Honda intake manifold
Old Nov 2, 2011 | 08:30 PM
  #441
Lowers are different so you can't bolt an 01 UIM to a 99 LIM, but you can bolt an 01 LIM to a 99 head.
Old Nov 3, 2011 | 04:38 PM
  #442
blindboxx2334's Avatar
exactly wut i needed to hear. thanks a bunch! this will make trying to track a LIM wayyyy easier and prob cheaper.
Old Dec 11, 2011 | 10:30 AM
  #443
Buzz's Avatar
So what is the best intake manifold for a (350 whp turbo) with a 99 head?
Old Dec 11, 2011 | 01:02 PM
  #444
aaronc7's Avatar
Total Cats: 43
blox or skunk2 manifold.....edelbrock victor x is probably 'best' of the honda ones for 400+ but below that you're probably just giving up a good bit of low end powa
Old Dec 11, 2011 | 04:12 PM
  #445
victor X is designed for 10,000RPM, it's not the ideal choice for our motors.
I'd choose the performer X over it.
IIRC blox is a rip of the skunk2, which is a rip of the ITR oem manifold.
Old Dec 12, 2011 | 10:59 PM
  #446
illeniummx5's Avatar
Total Cats: -14
im curious. why would you dare think of putting honda products on the prestigious miata?
It would be like a betrayal of the philosphy behind the mazda roadster. parumph.
Old Dec 13, 2011 | 07:43 AM
  #447
TurboTim's Avatar
Total Cats: 425
I'm curious. What's a parumph?
Old Dec 13, 2011 | 08:10 AM
  #448
lassi's Avatar
Total Cats: 12
Apparently;
"a town in nevada. the sound an elephant makes when it farts."
Old Dec 13, 2011 | 09:09 AM
  #449
LowFlyin''s Avatar
He's oh so close to 15 posts, though...
Old Dec 13, 2011 | 09:17 AM
  #450
Bond's Avatar
Miatas are not prestigious. They are a shell. It's the go-fast parts that make them fun. Otherwise, they are just a chick car with 90 horseys.
Old Mar 8, 2012 | 07:17 PM
  #451
yellowihss's Avatar
Total Cats: 8
I'm about to build one of these, but I need the flange.
I know I saw a CAD, or solidworks drawing on here a while back, but cant seem to find it.
Can somebody find it please. It would be greatly appreciated.
Old Mar 9, 2012 | 04:15 PM
  #452
Boost Joose's Avatar
Bannisheded
Total Cats: -222
Yellow, which mani you going with?
Old Apr 1, 2012 | 09:09 PM
  #453
kotomile's Avatar
Total Cats: 42
I'm chiming in again to say that I haven't completely forgotten about installing this bad boy, it just was moved to the back burner. Had a lot of other things going on. But today I ordered some more things I need to make this happen, which is good. Right?
I ordered a 3" --> 2.5" reducing coupler so I can use my existing 2.5" charge piping. Since I currently have an obsolete inside-mount WI nozzle drilled into the existing 2.5" elbow, I went to alcohol-injection.com and ordered 4 .75 GPH nozzles, line, new check valve, and 3 splitters... so I'm plumbing the WI into the mani now, for better or worse.
So now I need to determine the optimal distance up the runners for the nozzles. I also need to learn myself some timing theory.. because if this mani is going to necessitate a spark tune change I guess I need to budget for some dyno time. On top of that, I need to wire up the Honda MAP and change whatever needs changing inside the MS, and calibrate the MAP once in. Jeez...
This had better be worth it.
Old Apr 2, 2012 | 01:51 AM
  #454
Full_Tilt_Boogie's Avatar
Total Cats: 409
If you went aware, the Honda map is only a 1.7 bar.
You can get bigger ones that fit in the stock Honda throttle, "Omni" MAP sensors are popular.
Old Apr 2, 2012 | 04:36 AM
  #455
kotomile's Avatar
Total Cats: 42
I'm an idiot, I meant the TPS. Dunno why I typed MAP instead. Derp.
Old Apr 6, 2012 | 11:56 PM
  #456
aaronc7's Avatar
Total Cats: 43
my turn
Old Apr 7, 2012 | 12:04 AM
  #457
TorqueZombie's Avatar
Total Cats: 64
Please post a finished pic
Old Apr 7, 2012 | 07:43 AM
  #458
aaronc7's Avatar
Total Cats: 43
My motor is still at the shop getting rebuilt- that's my biggest hold up right now to getting everything finished, but I will definitely document the flange conversion and all that
Old Apr 7, 2012 | 05:40 PM
  #459
yellowihss's Avatar
Total Cats: 8
I'm going to post a few more pics than I would otherwise normally do since there are a number of people wondering about this. Hopefully between aaronc7 and I this shoould be pretty well documented.
Here is the manifold I bought.It is a Skunk2 for a B18C1.
Here is the Throttle Body I bought to go with it since Skunk2 is running a sweet deal off their website.
Here they are together.
Since I got the 74mm TB I will have to do a little port work.
Here is the flange I bought from ftjandra (not sure if he has more or not.)
This thing is sweet, and looks like there is a lot of time spent on designing it.
It is made out of 6061 aluminum.
On the manifold.
Attached Thumbnails Honda intake manifold-f4ce36c0.jpg   Honda intake manifold-a30547eb.jpg   Honda intake manifold-d1ef6f7d.jpg   Honda intake manifold-1da75e97.jpg   Honda intake manifold-71deacf5.jpg
Honda intake manifold-ab30402c.jpg   Honda intake manifold-f737a9a9.jpg   Honda intake manifold-e5302f4c.jpg   Honda intake manifold-14acc394.jpg   Honda intake manifold-c8d5e351.jpg
Old Apr 7, 2012 | 05:48 PM
  #460
aaronc7's Avatar
Total Cats: 43
Nice!!! If I can find a reasonably priced flange by itself, I will go that route, rather than dealing with hacking up my stocker...but they seem hard to come by and/or expensive.
