XIDA-S removing adjustment knob?
Old Dec 24, 2011 | 10:45 PM
Zefiris's Avatar
Default XIDA-S removing adjustment ****?
So I've been searching for over two hours now and can't find anything specific. I ordered a set of XIDA-S coilovers and the front springs shipped separately. Now I need to remove the top hats to install the springs, but the rebound adjustment **** is in the way. So the question
To remove the adjustment ****, do I just twist really hard counterclockwise? It seems like there is a bit of resistance when just twisting it.
Or do I start undoing the brass looking fitting that is mated up against the shaft right below the adjustment ****?
Picture -- http://949racing.com/xida-scoiloversmiata.aspx
Silly question with a simple answer, but I don't want to screw something up and have them rebuilt before ever getting them on the car.
Old Dec 24, 2011 | 11:10 PM
crashnscar's Avatar
Total Cats: 9
There is a small allen head set screw going into the side of the ****, perpendicular to the shaft. Loosen it and the **** will easily slide upwards and off.
Old Dec 24, 2011 | 11:25 PM
Zefiris's Avatar
Phew, glad I asked. Thanks for the quick answer. Now maybe I can get these put on tonight
Old Dec 24, 2011 | 11:29 PM
johnwag's Avatar
it's a 2mm allen set screw on the side. When you re-install the ****, make sure that it's against the flat side of the brass adjuster.
Old Dec 26, 2011 | 03:21 PM
bigx5murf's Avatar
Unless your trunk is stripped out, I highly recommend picking up a pair of these.
http://www.vorshlag.com/product_info...roducts_id=446
Call and ask for the extra long versions, they're an extra $15. Totally worth it though.
Old Dec 26, 2011 | 06:53 PM
GeneSplicer's Avatar
Total Cats: 180
You're a bastard for actually owing a set of xidas...
Otherwise - good to know for future xida fondeling - that cable adjuster is awesome!
Old Dec 26, 2011 | 07:13 PM
By "stripped out" you mean "remove one panel", right.
Old Dec 26, 2011 | 08:18 PM
Bond's Avatar
LOL I was thinking the same thing.
Old Dec 26, 2011 | 09:18 PM
bigx5murf's Avatar
There's also that those grey floss looking interior panels held on by 3 plastic clips, and that panel is held in by 3 bolts, but the plastic bin underneath needs to be removed to remove that panel also... I'm lazy, and like a finished trunk
Old Dec 27, 2011 | 07:57 AM
:MazdaspeedCrew:
stoves
Apr 21, 2016 03:00 PM
ihiryu
33
Oct 8, 2015 04:56 PM
slomiata
Oct 7, 2015 01:11 PM
