door bars are worth every cent
Old Jan 27, 2010 | 07:13 PM
  #101
cueball1's Avatar
Originally Posted by ZX-Tex
Clearly that is not true. Marketing-speak.
They've always contended HD's door bars do nothing. Obvious in this thread it's not true. Sure it bolts in only two places but it triangulates the door and rear bulkhead openings. Now they have theirs and it bolts in four places. It may be better but it sure looks fugly and a whole lot tougher for entry and exit.
Old Jan 27, 2010 | 08:21 PM
  #102
Without looking at their page, their design could be stiffer for the same weight or the same weight for the same stiffness. The plates would increase beding stiffness considerably in the plane of the plates (vertically as installed). Also it can be narrower with the smaller diameter tubing.
Nice idea from a purely mechanical standpoint but I do not like the look at all especially with the lettering cutouts. I still prefer the ones I have.
OK read the description..
Put a ******* pipe between the a-b pillars, bolt the **** together, get money, **** bitches, go fast at the track, god damn.
Old Jan 28, 2010 | 06:45 AM
  #103
02semiata's Avatar
I Recall reading that boss frog was against the idea of door bars. I guess not anymore.... They call them frog ribs
Frog Ribs (Door Bars) - MX-5 Miata Forum
Old Mar 19, 2012 | 09:15 PM
  #104
gearhead_318's Avatar
Total Cats: 21
I realize this thread is older then dirt, but I've got questions.
Has anyone tried bossfrogs door bars, are they better then the hard dog door bars? Would they even fit since I've already got a HD rollbar?
How do door bars effect handling? Do they promote/diminish oversteer or understeer?
Old Mar 20, 2012 | 12:05 AM
  #105
newold_m's Avatar
The mounting point on the BF door bar does not match the HD rollbar and vice versa. BF has two bolts and HD has three.
Old Mar 20, 2012 | 12:15 AM
  #106
Total Cats: 21
Thanks.
Old Mar 27, 2012 | 10:32 AM
  #107
Ninjaneer's Avatar
Any comparison of the HD Doorbars vs the DIY Roadster Bars?
I read over at m.net, the roadster bars are easier to get in and out of. However, it has a larger outside diameter.
Any interference with driver seating position?
Does the DIY Roadster bars bolt directly to hard dog roll bar mounting plates?
Old Mar 27, 2012 | 12:22 PM
  #108
newold_m's Avatar
Yes, they do. I found them pretty easy to get in/out with stock seats. You slider over them and seat bottom is almost level. Because they angle out, I'd think there is more space with the DIY ones, but have not seen a HD bar in person. Also keep in mind the DIY ones will interfere with NB door pockets, again due to the bend. You can notch the plastic.
Old Mar 27, 2012 | 02:41 PM
  #109
Ninjaneer's Avatar
Good to know, on my bucket list of things to buy.
Zaphod
47
Oct 26, 2018 11:00 PM
Quinn
Cars for sale/trade
6
Oct 23, 2016 07:58 AM
