1.8 Head on 1.6 Block?
Old Apr 20, 2011 | 01:00 AM
TOPSECRET's Avatar
Default 1.8 Head on 1.6 Block?
Just out of curiosity.
Is it possible for the na/nb motors, to swap heads, and trannys?
I hear honda heads yap all day about how they swap different heads and trannys with different blocks and such.."b16, b20, single cam, w/LS head, GSR tranny, Typr-R this, bullshit that, and all honda noise"
Just wondering if its possible to swap such components with the miata motors..?
Old Apr 20, 2011 | 12:23 PM
Joe Perez's Avatar
Boost Pope
Total Cats: 7,548
C'mon, guys. It was a valid question.
(lots of stuff deleted)
1: Transmissions are freely interchangeable between all year Miatas, as are complete longblocks. There are some electrical differences, but mechanically it works. Note that this holds true only for the NA and NB cars ('90-'05). The new style NC is a totally different vehicle, and nothing interchanges with those cars.
2: The 1.8 Miata engine isn't just an overbore of the 1.6, it's a totally different motor. The block is longer front-to-back, with a different bore spacing. So while certain parts are interchangeable (rods, flywheel / clutch, etc) the heads are not, nor are the cranks, cams, or manifolds.
3: Within the 1.8 engine family ('94-'05), most parts are interchangeable. There are only a couple of minor incompatibilities (eg: intake manifolds are not interchangeable across the 1998 barrier) but these are fairly inconsequential.
Old Apr 20, 2011 | 12:26 PM
buffon01's Avatar
Total Cats: 13
Old Apr 20, 2011 | 12:32 PM
Sean's Avatar
They will not interchange. You can swap complete motors but not the head/blocks. The only motor this works on is the BP and that would just be putting another head off a different year BP. Trans missions are interchangeable. Miatas are nothing like hondas for swaping parts. Trust me I own one of each.
Old Apr 20, 2011 | 12:49 PM
jbresee's Avatar
Obviously, I haven't done this, but here is the book I was referencing:
Mazda Miata MX-5 Performance Projects by Keith Tanner. ISBN-13 978-0-7603-1620-7
Page 45: "Retrofitting a NB head on an NA Engine"
He states that ideally, you should use an NB intake manifold, but that you can modify an NA manifold. He suggest a head from a 1999-2000 based car as the most appropriate choice to avoid the VVT issues. He has suggestions for dealing with the CAS and VICS system.
Like I said, I haven't done it, but Keith has pictures that show it being done.
Old Apr 20, 2011 | 12:55 PM
Techsalvager's Avatar
NB\NA as in 1.8 NA vs 1.8 NB
Old Apr 21, 2011 | 12:59 AM
Joe Perez's Avatar
Boost Pope
Total Cats: 7,548
The NB head will fit onto a 1.8 NA engine ('94-'97) as the blocks are essentially identical. No 1.8 head (NA or NB) will fit onto a 1.6 ('90-'93) engine, which has a different block. The number of components that will interchange between a 1.6 and 1.8 engine is quite small, actually. Rods, bearings, lifters, flywheel (though the 1.8s got larger flywheels and clutches from the factory), a few other trivial bits.
Honestly, though, the gains to be had from doing so are relatively minuscule. And, these days, VVT is no longer something to be avoided, since several ECUs capable of dealing with it are available, plus of course the VVTuner, which is a neat little standalone VVT controller that also produces an NA-style CAS signal as a byproduct.
I just can't imagine why you'd go through the trouble. If you're going to do a swap (and presuming you don't want to go with forced induction), just grab the whole NB engine and plop it in. Higher compression.
Old Apr 21, 2011 | 02:00 AM
kenzo42's Avatar
Total Cats: 13
Isn't there a 1.6 VVT head? Would that swap work?
Old Apr 21, 2011 | 08:37 AM
jbresee's Avatar
Agree with all of the above. I was just quoting Mr. Tanner.
Old Apr 21, 2011 | 07:44 PM
Tim Irwin's Avatar
Not in the US market at least. VVT didn't come out until 8 years after the 1.6l Miata.
Old Apr 21, 2011 | 08:10 PM
Joe Perez's Avatar
Boost Pope
Total Cats: 7,548
I have some conflicting information here.
Some sources say that the euro/Japan-spec 1.6L NBs continued to use the B6 engine.
Some sources say that at least some 1.6L euro/Japan-spec NBs had VVT.
I can find no evidence to support any B6 engine ever having been equipped with VVT.
Now, I'm no expect on the Z-series engine, however what little information I can find suggests that it was "based on" the B-series design, and that the block itself is either the same as or similar to the early (pre-B8) B-series block.
If true, then it's entirely possible that the head from a ZL-VE (a 1.5L engine with VVT) might fit onto a B6.
Personally, I think it'd be a waste of time and money.
Old Apr 21, 2011 | 10:21 PM
or just retrofit a 1.8 vvt into the 1.6l head if possible, no idea if cam journals differ in size.
Would be interesting if you could fit it on both cams
Old Apr 22, 2011 | 05:14 AM
Retrofitting a 1.6 motor with VVT would involve a huge amount of work. A 1.8 exhaust VVT retrofit would be less work, but still a ton of work.
Old Sep 24, 2012 | 10:49 AM
fhdez87's Avatar
Total Cats: -28
Default Wow
So... All you guys are telling me that i could swap a 2005 engine in my 96 miata, and the transmission will fit?
Old Sep 24, 2012 | 10:52 AM
Saml01's Avatar
yes.
Old Sep 24, 2012 | 11:26 AM
RyanRaduechel's Avatar
Total Cats: 149
Swap in a 12 valve Cummins turbo diesel...
Old Sep 24, 2012 | 11:37 AM
thenuge26's Avatar
Total Cats: 239
Guys, I think loud miatas sound too ricey for me. So I think I am going to swap in a 2 stroke weed-whacker motor. That should help.
Old Sep 24, 2012 | 11:59 AM
fhdez87's Avatar
Total Cats: -28
WOW Thanks, so i am going to swap 06 engine into my 94 miata
Old Sep 24, 2012 | 12:15 PM
Bryce's Avatar
Total Cats: 35
There is a difference between the 05 and 06 engine. A very big difference.
Old Sep 24, 2012 | 12:26 PM
thenuge26's Avatar
Total Cats: 239
Yeah, they bored and stroked the 06 engine to 2 liters right
