Which Lube to Use?
Old May 25, 2010 | 03:01 PM
mad0953's Avatar
Total Cats: -37
Default Which Lube to Use?
Got a new TurboSmart Kompact Plumb Back BOV. It needs to be lubed up (I think) before I install it (and before I go messing around with different springs). What kind of oil/lubricant is the best ot use in this situation? TIA
Old May 25, 2010 | 03:05 PM
Bryce's Avatar
Total Cats: 35
I use synthetic brake caliper lubricant on my Forge.
Old May 25, 2010 | 04:50 PM
Dark Wanderer's Avatar
Total Cats: -1
I guess it's pretty hard to go on the turbosmart website and check the instructions
Lubricate the bore and the piston with Uni-Glide™, hydraulic oil or sewing machine oil (see figure 1) – DO NOT use grease or
viscous oils
Old May 25, 2010 | 05:13 PM
Neo Synthetic is the only oil you can use for this valve.
Old May 25, 2010 | 05:33 PM
FRT_Fun's Avatar
I'm a terrible person
Total Cats: 180
Old May 25, 2010 | 05:49 PM
samnavy's Avatar
Total Cats: 327
Jenna Jamieson would say, "The answer is always, more spit."
Old May 25, 2010 | 05:50 PM
WonTon's Avatar
just skeet on it...
Old May 25, 2010 | 10:41 PM
rider384's Avatar
Want fries with that?
Originally Posted by FRT_Fun
Why would there be flavored ---- lube?
Old May 25, 2010 | 11:03 PM
FRT_Fun's Avatar
Total Cats: 180
I could think of a few reasons.
Old May 25, 2010 | 11:27 PM
Turbo_4's Avatar
I EAT CUM
Ky yours and mine...for the ultimate experience.
Old May 26, 2010 | 03:43 PM
mad0953's Avatar
Total Cats: -37
Geee Mr Smartypants....I did go there but could not find any info.....sorry for making your perfect day so shitty.
viscous oils
Old May 26, 2010 | 04:39 PM
Total Cats: -1
I hope you're kidding right? If not, stop using the Interwebz or something bad will surely happen to this planet!
Let me take you by the hand:
Step 1: http://www.turbosmartonline.com/
Step 2: Click on the link "Instructions & Downloads" wich is the last link on the right, next to the "Dealer Locator" link
Step 3: Choose the right instructions (in PDF) for you BOV under the "Blow Off Valves - Universal" title.
Step 4: Read the PDF to find the tips about lubricating the BOV
Step 5: Have fun with your ---- Lube
And FYI you BOV doesn't need to have a different spring to get adjusted, you only have to rotate the cap to adjust stiffness.
And please, don't get butthurt this time. At least you shouldn't with your lube
Old May 26, 2010 | 07:57 PM
mad0953's Avatar
Total Cats: -37
Thanks Dark...but my BOV is so new that the instructions are not on the website and it is a little different different from any on there. The instructions that came with it make no mention of taking it apart, cleaning and lubing it. I can fax them to you if you would like so you will forgive me for asking a question on this website. I see you post here quite often. The tension is not adjustable. So I think my question was ok to ask. I am not butt hurt btw, just pulling your chain a little. My skin is a bit thicker than you Canadians.
Thanks for taking me by the hand.......I haven't held hands in a long time.....with anyone!!!!
Peace
codrus
Apr 22, 2013 07:40 AM
Zoot
Meet and Greet
Apr 13, 2012 03:14 AM
JasonC SBB
Engine Performance
10
May 21, 2010 06:33 PM
Braineack
Useful Saved Posts
Dec 7, 2006 01:29 PM
