What I have left sale...
Old May 14, 2011 | 10:46 PM
JayL's Avatar
Default What I have left sale...
This is pretty much all I have left and I'd like to get rid of it. I'd prefer a local sale on many of these things, but if you're willing to work with me on the shipping costs I'd be more than happy to see what I can do to make the sale happen. If I'm way off on the prices of certain items, please send me a pm to let me know (if things don't sell I'll gradually lower the prices regardless). Help me replace my Miata with a Porsche 968.
Trackspeed Engineering 11" Wilwood 4pot front big brake kit (Wilwood Dynalite calipers, brackets, stainless steel brake lines, centering rings, hardware, rotors (3 track days and less than 500 street miles) and Carbotech pads (XP10, XP8 for the Wilwoods and also an oem set of XP8 pads for the rear, all sets have around 50% life remaining).....SOLD
Mazdaspeed Miata 6 Speed Transmission (decent condition with occasional grinding going into 3rd if I shifted fast after I changed the fluid to try a different brand before I pulled it, trying to give full disclosure so I'm mentioning it)........SOLD
Mazdaspeed Miata Torsen Differential (1.8) (w/MazdaComp Mounts), Axles and Driveshaft (everything needed for a complete Torsen diff swap).......$SOLD
Garage Vary Front Lip (NB2).......$180
ISC Rear top hats (showing wear where the shock shaft goes through the top hat).....SOLD
Red hardtop.......$SOLD
Nardi Personal Trophy 350mm Black Suede/Red Stitching Deep Corn Steering wheel with hub and airbag light eliminator (NB Miata)........$230
99-00 Short Block (unknown condition).......$250
99-00 OEM Exhaust manifold.......$20
01-05 OEM Exhaust manifold (tubular style)......$160
NB Cooling fan.....$20
NB A/C Fan......$20
99-00 Intake Manifold......$75
NB Rear Subframe.....$40
NB Front Sway Bar.....$30
99-00 Valve cover......SOLD
99-00 coil packs with plug wires......$85
Ryoko Rob front and rear tow hooks (black) (NB)......$75
949 Racing 6UL 15x8 Nickel Rims w/Hankook RS2 Tires with 1/3 tread remaining.........$SOLD
Beatrush Front Shock Tower brace........$140
Beatrush Aluminum Belly Pan (NB)......$140
VVT Cylinder head (has supertech valves, titanium springs, titanium retainers) (needs to be rebuilt).......$350
Billet Aluminum Catch Can (2 port with breather)......$50
99-00 Stereo.......$30
99-00 Oil Pan........$75
Old May 15, 2011 | 12:38 AM
yellowihss's Avatar
Pics of catch can.
Old May 15, 2011 | 01:36 AM
DEI liberal femininity
Total Cats: 574
pics of belly pan? also wondering if it's even shippable.
Old May 15, 2011 | 01:51 AM
Twibs415's Avatar
Total Cats: 114
pm for intake mani
Old May 15, 2011 | 10:08 AM
shaddbarr's Avatar
pm sent about thed cylinder head.
Old May 15, 2011 | 10:50 AM
miatamania's Avatar
So much **** I want, so many deals what would be raped with shipping. GLWS.
Old May 15, 2011 | 11:02 AM
JayL's Avatar
The shipping on that thing was crazy, so I will only be doing a local sale.
Originally Posted by Twibs415
pm for intake mani
The manifold that's listed is bare. The vics solenoid will be included, but the nipple is broken off. I do have another complete manifold with everything, but there's a local sale pending. If it falls through I'll be listing is in a few days.
I want the cylinder head to be a local sale so a very thorough inspection can be done by the buyer.
Old May 15, 2011 | 11:22 AM
yellowihss's Avatar
Is the catch can baffled, and what size/kind of fittings are welded on the can.
Old May 15, 2011 | 11:30 AM
JayL's Avatar
The catch can is baffled on the inside. I'm unsure of the exact size fittings that are welded to the can, but currently it has plastic fittings screwed into the holes and the size of the hose that's visible in the pictures is only 5/16". Relatively small compared to what most people seem to want these days.
Old May 15, 2011 | 12:00 PM
yellowihss's Avatar
If you can figure out what size it is, and I can use it I'll buy it.
Old May 15, 2011 | 04:43 PM
Twibs415's Avatar
Total Cats: 114
so is there anyway to fix the broken nipple on the vics actuator?
Old May 15, 2011 | 04:59 PM
JayL's Avatar
You might be able to get away with trying to glue a nipple back on there, but I wouldn't count on that being a permanent fix. Best thing would be to just replace the solenoid.
Old May 15, 2011 | 09:04 PM
skou's Avatar
Total Cats: 21
Is the VICS shutter actuator shown in the photo functional and included? Also looks like some of the bolts are missing from the flange between the two halves of the manifold. Do you still have them and are they included? Are the check valve and hoses under the plenum included?
Old May 15, 2011 | 09:33 PM
JayL's Avatar
I've been incorrect in the terminology that I've been using, what I've been calling the solenoid is actually the actuator. With that being said, the actuator is included, but the nipple is broken off. The solenoid, vacuum chamber and the check valve are not included nor are anything else that bolts to the manifold. I did put the bolts back in the manifold that hold the two halves together. Here's a better picture of the actuator on the manifold and where the nipple broke off. I bought this manifold to use for some testing along time ago.
Old May 15, 2011 | 11:22 PM
Twibs415's Avatar
Total Cats: 114
^thats not even that bad.
Old May 16, 2011 | 09:47 AM
skou's Avatar
Total Cats: 21
Every now and then FM has VICS shutter actuators available for $10 plus shipping in their Salvage section.
Old May 16, 2011 | 10:15 AM
bigx5murf's Avatar
If you were on the east coast, I would've taken the wheel swap offer.
GLWS!
Old May 16, 2011 | 01:14 PM
wayne_curr's Avatar
I'm beginning the process of buttering up the girlfriend to let me buy those wheels. I need 15x8s so bad right now it isn't funny.
Would you be willing to trade for my aftermarket 16's for less than $500 since they're nicer than OEM NB wheels?
Old May 16, 2011 | 03:41 PM
JayL's Avatar
Updated the pricing on certain items.
Old May 16, 2011 | 08:05 PM
boostin11's Avatar
do you have pix of Mazdaspeed Miata Torsen Differential ?
