ZX-Tex's Megahellastylin' Part Out Phase 1
Old Nov 5, 2010 | 08:03 PM
ZX-Tex's Avatar
Default ZX-Tex's Megahellastylin' Part Out Phase 1
UPDATED WITH INDIVIDUAL PRICING
More parts here
I am parting out just about my entire NB Miata build. Long story short I had to get something with a back seat and cannot justify keeping two Miatas (the other one is a track car). I'll be selling some very nice, very low mileage parts over the next few weeks.
Garrett GT2871 ball bearing turbo
- Sourced from ATP Turbo through BEGI.
- ATP ported anti-surge housing
- 0.64 A/R turbine housing,
- BEGI ported wastegate, NO BOOST CREEP even at 21+ psi
- Upgraded 12 psi wastegate actuator
- Very recent CHRA rebuild. Turbo is practically new, maybe 2000 miles.
- Wastegate actuator mounting bracket custom-made by Corky himself.
- I am also including $60 worth of silicone reducer elbows. You will want them since it has a huge 4" compressor inlet. See the pictures below.
- The adapter fittings for all four lines are also included as shown.
- $1350 new from ATP Turbo, not including the fittings and the reducer elbows.
$950 plus shipping
Braided stainless steel water and oil lines
Sourced from BEGI. Includes mounting bracket for the connection points. Aluminum AN fittings. Also includes the fitting for the drain pan. These are sized for an S4 style turbo mount which is lower in the engine compartment than the normal cast manifold location. Everything should work fine in a different location with the possible exception of the oil drain line.
$165 plus shipping
3" Enthuza Full Exhaust
- Full stainless, all mandrel bends and TIG welded, very high quality system
- High flow catalytic converter
- Magnaflow straight-through muffler
- Flex pipe
- Bung in stock location for rear O2 sensor
- Fits on stock hangers on a NB, NA may require some hanger mods, not sure
- 3" V-band connection on the down pipe end. The stock flange is too restrictive for this exhaust.
- In very good condition. It is almost a shame to hide something this beautiful under a car.
$550 plus shipping
Bosch EV14 1100 CC Injectors
- Sourced from Fuel Injector Clinic
- High impedance a.k.a. saturated
- These are the best 1100cc injectors you can get, period. Very fast response. They will idle at 14:1 AFR (gas) better than my 550cc RX7 injectors did. Hard to believe but it is true. Well worth the extra money over some other injectors.
- Plug and play. They fit the stock fuel rail, and come with harness adapter plugs.
- These are good for 700 BHP at 63 psi rail pressure on gasoline and 450 BHP on E85. The last injectors you will ever need.
$360 plus shipping
Reasonable offers considered. I am not desperate for cash so keep your lowballs to yourself.
No dibs. PM me for my paypal address. My local Miata peeps and others here will vouch for me so buy with confidence. Shipping for most items will be $20-$40. The exhaust will be $50.
Old Nov 5, 2010 | 08:09 PM
OMFG this is a GREAT deal.
Anyone that lowballs you deserves to be banned
Old Nov 5, 2010 | 08:35 PM
If you end up wanting to sell the turbo separately, or if someone is interested in the kit but would prefer a GT2560r instead, hit me up. (my turbo is also from BEGi, low miles no excuses, ceramic coated, and set up for the S4.)
Old Nov 5, 2010 | 08:46 PM
ZX-Tex's Avatar
Pictures:
Turbo showing BEGI S4 with Stage-8 and A286 hardware.
Turbo compressor with anti-surge housing. That is a 4" inlet.
Wastegate porting
Downpipe (before I added the v-band connection)
Old Nov 5, 2010 | 08:50 PM
ZX-Tex's Avatar
Thanks, yes it is. I could ask a lot more. This is good stuff. I cannot believe I am parting out this car after all the time I spent on it, but there it is.
More to come, including a fresh low miles built motor, and a T-II Torsen with 3.63:1 gears (gears bought new, pro installed) and polyurethane mounts already installed.
Old Nov 5, 2010 | 10:39 PM
RavynX's Avatar
Mad props to ZX-Tex. I've seen his car and work in person and it's well done. If I had the money I would be picking this setup from him. He does quality work and takes care of the people he works with.
Old Nov 5, 2010 | 11:42 PM
lsc224's Avatar
ditto....I have seen this car and it's ashame he's parting it out. Nothing is spared in his build, all quality parts. If this was 1 1/2 yr ago, I would have bought this turbo kit.
Old Nov 5, 2010 | 11:43 PM
buffon01's Avatar
Total Cats: 13
************ that's cheap. How much for the snail alone?
Old Nov 6, 2010 | 01:21 AM
oldgrayfrog's Avatar
If he were parting it, which he specifically said he was not, 2871 are normally in the $900-1200 range. The price for what he is selling is really a very good deal. It's like getting the 3" Enthuza exhaust for free! (That's about $900 alone) GLWS of a very nice turbo setup.
Old Nov 6, 2010 | 01:33 AM
Faeflora's Avatar
Total Cats: 130
Wtf. The price. So low. So charitable.
Old Nov 6, 2010 | 01:48 AM
Bryce's Avatar
Total Cats: 35
Why couldn't you do this a year ago?
Old Nov 6, 2010 | 01:51 AM
buffon01's Avatar
Total Cats: 13
Oh **** I didn't read the post to be honest. I skipped right to the price.
Old Nov 6, 2010 | 08:39 AM
dvcn's Avatar
Total Cats: 18
It's sad to see such a nicely built car get parted. ZX-Tex's parts are pristine and he is a first class seller.
(and I'm not kissing *** just to get a good deal on some parts off of the car )
Old Nov 6, 2010 | 09:48 AM
Pitlab77's Avatar
because thats when you stole the roll bar out from under me j/k.
GREAT price.
Any wheels or a bar that you might be selling from the car?
Old Nov 6, 2010 | 12:45 PM
ZX-Tex's Avatar
Roll bar is already spoken for by a local sale. Door bars are going in the other Miata. Wheels I am keeping for the roller which I will be selling as well.
To respond to some of the PMs. I am selling this as a package deal for a low price to reduce my time and hassle factor. If I break it up into components the sum price for all will be more than what I am selling the package for.
Old Nov 6, 2010 | 12:59 PM
aznDragonX's Avatar
Wanna part out Tial Q BOV? If so, how much you want for it? Also what's the spring rate for BOV?
Old Nov 6, 2010 | 01:33 PM
chance91's Avatar
Someone should buy this meow. Jesus, less than I paid for my FM2 3071 and better power. I'd do it now if I wasn't needlessly worried about weld el manifolds for some reason. **** the exhaust alone is About a grand.
Old Nov 6, 2010 | 09:20 PM
ZX-Tex's Avatar
FYI I will sell the injectors separately for $390 plus shipping. They are worth $480 new and are in excellent condition.
Tial-Q will be going up for sale soon. It will be $210 with a nice stainless steel adapter tee.
Old Nov 9, 2010 | 07:35 AM
dvcn's Avatar
Total Cats: 18
Any more parts for sale?
Old Nov 10, 2010 | 03:31 PM
snakeeyes's Avatar
ZX's stuff is top-drawer; his water injection setup damned near brought me to tears, it was so purty. Buy with confidence.
