Faelflora breaks his promise, time to part out car. GIT THE SAWZALL!
Old Jan 11, 2012 | 06:49 PM
  #2021
Slowest Progress Ever
Total Cats: 305
That was the most fail video I have ever seen.
I'm just glad to finally see this thing back together and driving down the street.
Old Jan 11, 2012 | 07:00 PM
  #2022
Vashthestampede's Avatar
Total Cats: 58
Originally Posted by Faeflora
It runs. On the street.
Jesus christ! I don't think you should be on the street!!
The car sounded pretty good, but your going to crash it driving around like that. Dropping the camera and ----. FFS man!
You really do take well to the failflora name.
Old Jan 11, 2012 | 09:29 PM
  #2023
vehicular's Avatar
Total Cats: 47
Originally Posted by miata2fast
I am getting more and more convinced that this site is a gay dating service.
Because Miata Forum.
Old Jan 11, 2012 | 10:57 PM
  #2024
FRT_Fun's Avatar
I'm a terrible person
Total Cats: 180
I'll hold your.. uhh.. camera while you drive.
Old Jan 12, 2012 | 03:51 AM
  #2025
Zaphod's Avatar
Total Cats: 106
In for thread title change... Faaflora is not a cameraman....
Old Jan 12, 2012 | 01:46 PM
  #2026
Full_Tilt_Boogie's Avatar
Total Cats: 409
Attached Thumbnails Faelflora breaks his promise, time to part out car. GIT THE SAWZALL!-3832124335_07fce29c03_b.jpg
Old Jan 12, 2012 | 02:38 PM
  #2027
Total Cats: 3,588
Fae, I just saw the video of your seizure. Are you OK? I heard some muffled grunts and groans, too. You didn't bite your tongue off did you?
Old Jan 12, 2012 | 02:46 PM
  #2028
Clos561's Avatar
it's a typical fae video, absoultely no content.
he would have been better off taking vid of flushing his poop down the toilet.
Old Jan 12, 2012 | 03:12 PM
  #2029
fmowry's Avatar
Originally Posted by TurboTim
What's that gauge thingie on the right, and what's the red indicator light?
Red light indicates when the flywheel is hitting the coolant reroute.
Old Jan 12, 2012 | 03:15 PM
  #2030
fmowry's Avatar
Plenty of Faesh.
Old Jan 12, 2012 | 03:45 PM
  #2031
miata2fast's Avatar
Total Cats: 175
Originally Posted by fmowry
Plenty of Faesh.
Well I just spit on my computer; that was damn funny!
Old Jan 13, 2012 | 02:59 AM
  #2032
Faeflora's Avatar
Total Cats: 130
Went for a drive tonight to play some ping pong at a buddies house. Of course, it is still raining.
Despite that i made some light throttle pulls to redline and hit 12 pounds of boost. I forgot how much fun it is to drive my car and how much time I have put into tuning it.
Sadly, despite upgrading my fuel pump wiring i am still seeing a drop in batt voltage with boost and rpm. I have an NA alternator sitting in my garage so i will convert over to that before breaking out the meth and se if that fixes the voltsge crap out. I just want to drive my car for a few days before fuci g with it again.
Will tape camera to wheel tomorrow if not raining.
Old Jan 13, 2012 | 03:05 AM
  #2033
chpmnsws6's Avatar
How does a fuel pump rewire effect the vehicles main voltage? It should only consume 6-15amps where the alternator should be able to put out 65+ (being conservative since this is a little Miata go-kart) amps.
Old Jan 13, 2012 | 03:11 AM
  #2034
Reverant's Avatar
Total Cats: 369
A NA alternator will only get you crappy results. They idle at ~13.2V, and can drop down to 12V just by having both fans switched on. You want an RX-7 FD alternator, which can output 100 amps, instead of the weak 65A of the NA alternator.
Old Jan 13, 2012 | 03:23 AM
  #2035
soviet's Avatar
Total Cats: 269
OOOo this is good to know. Are they more durable too? Because I had an N/A alternator die after 1 hour of track
Old Jan 13, 2012 | 03:24 AM
  #2036
chpmnsws6's Avatar
Upgrade your alternator wiring if you plan to use this. I run my fan relay power directly off the alternator output stud to keep its 25-55 amps off the alternator wiring.
Old Jan 13, 2012 | 09:16 AM
  #2037
Faeflora's Avatar
Total Cats: 130
I dont know guys why i am having this problem then.
You think maybe my NB alternator is dead?
Reverant does this rx7 fd alternator just bolt right up on stock position?
Old Jan 13, 2012 | 09:28 AM
  #2038
...and can drop down to 12V just by having both fans switched on.
Much below this...With the a/c running and headlights on and stereo blasting music, I can get my voltage to drop to 11.5v where my LC-1 will then shutoff.
and it's only 60A. the Auto is 65A.
well the 1.6L one that is.
the 1.8L is 65A manual and 70A auto.
Old Jan 13, 2012 | 09:29 AM
  #2039
I'm just curious: why are you so worried about the voltage dropping?
Is it completely crapping out at one point, or does the car start breaking up, or what?
Are you getting spark blowout?
Old Jan 13, 2012 | 12:43 PM
  #2040
Reverant's Avatar
Total Cats: 369
Yes, it bolts in, no problems at all. It has a 6-rib pulley, however you just use the stock 4-rib belt and it won't slip or jump or anything.
