Where to get a fancy oil feed like this one?
Old Jul 1, 2012 | 04:11 PM
fwMiata's Avatar
Aluminum oil hardline is an engine fire waiting to happen. BTDT. Tried it on my coolant lines and it constantly leaked and cracked. Hard aluminum line has no place in a car.
SS hardline is an enormous bitch to work with. You need a $100 bender and a $250 flare tool to do anything with it, and they will still be more susceptible to vibration failure than a SS braided line wrapped in Thermosleeve.
I wouldn't cantilever a braided SS hose off of a -4AN tube nut and some 1/4" steel hose while expecting those same parts to contain ~60psi of oil pressure at all times, but that's just me.
This alum is rated for a working pressure of 1500PSI...
Attached Thumbnails Where to get a fancy oil feed like this one?-funny-pictures-you-jealous-tails.jpg
Old Jul 1, 2012 | 07:45 PM
Total Cats: 1,415
He said nothing about it being bad due to running excessive pressure.
Old Jul 1, 2012 | 07:46 PM
Thanks, I'll stick with 90* steel swivels on my car then.
Old Jul 5, 2012 | 08:56 AM
Rallas's Avatar
Total Cats: 36
I have been debating on running Alu hard lines for my oil cooler when it goes in, at least part of the way. I have been wondering how well it would hold up to vibration and other conditions in the engine compartment. Working on helicopters while in the army, we had several places that had aluminum lines, I know we had several locations with Alu fuel lines. I wan't to say even some of the smaller (<3/8") hydraulic lines were Alu, not 100% sure though. All the AC lines on your car are ALU and run at much higher pressures with gas in it. If properly installed I am sure it could work.
I would want the lines 100% supported with little to no additional weight hanging off at the fittings. If the line is going to fail it will be at the fitting end or where tight bends are made. Make sure it is fully annealed Alu if you are doing any bending. The temperatures that a soft aluminum tube will encounter taht close to a trubo might cause some issues too.
I was planning on making the oil feed line out of SS or at least carbon steel 3/16 brake line. I used to work with a lot of SS tubing and can tell you that a nice bender is needed and it is very hard to correctly flare SS. I mostly dealt with 45 deg flares on stainless, 37 deg flares might be a little easier to do. Also 304 SS would be easier to flare and bend than 316 SS.
If you can find the correct tubing adapters to attach to the tube ends and match your turbo fittings, that would be the way to go with SS. I did a nice SS hardline oil cooler setup for my brother's FFR roadster and it works/looks great, will never have to worry about leaks or failures. I worked at Swagelok at the time and had access to free fittings though. If you can find what you need, it will more than likely cost $15-20 for proper SS tube adapters. Compared to the cost of 90* swivels it might not be that bad.
Old Jul 5, 2012 | 10:43 AM
Well, this thread went to total ---- fast.
Old Jul 5, 2012 | 11:55 AM
StarletRick's Avatar
in for Nitrodann explaining if/how he has his oil feed in the head.
Old Jul 5, 2012 | 11:57 AM
I've no idea how this thread is off topic when OP is about a feed line and discussion is about feed lines
+1
Old Jul 6, 2012 | 09:41 AM
skidude's Avatar
Total Cats: 19
I support thread drift to nitrodann's feed location.
Old Jul 6, 2012 | 05:14 PM
baron340's Avatar
Total Cats: 13
There is an oil galley plug right there. It's where the casting was machined for the lifter oil feed.
Old Jul 10, 2012 | 05:35 AM
moar pics?
Old Jul 10, 2012 | 06:06 AM
nitrodann's Avatar
Total Cats: 66
And some bonus photos just for good measure.
blah blah, hektik welds, etc
Cheers,
Dann
Attached Thumbnails Where to get a fancy oil feed like this one?-img2007f.jpg   Where to get a fancy oil feed like this one?-img2010f.jpg   Where to get a fancy oil feed like this one?-img2011l.jpg   Where to get a fancy oil feed like this one?-img2012mu.jpg   Where to get a fancy oil feed like this one?-img2013tv.jpg
Where to get a fancy oil feed like this one?-img2122j.jpg   Where to get a fancy oil feed like this one?-img2020ip.jpg   Where to get a fancy oil feed like this one?-img2017q.jpg   Where to get a fancy oil feed like this one?-img2091ia.jpg   Where to get a fancy oil feed like this one?-img2339s.jpg
Where to get a fancy oil feed like this one?-img2388n.jpg   Where to get a fancy oil feed like this one?-img2449xfqm.jpg
Old Jul 10, 2012 | 06:24 AM
what thread size is that adapter? I am going to use this location for turbo sexiness on my new engine.
you are my new favorite guy called Dan.
Old Jul 10, 2012 | 07:06 AM
nitrodann's Avatar
Total Cats: 66
No idea haha.
but take the threaded plug out and show your brake guy and he will give you an adaptor to fit the standard brake line fitting to the head.
Dann
Old Jul 10, 2012 | 07:29 AM
Well if its a fitting a brake guy normally has that narrows it down a bunch. In that size its either 1/8npt, 8 or 10mm straight thread for a banjo fitting (I dont see a sealing washer so unlikely), or... Well thats all I can think of for fittings a brake guy would have on hand to match to 6 or 8mm flare. Maybe Maybe 1/8 British pipe thread, but thats a long shot.
Old Jul 10, 2012 | 08:33 AM
m2cupcar's Avatar
Total Cats: 372
I wonder if pulling oil from the galley that feeds the cam journals is a bad idea.
Old Jul 10, 2012 | 09:51 AM
would it be enough to worry about?
most people run a restrictor on the turbo feed, so the volume of oil passing though wouldn't be detrimental would it?
Old Jul 10, 2012 | 02:00 PM
baron340's Avatar
Total Cats: 13
I'd just like to point out that if you have a CAS on the exhaust side that galley plug is going to be a PITA to use. Maybe some fancy slim banjo might work, but it's close either way.
Old Jul 10, 2012 | 02:21 PM
Joe Perez's Avatar
Boost Pope
Total Cats: 7,548
The thing which concerns me is that the oil supply from the block into the head already passes through a fairly narrow restrictor, which is pressed into the block just below the deck surface:
While a journal-bearing turbocharger (or a ball-bearing turbo with a restrictor) should not be consuming a lot of oil relative to the normal flow of the lower engine, I'd still be concerned about upsetting the balance of oil pressure within the head by drawing oil out of it to feed to any external device.
Attached Thumbnails Where to get a fancy oil feed like this one?-f_cyht_53c_u77ts.jpg
Old Jul 11, 2012 | 08:49 AM
m2cupcar's Avatar
Total Cats: 372
Agreed^ and a diagram to further illustrate the point. Considering there is a restrictor in place from the factory, I can only assume that it is critical in determining the flow of oil to the head and using that as source post restrictor may change things.
Attached Thumbnails Where to get a fancy oil feed like this one?-enginelube.jpg
Old Jul 11, 2012 | 09:27 AM
Isn't that just for the HLA's? I don't think its on the newer engines.
I've seen/read a few of the spec guys actually open this restrictor up to get a bit more oil into the head...
