1990 - 2005 Parts clearance moving sale dirt cheap everything
Old Aug 30, 2011 | 02:18 PM
gdnimr0d's Avatar
Default 1990 - 2005 Parts clearance moving sale dirt cheap everything
Complete list of all my current parts and PHOTOS FOR ALL OF THEM...I don't have anything else other than what is listed here for sale
http://s224.photobucket.com/albums/d...miata%20parts/
Miata parts FS:
99-05
Exterior
-x2 Power antennae - $20 per
-99-05 hood latch - $15
Interior
-99-00 x2 Bose cd player and tape deck combo -$30
-99-00 non bose head unit- $10
-99-00 base model 4 spoke steering wheel airbag - $10
-Nardi steering wheel no airbag - $15
-Right (passenger) and left (driver) manual window regulators (both) - $50
-Right POWER window regulator - $50
-01-05 power window switch Black - $50
-99-00 all factory relays - $5 per relay
-99-00 dimmer switch -$5
-99-00 Power mirror controller - $5
-99-00 Gauge cluster 90,XXX miles -$20
-Gauges cluster hood - $15
-Dash harness for bose sound system with amplifiers - $25
-99-00 electronic ignition connector - $10
-90-05 convertible top latches
-x2 99-05 a/c control unit - $5
-x2 99-05 turn signal and light combination switch - $30
-99-00 automatic shifter selector - $10
-99-00 driver side seat rail - $5
Drivetrain
-99 -00 Shock and spring top hats complete set -$40
-99-00 Automatic Transmission 30,000 miles on it Mint condition with torque converter and flex plate and flywheel bolts -$350
-99-00 Automatic Driveshaft 30,000 miles on it - $50
-1.8 5spd driveshaft with bolts - $75
-Complete 1.8 Brake caliper set with soft lines and brackets- $125
-99-00 Brake master cylinder and booster and proportion valve -$50
-Right and left front spindles with abs sensors -$30 per side
-Right and left rear abs sensors - $5 per
-Complete set of all four front and rear hubs with ARP extended studs in the rear hubs only (see photos) – $100 for complete set
-x2 driver side rear hubs 1 abs and 1 non abs - $25 per
-P/S rack with inner and outer tie rods and resevoir - $25
-Complete P/S system with pump, all hoses and pressure lines, reservoir, and rack -$80
-Complete 99-00 Open diff with housing and r&p - $100
-Remanufactured starter - $40
Engine Parts
-ARP 1.8 main studs- $40
-99-00 complete intake system (box, snorkel, and tube) -$25
-01-05 complete head with 40K on it perfect condition with intake manifold - $400
-99-00 head good needs to be decked was overheated - $250 photos available upon email
-99-05 brand new radiator -$30
-x2 99-00 fuel injector harnesses - $5 per
-99-00 complete engine harness - $40
-Driver side radiator fan - $35
-99-00 Fuel pump assembly with fuel level sender and pump complete - $50
-x3 crank pulleys with crank trigger wheels - $10
-99-00 Vacuum and map sensor rack- $35
-x3 Water pump Pulleys - $5 per
-99-00 thermostat housing and various other cooling hard tubes and outlets - $5 per
-99-00 Miata 3 inch straight pipe exhaust (was on a turbocharged 99 Miata) - $50
-x 4 99-00 Cam gears (Both) - $10
-X2 99-00 Valve cover - $25
-x2 99-00 Alternators - $25
-Various A/C hoses - $5 per hose
-99-05 A/C compressor - $40
-x2 99-00 complete a/c lines with condenser - $40
-99-05 Fuel feed line quick disconnect factory - $5
-99-05 throttle body with tps sensor (No IAC) - $35
MAZDASPEED 04-05 Vacuum solenoid rack and MAP sensor - $15
99-05 vacuum solenoid rack and map sensor - $10
