Bushing swap with a $5 tool, no fire needed.
Old Mar 9, 2011 | 09:37 PM
thedguy's Avatar
Default Bushing swap with a $5 tool, no fire needed.
This is an old *** press tool concept, after doing this on a whim at Garage Woolery and I was surprised to find that no one has ever seen this redneck engineered tool before.
Gonna need a few things from the Home Depot hardware section:
One 3/8"-16x24" threaded rod (I call it all thread)
Four 3/8" x 1-1/2" Fender washers
Four 5/16" or 3/8" flat washers
Four 3/8" hex nuts.
All of this came to $4.17 for me
Optional;
A single 36mm socket will work well too. This will come in handy later, worth having anyway.
Might try using autozones free rental and get their ball joint kit as well.
OR Two 2" (or larger) diameter fender washers, though if you
pull the front lower control arm bushings first, you likely won't
need these.
A couple of 14mm wrenches/sockets. If you have an impact gun, get a socket to fit it that fits these nuts and this job will go retarded fast and easy.
The tool is assembled like so:
You thread on a single nut, well down on the piece of all thread, you want to get enough thread to go through both ends of both bushings and room for a couple of nuts and washers,
Drop on two of those flat washers,
then a fender washer,
then a random deep socket or small piece of pipe. Something to act as a spacer so the nut doesn't get forced down the whole created as the bushing comes out,
thread this through the bushings
Next you'll put on another fender washer (or 2 for added strength, they like to flex),
A flat washer (or 2, same thing),
and TWO nuts tightened together.
Should look like this on the other end:
now start wrenching on it:
As you start on it, both ends will start to come in, eventually one will give more than the other and it'll pop out.
One thing I found helps is tapping the bushing with a hammer while compressing the assembly helps the bushing pop out easier and quicker.
Once the first bushings comes out, remove your jam nuts. Pull out the assembly and now replace the "random deep socket" with the 36mm socket (or 2"+ washers or pipe or something to big to go in the hole) and reassemble
You might note earlier I said these were "optional". Reason why I say that is, if you start with the front lower control arm and get lucky enough to remove the bushing with the large lip, you can flip it backwards and use it instead. The very top pic of me doing this job shows said reverse bushing doing its thing.
Now spend the next hour or 2 (depending on using power tools or a ratchet) on the rest of your arms and you'll be done.
Bushings in the rear upright:
Remember how I said the 36mm socket will come in handy later? Yeah this is the spot.
Assemble the tool again, with the 36mm socket as the spacer and wrench it down. Once the bushing comes half way out, you can wiggle it out by hand pretty easily.
Here's it assembled on my upright with the ES poly bushings in place (so ignore the fact that it's obviously the wrong size).
Once done you end up with this
Nice thing about this technique is you can sit in front of the TV and watch a movie while doing it. It doesn't leave any residue behind like burning the old ones out and doesn't heat stress the metal either.
My ES poly bushings went in with no more effort than pushing them in with my hands on all the arms I had done with this tool. I had 2 arms that had them burned out and those were a fight.
Old Mar 9, 2011 | 09:55 PM
yunvmyegt's Avatar
snapon sells a tool like that its supposedly the bmw bushing install tool or thats atleast how its listed...
Old Mar 9, 2011 | 09:58 PM
miatamania's Avatar
Heh. Nice. Much less messy.
Old Mar 9, 2011 | 10:30 PM
Total Cats: 1,417
I like. I sticky?
I've seen presses used that actually bend control arms, I wonder if more stubborn bushings than yours would allow this tool to do that.
Old Mar 9, 2011 | 10:50 PM
sjmarcy's Avatar
Total Cats: -1
Also…grease the threads…it makes it easier.
Old Mar 9, 2011 | 11:19 PM
kotomile's Avatar
Total Cats: 42
Feels sticky to me. Definitely going with this method when I install mine. Thanks for the writeup!
Old Mar 9, 2011 | 11:29 PM
Golferluke's Avatar
Ha ha brilliant, epically simple. I love redneck engineering.
Definitely sticky worthy, would be cool to have a whole sticky thread full of stuff like this.
Old Mar 9, 2011 | 11:55 PM
Miataman28's Avatar
Total Cats: -1
Very cool, i was just gunna use my air hammer at the shop...... But i might try this anyways, looks like a great idea!
Old Mar 10, 2011 | 12:05 AM
thedguy's Avatar
Originally Posted by curly
I like. I sticky?
The bushings in the majority of those pics were from an NB rear lower and they were definitely more resistant than my 90's bushings and I didn't see remotely any flexing. But it's still a possibility.
I forgot to mention...
One of the arms did have the bushing come out with enough force that it took the tool with it about 3 feet away. So use caution when doing this, this may be slow moving but there is still a lot of pressure when cranking down on this thing.
Old Mar 10, 2011 | 12:53 AM
turotufas's Avatar
Total Cats: 7
Awesome! This will help many.
Bryce's Avatar
Total Cats: 35
I have a hydraulic press in my garage, but I think I may try this method.
Old Mar 10, 2011 | 01:13 AM
aznDragonX's Avatar
Total Cats: -1
very nice. Sticky!!!
this sure beat c-clamp method.
Old Mar 10, 2011 | 01:43 AM
Total Cats: 1,417
Originally Posted by aznDragonX
Sticky!!!
Done. Might even consider doing this myself sometime in the far future.
Old Mar 10, 2011 | 03:54 AM
thedguy's Avatar
Are there many other sub 5 post people that get threads stickied?
Old Mar 10, 2011 | 08:09 AM
miatauser884's Avatar
Total Cats: 11
Great post! Sticky this for sure!
Old Mar 10, 2011 | 08:24 AM
GeneSplicer's Avatar
Total Cats: 180
^^ That's where you and say doh...
Will definetly remember this when it come time, thanks!
Old Mar 10, 2011 | 08:47 AM
Total Cats: 11
Yep, that little tool would have been much better than the 3-arm puller I used. You could probably use different size washers and do the endlink bushings.
Old Mar 10, 2011 | 09:05 AM
m2cupcar's Avatar
Total Cats: 372
I did that fifteen years ago, but added an impact gun and some spray lube.
Old Mar 10, 2011 | 09:18 AM
I used my thumbs to press the old bushings out. Maybe you queers need to visit the gym for the first time in your pathetic lives.
Old Mar 10, 2011 | 04:24 PM
thedguy's Avatar
I've been using this thing on bikes since I was 7 to put in bottom and headset brackets on bikes. I'm couldn't believe how many people hadn't known about this simple tool when I whipped it out at Techday.
