery / relay switched)
IAC #3
Fuel Pump #4 (Connected at original ECU connector)
Injector A #5
Injector B #6
Injector C #7
Injector D #8
Coil A #17 (Only A&B used for stock 01-05 coils)
Coil B #18
Coil C #19 (A/B/C/D for sequential - R8 coils)
Coil D #20
TPS #2 (5v reference)
TPS #28 (Signal)
VVT #9
Fan #10 (Connected at original ECU connector)
Tach out #12 (Connected at original ECU connector)
Ground to frame and block #22-#23
Coolant temp #26
IAT #27
Flex fuel sensor #29
CKP Crank #30
CMP Cam #32
Wideband AEM 4110 analog pin #13
or
Wideband AEM X300 canbus pin #24 & #25 (Most accurate)
01-05 connectors
TPS connector
Green/Black ECU signal #28
LTgreen/Red 5v ref #2
Black/Red Signal GND #21
IAC 2pin Connector
PWM ECU #3
12v power source
VVT 2 pin connector
PWM ECU #9
12v power source
IAT
ECU #27
Signal GND #21
Coolant temp (1994 miata 2 pin)
ECU #26
Signal GND #21
Flex Fuel 3pin Connector
Digital 1 #29
GND
12v power source
Stock 01-05 coils
Coil 1/4
Brown/White #17
Black/White 12v
Black GND
Coil 2/3
Black/Yellow #18
Black/White 12v
Black GND
Injector 2pin Connector
INJ A
ECU #5
12V power source
INJ B
ECU #6
12V power source
INJ C
ECU #7
12V power source
INJ 8
ECU #5
12V power source
CKP
White/Red = 12v power source
Violet/White = ECU #30
Black/Blue = GND
CMP
Grey/Blue = ECU #32
Black/Blue = GND
OEM ECU connector pin out and VVT engine connector pinouts are on TurboKitty.com for more info
I'll be adding some pics, more info, and base tunes when I get a little more time. Stay tuned - get it
Old Jan 25, 2026 | 11:13 PM
SiRAutoX's Avatar
Great thread @58nate . I followed your build and I appreciate that you were able to use the parts you had on hand and make them work together instead of buying new parts.
I am considering the ms3 pro mini myself (or ms3 gold lite) and this info will be super helpful!
These ecus are great bang for the buck compared to the pnps, but they dont seem very popular.
Old Jan 27, 2026 | 09:50 AM
58nate's Avatar
They are a great deal if you are willing to put in the work to wire them in. I just got the MS3 Gold Lite for my mustang and have been comparing them. I talked to the main guy over at EFI Source and we talked quite awhile, if you ever need support they are great people. If I ever built a 4 cylinder again I would probably stick with the AMP MS3 Pro mini. It has the built in pullups, built in baro correction, built in Map and Tunerstudio License. It just makes a compact clean install. The Gold lite is nice because it is really the only cheap option for fully sequential V8 stuff and has USB C connection, you just have to add in the things that are missing and figure out the pullups.
Edit: also the AMP MS3 Pro Mini has 8gb for datalog and the Gold Lite has 2gb.
The MS3 Gold Lite runs the old firmware. That's why I ended up calling them, they told me to just use the MS3 firmware. There are 7 different variants in the download and I didn't want to brick the damn thing
tacocabeza
ECUs and Tuning
Jul 22, 2024 03:58 PM
pascal.1605
Dec 22, 2023 09:03 AM
pascal.1605
Nov 22, 2023 05:18 PM
1993ka24det
ECUs and Tuning
Jun 24, 2023 10:17 PM
ianferrell
6
Nov 8, 2010 10:11 PM