99-05 fuel distribution block with short quick disconnect hose - $5
1.8 Timing belt and cam gear covers and timing plate- $5
90-97 Parts
Interior
-Passenger seat black leather custom wrapped no tears or rips - $15
-Passenger seat fabric no tears or rips -$10
-90-93 dash harness -$5
-x2 90-93 turn signal and light combination switch - $10
-x2 90-97 A/c controls -$5
-90-93 automatic shift selector - $5
Engine Parts
-94-97 a/c condenser - $15
-90-93 fuel injector harness - $5
-94-97 fuel pump assembly with fuel level sender (NO PUMP) - $10
-94-97 Vacuum solenoids - $5
-1.6 90-93 vacuum solenoid - $5
-90-93 CAS - $40
-90-93 5 spd TPS sensor - $5
- 1.6 coil packs - $50
-1 driver side Radiator fan - $35
-90-93 Crank and water pump V belt pulleys - $10
-90-93 Valve cover -$10
-90-93 alternator - $20
-90-97 Starter - $20
-x2 90-97 power steering pump - $20
ALL PHOTOS OF EVERY PART ARE HERE
Call me at 754 244 1755 or email me at ryanckaufman@gmail.com
thanks
Ryan K
Old Aug 30, 2011 | 07:52 PM
matthewdesigns's Avatar
Total Cats: 55
Emailed re: 90-93 valve cover
Old Aug 30, 2011 | 08:16 PM
94mx5red's Avatar
Ryan, do you have any pics of the leather passenger seat? I did not see any on photobucket.
Old Aug 30, 2011 | 09:27 PM
gdnimr0d's Avatar
yeah i will get some posted up tomorrow
thanks
Old Aug 31, 2011 | 06:11 PM
bobbiemartin's Avatar
Please send me a PM or email on the 99-00 valve cover
Old Aug 31, 2011 | 06:35 PM
gdnimr0d's Avatar
90-93 valve cover sold
everyone has been pmed
Old Aug 31, 2011 | 07:05 PM
phillyb's Avatar
Total Cats: 9
have na6 gauge cluster hood?
Old Aug 31, 2011 | 10:34 PM
Camaro67racer's Avatar
Interested in hubs. Email sent.
Old Sep 1, 2011 | 11:29 AM
gdnimr0d's Avatar
I ONLY HAVE WHAT IS LISTED ON THIS AD
thanks
Old Sep 1, 2011 | 08:37 PM
gdnimr0d's Avatar
convertible top latch sold
1 99 valve cover sold
ARP main studs sold
1 99-00 bose head unit and deck combo sold
94-97 a/c condenser sold
Old Sep 2, 2011 | 08:16 PM
Simonvkasteren's Avatar
What about: -90-05 convertible top latches
Do you have any pics, you can send it to: simon_v_kasteren@live.nl
Old Sep 3, 2011 | 04:51 PM
gdnimr0d's Avatar
the convertible top latch set has been sold...I offer a welding repair and repaint of the latch locking mechanism for $30 dollars and you pay shipping.. let me know if you are interested thanks
Ryan K
Old Sep 5, 2011 | 06:10 PM
Pitlab77's Avatar
do you have the 99 a/c fan and fan shroud?
Old Sep 6, 2011 | 04:14 PM
Total Cats: 55
VC received today in good condition. Thanks for getting it out so quickly!
Old Sep 6, 2011 | 06:53 PM
josedacz1's Avatar
he just wondering if the valve cover and cluster for 2000 are stil available and do you have a coil pack for a 2000 too
Old Sep 6, 2011 | 08:19 PM
gdnimr0d's Avatar
no coil pack but i do have a valve cover and gauge cluster with 90k on it...call me if anything 754 244 1755
thanks
Ryan K
Old Sep 7, 2011 | 01:11 AM
josey_gt's Avatar
Pm'ing..
Old Sep 7, 2011 | 10:24 PM
gdnimr0d's Avatar
i will be out of town from tomorrow until monday so please be patient with responses thanks
Old Sep 13, 2011 | 08:35 PM
gdnimr0d's Avatar
i am back in town and ready for shipping so get at me folks!
Old Sep 14, 2011 | 06:52 AM
Ryan K
So this means, after the welding repair the latch locking mechanism will work flaweless again ?
i need these:
http://www.twiga-used-parts.com/medi...8a067ed0_m.JPG
Simon
