Electronics Section about electronics, connectors, and wiring
Connector Witch Hunt
Old Mar 4, 2013 | 05:34 PM
  #101
AbeFM's Avatar
Total Cats: 13
Wow. Really getting there.
There's another which springs to mind (no just because I bought a new fuel pump like ten minutes ago).... The fuel pump connector! :-) But, no one has pictures of it unless they have a pulled harness.
Sven, is there anything you can think of I can do to help you find the remaining major plugs? We've almost got the full list and I'd like to see it happen. I really am going to pull all the wires out of the car any minute now...
Old Mar 5, 2013 | 01:51 AM
  #102
Zaphod's Avatar
Total Cats: 106
Hi Abe, work and a little Miata side project have kept me quite busy lately...
Let's see what we are missing:
(We need pictures of that!)
- VSS
- Neutral switch
- Reverse switch
- Clutch switch
- Purge solenoid
- Alternator control
- AC control
- Master cylinder
- Dash plugs
- Fan (I have that - will take pictures)
I suspect some of the are standard spade connectors 6.3mm
I know that the Oil pressure sender is such a connector and have added this to the spreadsheet.
@Leafy - about the IAC and VICS connectors - did you actually try the
IAC:
AMP 184000-1 or did you use the K2BS from Corsa technic? - (because they are different)
VICS:
SUMITOMO 62 sealed series 090(2.3mm) [6098-0135] or did you use the 2P040WP-HX-F? - (again they are different)
Old Mar 5, 2013 | 07:23 AM
  #103
I used the HX for the VICS because it was the best lead we had at the time. And I misread easternbeaver and thought their AMP stuff was the same as the right one but it was from the eco line or something.
Old Mar 5, 2013 | 08:20 AM
  #104
Zaphod's Avatar
Total Cats: 106
O.K. so I can add the removed stuff to the spreadsheet again...
Old Mar 5, 2013 | 08:22 AM
  #105
I thought i only removed the VICS stuff, which I added in the first place.
Old Mar 6, 2013 | 04:04 AM
  #106
Zaphod's Avatar
Total Cats: 106
Fan connector:
Again a totally different type:
It's a SUMITOMO 58 sealed series
Part.-Nr. 6189-2841
Link: SWS Components for Automobiles
Attached Thumbnails Connector Witch Hunt-fan_1.jpg   Connector Witch Hunt-fan_2.jpg   Connector Witch Hunt-fan_3.jpg   Connector Witch Hunt-61892841.jpg
Old Mar 6, 2013 | 05:36 AM
  #107
Zaphod's Avatar
Total Cats: 106
Me again... I did a wee bit of work on the spreadsheet (go figure):
- added a column with connector series names (and filled it)
- added some vendor links (though it seems that most of the connectors are to be found at the Newunitedracetech site)
I am at loss for the Clutch switch connector... have to get some better pictures....
Old Mar 7, 2013 | 10:02 AM
  #108
Zaphod's Avatar
Total Cats: 106
Added some interior connectors to the spreadsheet
Old Mar 7, 2013 | 03:37 PM
  #109
AbeFM's Avatar
Total Cats: 13
MiataConnectorImages - AbeFM's Photos
Ok, uploading, as we speak, more images. Some duplicates. :-(
I got the sensor side of the nuetral switch (I think, not sure which is reverse and which is neutral) - I'll get the harness side next time my car goes up. The plug is the same for the power window motor. :-) And Link used it on their piggyback computer set up at some point.
Couldn't find either the AC or the alternator, which sucks since I thought I had some out.
The clutch switch looks to be very similar to one of the two brake switches (there's one that is a top-of-travel and one that is heavier... I think for turning off cruise control or something?)
I also got a picture of the relay, I think for the fans. Come to think of it, you're more likely to change the signal going to the relay than you are to change the wire from relay to fan.
The secondary (AC?) fan motor has, of course, a different connector, so I got a pic of that one as well.
Lastly, there's the square connector that goes to the coil harness, got both sides of it. It's only four pins (power, ground, coil A coil B I assume).
Lastly, a pic of the oil pressure sender, which, as you said, seems to just be a standard spade connector (as are the pins on all the transmission stuff).
Will edit in pictures later when they upload, or else find them on the last pages here:
Old Mar 8, 2013 | 06:54 AM
  #110
Zaphod's Avatar
Total Cats: 106
My clients won't like me getting up from my work to look after some Miata connectors - but f***'it...
This is a SUMITOMO SL Series Part.-Nr. 6189-0643 female / 6181-0439 male
They grey one -
(we had a similar before)
This is a Sumitomo DL 090(2.3mm) Sealed Series 3 Position Female Housing [Dark Gray] Part.-Nr. 6195-0009 female
Sumitomo DL 090(2.3mm) Sealed Series 3 Position Female Housing [Dark Gray] [6195-0009] : New United Race Tech, New United Race Tech
The black one -
This is a Sumitomo SL sealed series 090(2.3mm) 2 Position Female Housing [Black] Part.-Nr. 6189-0643 female / 6189-0653 male
Sumitomo SL sealed series 090(2.3mm) 2 Position Female Housing [Black] [6189-0653] : New United Race Tech, New United Race Tech
I couldn't find anything for the Black 2 position - spade connector - it should be a YAZAKI as it has something stamped on the front that is usually seen on the YAZAKI connectors.
