How to Measure, Mic, a Piston
Old Apr 18, 2012 | 08:44 PM
BogusSVO's Avatar
Total Cats: 205
Default How to Measure, Mic, a Piston
Supertech PN# P4-MA835-N4
Factory supplied spec sheet.
They ask for a bore spec 3.287/83.50 mm, This what is your recommend bore size.
Tools needed for the procedure, Outside micrometers 3-4 inch,
But in a pinch, venire calipers will “Get you close” if just doing a quick check
A machinist standard is handy to have, so you can zero your measuring tools.
The points you want to measure 90* to the wrist pin centerline
A view of the appox pot to measure from, with venire caliper.
All 4 pistons in the box measured 3.2845
This is going to be Piston to Wall clearance, PTW, in theory. Your actual PTW will vary due to cylinder block finish.
The factory spec sheet says 3.287”/83.50 mm
The formula for converting mm to inches is
Mm x .03937 =Inches
83.50 x .03937 = 3.287395
Now to figure PTW (Theory)
3.287 – 3.2845 = .0025 PTW clearance
I am more accustomed to seeing .0035, but that is on a 85mm piston, and other brands of forged pistons.
That also be in part due to the “Phosphate dry lubricant”
From the super tech website
SURFACE FINISH:
Finally our "phosphate dry lubricant" coating is applied to protect the rings against "micro welding" and enhance lubrication on the skirt/cylinder area.
Piston Rings are manufactured in Japan with the latest technology for high performance applications.
Quality Control: Performed after every step of the manufacturing process in climate controlled environments to ensure reliability of dimensions.
http://supertechperformance.com/products.html?id=10
Attached Thumbnails How to Measure, Mic, a Piston-dscf6037.jpg   How to Measure, Mic, a Piston-dscf6043.jpg   How to Measure, Mic, a Piston-dscf6039.jpg   How to Measure, Mic, a Piston-dscf6040.jpg   How to Measure, Mic, a Piston-dscf6044.jpg
Old Apr 19, 2012 | 02:01 AM
The tight .0025 clearance is mostly due to Supertech's 4032 alloy. It's got a higher silicone content than the standard 2618 that everyone else (Weisco, CP, etc) uses, which means the ultimate strength is a tiny bit lower (something like 5% IIRC) but the thermal expansion is quite a bit less. It allows for tighter wall clearances, less piston noise, and longer life.
Old Apr 19, 2012 | 10:21 AM
BogusSVO's Avatar
Total Cats: 205
Sav.. I understand that, But I am human, and humans do not like change. For most of machining life, I have set up PTW to the .0035 clearance.
I will adapt and use the tighter clearance.
When you been trained from day one that "loose lives"
It is ingraned in the thought prosses, It takes a bit to over come.
Old Apr 19, 2012 | 11:21 AM
Efini~FC3S's Avatar
Total Cats: 99
This has been mentioned before in some of your other threads; you need to enable the "Macro" mode on your camera.
The information you've been adding to our forum has been very helpful and I think everyone is very appreciative. In that sense it's hard to complain about your pictures, but there should be a simple switch somewhere on your camera that will help it focus for pictures like this.
Anyway, thanks again for all your knowledge dumping on this site.
Old Apr 19, 2012 | 11:41 AM
BogusSVO's Avatar
Total Cats: 205
The Macro/flower Icon would not come on when I took these pics.
Old Apr 21, 2012 | 10:50 PM
chpmnsws6's Avatar
With you cats so worried about the picture quality, maybe you should all pitch in and send him a camera.
Once again, thanks for the great read! +1 props.
Zaphod
47
Oct 26, 2018 11:00 PM
stoves
Apr 21, 2016 03:00 PM
pdexta
Sep 28, 2015 11:18 AM
