crank pulley wobbling - how do i fix this?
Old Feb 14, 2012 | 07:54 PM
phillyb's Avatar
Total Cats: 9
Default crank pulley wobbling - how do i fix this?
i'll post a video when i get home, but i'll try to describe this as best as i can.
when putting the pulley onto the crank, it wobbles back and forth. the hole on the pulley is slightly larger than the crank. the notch lines up, but there's too much play...
the piece on the pulley that has the hole...is that the boss? or hub boss?
can that be replaced without replacing the whole pulley?
thanks in advance. when i get home, i'll post a video for further clarification.
Old Feb 14, 2012 | 08:46 PM
Miater's Avatar
Total Cats: 27
Buy a used pullie. There pretty cheep.
Did you have the crank machined? Was this the reason the pullie is off of the motor in the first place? Why, why is it too big?
Old Feb 14, 2012 | 08:54 PM
phillyb's Avatar
Total Cats: 9
this is a used pulley i got from a member here about 2 weeks ago.
it's out cause the engine is being rebuilt.
Old Feb 14, 2012 | 09:46 PM
phillyb's Avatar
Total Cats: 9
here's the video. it's a 99 engine
Old Feb 14, 2012 | 09:56 PM
Which pulley? The front one with the 2 belts or the one that the timing belt goes on?
Just watched the video, have you tightened the main bolt down to 120ft/lbs and then installed the 4 10mm bolts on the big pulley?
Old Feb 14, 2012 | 10:00 PM
phillyb's Avatar
Total Cats: 9
crank pulley...the one with two pulleys. you can kind of see it in the video
this guy
Attached Thumbnails crank pulley wobbling - how do i fix this?-0419d5bd.jpg   crank pulley wobbling - how do i fix this?-1e73167c.jpg   crank pulley wobbling - how do i fix this?-ee940a2c.jpg
Old Feb 14, 2012 | 10:21 PM
I think you need to tighten down the big bolt to 120ft/lbs and then see if it moves.
Old Feb 15, 2012 | 04:30 AM
Mobius's Avatar
Total Cats: 365
There's a plate that goes behind this pulley.
a) is it there?
b) is it oriented correctly? It has a front and a back. The center is slightly humped, the hump should go towards the front of the car, away from the engine.
Old Feb 15, 2012 | 05:51 AM
blaen99's Avatar
a) is it there?
Any chance of pictures of said plate?
Old Feb 15, 2012 | 07:59 AM
phillyb's Avatar
Total Cats: 9
a) is it there?
a) silver piece is the plate, no?
Old Feb 15, 2012 | 08:27 AM
olderguy's Avatar
AFM Crusader
Total Cats: 364
Plate was on later NA's and NB's for crank sensor. Looks like OP has one of the early ones since the TB cog has made an impression. I would tighten everything up and see if it runs true on the car.
Old Feb 15, 2012 | 11:19 AM
BarbyCar's Avatar
I had a '00 engine with the #4 bearing fault. Mazda warranty replaced the engine and it never ran properly. Diagnosis eventually tracked the problem to a wobbling pulley (crank trigger miss) caused by A BENT CRANKSHAFT. Mazda replaced that engine too. Any chance you have a bent crank here?
Old Feb 15, 2012 | 11:22 AM
phillyb's Avatar
Total Cats: 9
doubt it...it's been measured and made sure that it's in spec during this build.
Old Feb 15, 2012 | 02:42 PM
Mobius's Avatar
Total Cats: 365
I have a pdf copy of the 99-00 service manual; here's a page showing the plate.
My engine is a bit different since it's a 2001, and my pulley looks different, no keyway in mine. However my page in the 2001 manual looks similar to this, so I'm assuming the plate is similar. My plate is ~1/8" thick, and has the same diameter as the accessory crank pulley. It is not attached to the pulley in any way, it is a separate piece which gets sandwiched underneath the accessory pulley. The inner area with the 4 bolt holes is the part that is humped.
Attached Thumbnails crank pulley wobbling - how do i fix this?-1999-2000workshopmanualp201.jpg
Old Feb 15, 2012 | 02:51 PM
phillyb's Avatar
Total Cats: 9
that plate is there.
i took off the four bolts that bolt together the plate and the pulley boss from the pulley itself...the boss is shot (i think and hope). i just ordered a new one and it should be tight. i'll keep everyone posted, but i don't think i'll need to loctite anything. and i'm fairly certain the crank doesn't need to be replaced.
thanks for your help.
Old Feb 15, 2012 | 03:01 PM
Scary. Try swapping the backing plate with another one - I doubt the crank wore down.
Take a picture of the keyway on the crank too.
Old Feb 15, 2012 | 03:46 PM
phillyb's Avatar
Total Cats: 9
i'll try to get a picture tomorrow, though i was just over there. the key is fine. the crank is fine.
Old Feb 16, 2012 | 12:05 AM
Faeflora's Avatar
Total Cats: 130
I really doubt the crankshaft was bent.
The crank is pretty much the strongest thing in the whole miata.
Old Feb 17, 2012 | 06:42 PM
Moffitt's Avatar
Total Cats: -1
Crank nose shouldn't be bent.
If the key way is fine to still be able to index the boss and crank together, it should be fine.
The assembly on yours from front to back should be..
21 mm bolt>>large accessory pulley>>boss pulley>>lower timing cog>>crankshaft.
(correct me if I am wrong)
You DID inspect the keyway inside the boss and on the nose of the crank correct?
Old Feb 17, 2012 | 07:43 PM
phillyb's Avatar
Total Cats: 9
yeah, crank is fine.
keyway is fine.
hoping it's the pulley boss.
when we unbolted the four bolts that hold the pulley to the boss, flipped the boss over and there was considerably less play on the nose of the crank. obviously you can't bolt it on like that and expect it to work. we just did this to test the theory that the boss was not to spec...and it was not.
