Faelflora breaks his promise, time to part out car. GIT THE SAWZALL!
Old Jun 6, 2012 | 12:28 PM
  #2921
pdexta's Avatar
Total Cats: 184
Stupid question, I know, but I didn't see it mentioned... Is the driveshaft out?
Old Jun 6, 2012 | 12:47 PM
  #2922
Faeflora's Avatar
Total Cats: 130
Ya.
I think the input shaft is hung up on the outermost clutch disc. I was told that often happens and you have to align it "just so" to pull the trans out. Brute force is apparently, bad.
I should have pulled the fuckying motor. I think it is gay as hell that i have to pull the motor each time i have to swap trannies. Fail.
Sean AKA GODLIEST GOD OF WRENCHING may stop by this evening before I pull the motor to lay his senior eye upon my catastrophe.
Old Jun 6, 2012 | 01:02 PM
  #2923
Maybe if you took pics and posted them we would be more helpful. Well really it would just be more ---- for us to laugh at.
Old Jun 6, 2012 | 05:52 PM
  #2924
Faeflora's Avatar
Total Cats: 130
There aint shiit to see. Just a damn trans that is 3/4" away from the oil pan lookin all obstinate n shiz.
To fix my transmission problem I have determined that the solution is custom cams. Yes, I have a reasonable priced source for custom VVT cams.
So.
What specs should I get? 280? 272? Give me specs.
Old Jun 6, 2012 | 06:03 PM
  #2925
Asx's Avatar
Asx
Are you absolutely positive you have all the bolts out? Serious face. I pulled my trans a good inch away from the engine and it wouldn't budge any further. I pry barred that ---- and once the ear on my starter broke off everything came off all nice and happy. The bolt was hidden under some wiring harness and i couldn't see it
Old Jun 6, 2012 | 06:22 PM
  #2926
blaen99's Avatar
Originally Posted by Faeflora
Ya.
Good to know you've came to your senses Faefae.
Old Jun 6, 2012 | 09:03 PM
  #2927
Total Cats: 1,415
I refuse to do clutch/transmission work without removing the engine. I have a small garage though, no room on the sides. I need an old driveshaft for a plug though.
Old Jun 6, 2012 | 09:43 PM
  #2928
Call Steve@ Panic Motorsports. He sells old drive shafts already cut to be used as plugs.
Old Jun 6, 2012 | 11:53 PM
  #2929
Slowest Progress Ever
Total Cats: 305
I refuse to do clutch/transmission work without removing the engine. I have a small garage though.
+1
I recently built a big garage, and my house has a 2 car garage attached to it. I have plenty of room, but it still sucks.
When I pull my engine, (which will hopefully be the end of this year hopefully), I am pulling the trans and engine in 1 piece. F that laying under it and seperating them crap.
Old Jun 7, 2012 | 02:48 AM
  #2930
skullzaflare's Avatar
Ya.
i offered my help, and texted you but never got a reply
Old Jun 7, 2012 | 09:31 AM
  #2931
miata2fast's Avatar
Total Cats: 175
I have to give you a prop on that. That ---- was funny, and I have been there.
Old Jun 7, 2012 | 07:13 PM
  #2932
Faeflora's Avatar
Total Cats: 130
Pics.
Thank you Sean.
Attached Thumbnails Faelflora breaks his promise, time to part out car. GIT THE SAWZALL!-fe3oe.jpg   Faelflora breaks his promise, time to part out car. GIT THE SAWZALL!-abrc1.jpg
Old Jun 7, 2012 | 07:19 PM
  #2933
what was the dealio?
Old Jun 7, 2012 | 07:26 PM
  #2934
soviet's Avatar
Total Cats: 269
I'm guessing the solution was simple - daylight.
Old Jun 7, 2012 | 07:27 PM
  #2935
Sean is a man
Old Jun 7, 2012 | 07:32 PM
  #2936
triple88a's Avatar
Total Cats: 1,830
U mean not drinking before working on it?
Old Jun 7, 2012 | 07:38 PM
  #2937
Faeflora's Avatar
Total Cats: 130
This. I am the worst mechanic in the world.
Old Jun 7, 2012 | 07:40 PM
  #2938
Faeflora's Avatar
Total Cats: 130
Let's see how many hours it takes me to put new trans in. Bets? My bet is 85.
Old Jun 7, 2012 | 07:42 PM
  #2939
did you really leave the starter bolts in???
A new record has been set gentlemen
Old Jun 7, 2012 | 09:43 PM
  #2940
bikersam717's Avatar
Total Cats: 74
Leave them out on install for easier removal when you realize you've fckd something else?
