How to resurface an Aluminum Head For a MLS head gasket.
Old Apr 13, 2012 | 11:07 AM
BogusSVO's Avatar
Total Cats: 205
Default How to resurface an Aluminum Head For a MLS head gasket.
I use a Comec Auto I 1000 High Speed Milling Machine with CBN insert for Cast Iron OR a PCD Insert for Aluminum Heads
This machine is double adjustable, I can adjust the spindle speed and the table travel speed to achieve the surface finish that is required.
http://www.joebakerequipsales.com/AutoI1000.htm
The first thing to do is check the valve cover surface for any burrs and remove them.
Next is to mount the head in the machine and check the level of the head in both directions.
Then the other way, this head was not out that bad from the last time it was milled.
I did a “getting to know you” pass of .002 to see how square the head was. This was done on a faster setting.
Notice the upper and left side of the head is dull, this is a low spot. The head was not index properly and did not maintain a proper “square” to the valve cover surface.
I made another cut of .003, I sped up the cutter, and slowed the table speed.
This is the end result.
Another different view.
Now with a proper surface, and the head re-squared, The customer will have no issues with a MLS gasket sealing, and also having a closer to equal combustion chamber size.
Attached Thumbnails How to resurface an Aluminum Head For a MLS head gasket.-dscf3965.jpg   How to resurface an Aluminum Head For a MLS head gasket.-dscf3964.jpg   How to resurface an Aluminum Head For a MLS head gasket.-dscf3961.jpg   How to resurface an Aluminum Head For a MLS head gasket.-dscf3963.jpg   How to resurface an Aluminum Head For a MLS head gasket.-dscf3962.jpg
Old Apr 13, 2012 | 02:23 PM
Joe Perez's Avatar
Boost Pope
Total Cats: 7,548
Dale, this is really beautiful stuff you're doing. I'm gonna have to compile it all into a sticky at some point.
Old Apr 13, 2012 | 02:43 PM
BogusSVO's Avatar
Total Cats: 205
Oh, I still have a few more to post, just been dropping one a day.
I have some I will be doing for the 1.8l in the comming week.
Old Apr 13, 2012 | 03:02 PM
cardriverx's Avatar
Total Cats: 12
+ props for you.
Old Apr 13, 2012 | 03:09 PM
ianferrell's Avatar
Yeah... I wish you were a little closer, I've got a vvt motor that could use a lookover before it gets new rods (maybe more)
Old Apr 13, 2012 | 04:30 PM
Faeflora's Avatar
Total Cats: 130
Thank you very much for posting these great machine work "how to's". It helps me understand motors more. <3
Old Apr 13, 2012 | 04:50 PM
BogusSVO's Avatar
Total Cats: 205
Fae... That is the point of them!
Hope they help you loose the "nickname" you have around here!
stoves
Apr 21, 2016 03:00 PM
graexodus
Oct 26, 2015 01:48 PM
Aroundcorner
Oct 1, 2015 03:20 PM
shooterschmidty
Engine Performance
8
Sep 30, 2015 10:28 PM