I have to do some work now...
Attached Thumbnails Connector Witch Hunt-img_5438-m.jpg   Connector Witch Hunt-61890643.jpg   Connector Witch Hunt-61810439.jpg   Connector Witch Hunt-img_5407-m.jpg   Connector Witch Hunt-9555.jpg
Old Mar 8, 2013 | 10:25 AM
  #111
Zaphod's Avatar
Total Cats: 106
Phewww, that didn't let me rest...
Found it:
The black square one - it's a
YAZAKI New 250 Connectors Housing 2P Female Part.-Nr. 7223-5526
YAZAKI Connectors Catalog
Yazaki New 250 Connectors Unsealed 2 Housings [Natural]
The Master cylinder seems to be something like this too...
Greets
Attached Thumbnails Connector Witch Hunt-img_5407-m.jpg   Connector Witch Hunt-7595.jpg
Old Mar 9, 2013 | 03:43 PM
  #112
AbeFM's Avatar
Total Cats: 13
You are a monster. :-)
Ok, got another pic while putting in a noisy fuel pump to replace the perfectly find OEM one. Heh.
Fuel Tank Connector (pump + level sender)
As usual, more pics on my webpage.
Of the three, the grey one doesn't seem to have a protrusion to it? The Sumitomo you show the center sticks out past the end of the connector? Another angle:
though that doesn't show the placement as well as the pic you already posted.
Really had trouble with the metering on that clutch switch
And of course, lastly, the fan motor (again, probably not as important as the relays, why change good wiring?).
And I know I said "lastly" but really, this is the last one:
That's the relay plug, I forget if it's for the headlights or the fans, but if people are rewiring in an aftermarket ECU, that's the pins they will care about.
Attached Thumbnails Connector Witch Hunt-20130308_203409-x2.jpg   Connector Witch Hunt-20130308_203416-x2.jpg   Connector Witch Hunt-img_5406-x2.jpg   Connector Witch Hunt-img_5404-xl.jpg   Connector Witch Hunt-img_5403-xl.jpg
Connector Witch Hunt-img_5400-x2.jpg   Connector Witch Hunt-dscf0283-x2.jpg   Connector Witch Hunt-dscf0286-xl.jpg   Connector Witch Hunt-img_5412-x2.jpg   Connector Witch Hunt-img_5413-x2.jpg
Connector Witch Hunt-img_5415-x2.jpg   Connector Witch Hunt-img_5417-x2.jpg   Connector Witch Hunt-img_5416-x2.jpg
Old Mar 9, 2013 | 05:07 PM
  #113
AbeFM's Avatar
Total Cats: 13
http://www.automotivewiringsystems.c...connectors.htm
Worth checking out?!
Old Mar 9, 2013 | 11:26 PM
  #114
Added another source for the iac connector. I'm seeing if he can source the vics connector since new united doesnt have them and neither does eastern beaver. Ballenger says they have them on their sumitomo list but I cant find it in their store.
Old Mar 10, 2013 | 01:24 AM
  #115
Zaphod's Avatar
Total Cats: 106
@Abe - about the protrusion - that is just a matter of the catalouge picture - because the center part is separate and can be removed. All (or most) of the Sumitomo pictures do look like this.
The fuel pump one is also a Sumitomo SL sealed series.
SUMITOMO SL (old) sealed series Part.-Nr. 6189-0652
http://swsct.sws.co.jp/components/en..._s=61890643sls
http://www.newunitedracetech.com/sho...01_730_735_736
Old Mar 10, 2013 | 03:59 AM
  #116
cordycord's Avatar
Total Cats: 560
Default main harness
Anyone that finds the part numbers for the big blocky connectors gets a free Catfish t-shirt.
16 pin Tyco? Sumitomo? I dunno, but they are the main connectors between the engine, main, dash and PPF harnesses.
BTW, I have pictures and descriptions of every connector on a 1999 harness, but no part numbers. I'd be happy to upload or send them to whomever is building a list.
Attached Thumbnails Connector Witch Hunt-img_8184.jpg   Connector Witch Hunt-img_8221.jpg   Connector Witch Hunt-img_8226.jpg
Old Mar 10, 2013 | 05:26 AM
  #117
Zaphod's Avatar
Total Cats: 106
@Cordycord - please post pics from the back - (and maybe all sides of the connectors)
Old Mar 10, 2013 | 01:48 PM
  #118
cordycord's Avatar
Total Cats: 560
Default Connector pictures
Unfortunately I only have reference pictures, and all are wired on the harness--correct pictures from the back of the plug may not be of use because the wires obstruct the view.
However, if you're looking at a plug and wonder what it does, I've got that covered.
Old Mar 10, 2013 | 03:54 PM
  #119
AbeFM's Avatar
Total Cats: 13
Cordy,
Perhaps when I do my rewire, I'll come across some of those plugs and can get more pics for Sven.
If you have more pics I can give you a place to upload them - the issue is then going through an entering in the descriptions one at a time...
Old Mar 10, 2013 | 03:56 PM
  #120
AbeFM's Avatar
Total Cats: 13
Sven,
So, we know enough about most of these to know the series? I'm getting my wire sometime next week, and want to just amass a list of pin types so I can repin everything. Then I don't actually need to purchase connectors since, aside from the fan connector, they are all in great shape.
