Using TunerStudioMS for Tuning Megasquirt - Guide
Old Jan 25, 2010 | 04:17 PM
  #41
save this somewhere and tell it use it: http://boostedmiata.com/MS/msq/firmware/msns-extra.ini
(right click, save link as, save as txt)
Old Jan 26, 2010 | 02:23 PM
  #42
thesnowboarder's Avatar
Anyone using TS on a mac?
Old Jan 26, 2010 | 02:45 PM
  #43
Andreas's Avatar
I don't know if it's of any help but I've seen that someone is using Tunerstudio on Mac OS X 10.6.x on the msextra forum.
Old Jan 26, 2010 | 02:52 PM
Tremiata's Avatar
Post AEM and AFR reading
Win7 Home Premium 64bit:
For my AFR Target tables to show up as AFR instead of volts using AEM I had to edit the mainController file in c:\users\Name\My Documents\TunerStudioProjects\Miata\projectCfg\mainController
Where Name is your username and Miata is whatever you called your project.
Changed these lines per instructions from the sticky thread
Look for the following lines in that "page = 7" section:
#elif AEM_LINEAR
afrBins1 = array, U08, 0, [8x8], "Volts", 0.0196, 0, 0.0, 5.0, 2
You want to make the following changes, which I've highlighted in red:
#elif AEM_LINEAR
afrBins1 = array, U08, 0, [8x8], "AFR", 0.038666, 255.0, 10.0, 20.0, 1
Also had to either adjust or disable User Account Control.
Old Jan 26, 2010 | 05:04 PM
  #45
Turbo_4's Avatar
I EAT CUM
What do you mean by this?
Old Jan 26, 2010 | 09:58 PM
  #46
Turbo_4's Avatar
I EAT CUM
Well for some reason mine still says there are unit mismatches every time I load up my msq.
Old Jan 26, 2010 | 10:09 PM
  #47
did you activate the hr_10g firmware in configurator like i keep sayin?
Old Jan 27, 2010 | 12:56 AM
  #48
Total Cats: 1,415
I told him he needed to check that too! I think. I had the same error, but it only happened the first time I opened the msq after changing to AFR's.
Old Jan 27, 2010 | 03:31 PM
  #49
Turbo_4's Avatar
I EAT CUM
There's no configurator option under TS...The only way to get to it is through MS...am I supposed to activate it through ms?
Old Jan 27, 2010 | 03:32 PM
  #50
Mach929's Avatar
it's under the project
Old Jan 27, 2010 | 03:48 PM
  #51
Sorry, then you gotta go to File > Project > Project Properties
Then under the configuration tab, change the ECU definition to "MS/Extra format hr_10 *******" If you dont have that, select other, then browse to the file you should have downloaded:
this one: http://boostedmiata.com/MS/msq/firmw...extra.ini.hr10
Old Jan 27, 2010 | 03:49 PM
  #52
Turbo_4's Avatar
I EAT CUM
Okay so I just started a new project and use that hr10 file as my firmare file. I activated it through MS and changed it to the AFR instead of volts. Now when I open my project it does not tell me about the differences. But, if I go in and just load my msq rather than loading the project first it says there is an error.
Old Jan 27, 2010 | 03:51 PM
  #53
popopopop's Avatar
Total Cats: -1
You can put the MSQ in your project folder and it'll load that one.
Old Jan 27, 2010 | 03:53 PM
  #54
Turbo_4's Avatar
I EAT CUM
Yeah....If I just click the msq on my desktop is loads under TEMP. So instead I just open up TS, open my specific project, and there you go...no error. Thanks!
Old Jan 27, 2010 | 04:09 PM
  #55
Yeah, I'm still getting used to the project nuances myself, I still use MT for loading other's files because it's easier to swap between projects with errors and crap.
Old Jan 27, 2010 | 04:11 PM
  #56
Turbo_4's Avatar
I EAT CUM
Where exactly are you sticking the msq in your project folder? Just generally in the specific folder or one of the sub-folders? When I open the project if no longer says the name of the msq at the bottom right portion of the screen like it would otherwise.
Old Jan 27, 2010 | 04:26 PM
  #57
there should be a default or offlinetune .msq file that gets created for each project, so long as you open TS it'll preload the last tune you saved so you shouldnt be clicking on msq files, just open the software and itll already be loaded.
Old Jan 27, 2010 | 04:32 PM
  #58
Turbo_4's Avatar
I EAT CUM
Ahhhh okay, I'm still just getting used to this so thanks for being understanding. I'm used to the simplicity of a dtec.
Old Jan 27, 2010 | 04:57 PM
  #59
CRAIGO's Avatar
If you make any offline changes to the MSQ file on the controller, TS can be made to perform a "difference report" upon connecting. Previous versions of TS prior to the auto-tune update had this defaulted to "on". The recent update has this option turned off, I thought it was an update bug but Richyvrltd brought the option to my attention and I turned it back on.
It's under OPTIONS - PREFERENCES - PERFORM DIFFERENCE REPORT UPON CONNECT. Handy to have on if you like to hand-smooth and make changes in the comfort of your own home while offline or if you are constantly opening other peoples maps in your project.
Old Jan 31, 2010 | 06:43 PM
  #60
flipt86's Avatar
Total Cats: -1
Are there just three inc files that you need to copy overto the inc folder in the TS project directory?... Airdenfactor, matfactor, and thermfactor?
Last edited by flipt86; Jan 31, 2010 at 10:16 PM. Reason: put other question in other thread...
