1990-2005 Miata parts clearance!!! Selling all my parts in my shop
Old Jan 17, 2011 | 12:07 PM
gdnimr0d's Avatar
Default 1990-2005 Miata parts clearance!!! Selling all my parts in my shop
COMPLETE LIST OF ALL PARTS AVAILABLE CLEARING THEM OUT FOR CHEAP
CALL RYAN KAUFMAN AT 754 244 1755
PHOTOS OF MOST PARTS CAN BE FOUND HERE
miata parts pictures by gdnimr0d - Photobucket
Miata parts FS:
99-05
Exterior
-99-00 Silver Passenger door shell -$150
-99-00 Silver Trunk decklid - sold
-x2 Power antennae - $50
Interior
-Bose cd player and tape deck combo -$30
-Right and left manual window regulators (both) - $50
-01-05 Power door locks with wiring harnesses (both) - $50
-99-00 all factory relays - $5 per relay
-99-00 dimmer switch -$5
-99-00 Power mirror controller - $5
-Stereo Surround -$15
-99-00 Gauge cluster -$20
-Gauges cluster hood - $15
Drivetrain
-99-00 Automatic Transmission 30,000 miles on it Mint condition with torque converter and flex plate and flywheel bolts -$400
-99-00 Automatic Driveshaft - $75
-Complete 1.8 Brake caliper set with soft lines 30K miles on them - $125
-99-00 Brake master cylinder and booster and proportion valve -$50
-01-05 Brake master cylinder and booster and proportion valve - $75
-Right and left front spindles with abs sensors -$30 per side
-Right and left rear uprights with abs sensors - $30 per side
-x2 ABS 1.8 Axles (both) - $80
-P/S rack with inner and outer tie rods - $35
-Complete P/S system with pump, all hoses and pressure lines, reservoir, and rack -$100
-99-00 Open differential no housing, individual unit - $30
-Used starter - $40
Engine Parts
-Driver side radiator fan - $45
-x7 crank pulleys with crank trigger wheels - $10
-99-00 Coil Pack - $50
-99-00 Fuel feed rack - sold
-99-00 Vacuum and map sensor rack- sold
-99-00 Automatic Ecu - $50
-x7 Water pump Pulleys - $5 per
-99-00 Throttle body with Idle air control valve, no TPS - $35
-99-00 Pistons -$40
-99-00 Bare block good cylinder walls -$20
-99-00 Oil pan - $30
-99-00 Damaged head complete with camshafts - $100
-99-00 thermostat housing and various other cooling hard tubes and outlets - $5 per
-99-00 Miata 3 inch straight pipe exhaust (was on a turbocharged 99 Miata) - $100
-99-00 Cam gears (Both) - $10
-99-00 Valve cover - $35
-Various A/C hoses - $10 per hose
90-97 Parts
Exterior
-White passenger side mirror - $25
-Passenger headlight mechanism
Interior
-90-93 Black and tan Dash Mint no cracks - $75
-Driver airbags - $5 per
-94-97 Passenger airbag Mint - $40
-Passenger seat black leather custom wrapped no tears or rips - $30
-Passenger seat fabric no tears or rips -$20
-x2 90-93 Gauge clusters -$5 per
-94-97 stereo surround - $15
Engine Parts
-1.6 F1 racing stage 1 lightened flywheel with f1 stage 1 clutch and pressureplate - sold
-1.6 exedy clutch slightly used - $35
-NON-P/S Idler pulley and bracket -$75
-94-97 Vacuum solenoids - $5
-x2 1.6 coil packs - $50 per
-x5 90-97 A/c Radiator fans -$25 per
-1 driver side Radiator fan - $35
-90-93 Crank and water pump V belt pulleys - $15
-90-93 alternator - $20
-Starter - $20
-90-93 Intake tube - $10
-90-93 Throttle body with Idle air control valve and tps sensor - $35
-good used 1.6 head - $25
-1.6 bottom end short nose crank rebuild able -$25
MY EMAIL IS Ryanckaufman@gmail.com
thanks
Old Jan 17, 2011 | 10:42 PM
Milky's Avatar
how many miles on the f1 clutch / lightened flywheel combo? how much shipped to 40026? which clutch is in better shape, the exedy or f1? how many miles on the exedy?
Old Jan 18, 2011 | 10:04 PM
gdnimr0d's Avatar
check your pms milky
thanks
Old Jan 18, 2011 | 11:50 PM
eddy1128's Avatar
I'd like to pick up these:
-99-00 Fuel feed rack - $10
-99-00 Vacuum and map sensor rack- $35
if they are still available. Do you have the charcoal canister too? If so, I need that as well.
Please PM me (I dont have enough posts) and I will reply with address/info. thanks
Old Jan 19, 2011 | 12:11 AM
turotufas's Avatar
More info on the head please. Call dibs as of now! Pending damage report.
Old Jan 19, 2011 | 10:29 AM
gdnimr0d's Avatar
Here is a link to the photos of the damaged head....the bare 99 block...and the 3 inch exhaust straight pipe
http://s224.photobucket.com/albums/dd135/gdnimr0d/
gdnimr0d's Avatar
more pms sent out too
Old Jan 21, 2011 | 11:02 AM
gdnimr0d's Avatar
still available people ....
Old Jan 21, 2011 | 11:08 AM
eddy1128's Avatar
I tried to pm you back and I couldnt, so I sent you an email to the hotmail account you posted in another FS thread
Old Jan 21, 2011 | 01:56 PM
Milky's Avatar
gdnimr0d, please clean our your pm's. i tryed to pm you to get some paypal info, but your box was full..
Old Jan 21, 2011 | 08:18 PM
gdnimr0d's Avatar
its empty now here is my contact email if anything ryanckaufman@gmail.com
Old Jan 23, 2011 | 11:58 PM
Clos561's Avatar
do u have the fuel injector harness for the 99? how much shipped to 33411?
Old Jan 24, 2011 | 03:47 AM
SLVMX5's Avatar
I'll be giving you a call tomorrow.
Old Jan 24, 2011 | 04:07 PM
rallyjiggz's Avatar
Is the dashboard still with you? How much would it cost me if you shipped the black and tan dash to Canadian postal code V8N 4Z8?
Old Jan 25, 2011 | 11:15 AM
gdnimr0d's Avatar
its not worth it to ship a dash like that ...to fragile sorry ....all other sold parts have been shipped
tons of more parts still available
Old Jan 28, 2011 | 06:50 PM
eddy1128's Avatar
Got my stuff today Ryan. Thanks!
Old Jan 28, 2011 | 08:52 PM
Kazan's Avatar
Hi ,
Do you have a thicker than 12 mm rear sway bar ?
Old Jan 28, 2011 | 11:44 PM
gdnimr0d's Avatar
Originally Posted by Kazan
Hi ,
sorry I dont have any rear sway bars
thanks tho
i pmed a couple people i missed before
Old Jan 29, 2011 | 03:39 AM
Techsalvager's Avatar
what year crank pulleys with crank trigger wheel?
interested in it
Old Jan 29, 2011 | 07:38 PM
gdnimr0d's Avatar
all of the crank pulleys and triggers came off 99 -00 miata engines
