not sure
Old Apr 28, 2009 | 01:29 AM
1990miata1.6's Avatar
Default not sure
hi i have been looking and reading about the AEM fuel ignition controller and it fits every thing i need to run my car and get rid of this shitty link piggy back. the only problem i am having is that i have 9.0:1 comp and the stock ecu is 9.5:1 comp and the AEM FIC only lets you retard ignition. Will this kill power from me having low comp and not being able to add timing when out of boost or will it be fine?????????
Old Apr 29, 2009 | 08:21 PM
Joe Perez's Avatar
Boost Pope
Total Cats: 7,548
You are aware that you can statically advance your timing by rotating the CAS, right? Consider that if you set your static idle timing to 15° BTDC, and then used the AEM to retard it by 5°, then you're back to the stock timing map. Any place you want to dial in some advance, just eliminate the AEM's retard.
That having been said, built a Megasquirt. Less $$$, more .
Old Apr 29, 2009 | 10:27 PM
joe remember last time lol i told you i have a 99 miata so im **** out of luck on a ms
