Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.
Old Feb 13, 2013 | 07:33 PM
Fireindc's Avatar
Total Cats: 915
Default Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.
ALL ITEMS ARE LOCATED IN Taos, NM (87529)
First I have a 2.5" straight exhaust made by enthuza. this is for an NA, and was on my 90' $180.00 + shipping OBO.
I bought this from "mikeriv87" several years ago, ran it on my car for maybe 2k miles, and ended up going with another quieter exhaust. This exhaust IS loud, no muffler, resonator, etc - just a straight pipe. Here is what Mike said about this exhaust in the thread I bought it from.
"This exhaust is a custom piece I had Enthuza make for me. It is directly based off their Turbo Exhaust systems except with no mufflers at all. Just a straight pipe all the way to the passenger side exit. 2.5" Mandrel Bent Piping. Had it on my car for about 2 months tops and used it for track days. Exhaust is still in great shape. "
Buy it and weld on a muffler to save big bucks on an exhaust
Run it as is, but beware it will be loud
It's in good condition, not the prettiest and has a spot where it was rubbing on my car (didn't rub through or anything), and it has a small dent in it - but nothing big enough to impede flow.
Not the cleanest, but not rusty or anything.
Here you can see where it was rubbing (due to my downpipe ill fitment), but did not rub through.
Small dent, i highly doubt this would impede flow in any way.
Flange
Next I have some 550cc "red top" rx7 injectors. $100.00 OBO + shipping
I ran these on my car for a few years. These are 100% plug and play. I made 240whp with these injectors. You may want to clean them, but they were pulled from my 1.6 setup that was running fine when i yanked it.
Will probably at least need some o rings where they seat to the fuel rail.
Next up is a alternator from a 99 miata. $40 + shipping
This was pulled from the 99 motor i'm putting in my car. The motor has 140k on it, i have no idea if this was original or not - but i DO know it worked. I cannot use this alternator, as on the 99-00 cars the alternator is regulated by the ECU, and my NA is not.
Next I have a 99 coil pack from the same motor. $50 + shipping
Same thing goes with the coilpack. Was working on the motor when I pulled it, no idea of the actual mileage of this unit.
A/C compressor off of 99 motor. $50 + shipping
A/C compressor bracket from 99 motor. $20 + shipping
OEM 99 header/cat/downpipe/heatsheilds/o2 sensors. $100.00 + shipping
NA softop frame with softtop on it from my 1990. $150.00 + shipping
Soft top is in okay condition (not good by any means, but doesn't leak and looks okay), window is complete trash. Frame itself is in great condition and comes with forward latches. I can pull the soft top off if you'd rather have just the frame. Pricing is for the frame only, but you can have the top for free if interested.
AC stuff from my 90' -$100.00 + shipping.
Had a slow leak when i pulled it, but worked fine. Comes with what you see here.
1.8 miata oil pan - $40.00 + shipping.
No dings or anything.
1.8 windage trey + oil pickup tube. Good condition. 35.00 + shipping
1.6 Miata ECU. $40.00 + shipping.
Worked great, pulled it when i went MS.
450cc, low impedance, DSM injectors + pigtails $80.00 + shipping
NOT plug and play, but can be made to work. Research this yourself.
OEM 1.6 injectors. $20.00 + shipping.
Obviously needs pental caps and o rings.
99 miata crank angle sensor and pigtail. $20.00
worked fine when pulled.
That is it for now, I'll have more to add as i dig through my garage. Let me know if you see anything you want and think the price is unfair.
Thanks!
Attached Thumbnails Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-9ionmln.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-2dnfd8u.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-eugeqqf.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-2yy9cof.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-eqn77re.jpg
Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-kbukdpv.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-z50yohf.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-6snevhb.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-h6fxv2h.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-ju3jl2e.jpg
Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-x3hj8c9.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-7esmwkn.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-xkjmuaj.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-aepogca.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-rosihig.jpg
Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-ejof5jv.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-rxmjfpe.jpg   Garage clean out! 2.5" straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-yyyctbn.jpg
Old Feb 14, 2013 | 12:44 AM
bombton_roadster's Avatar
pm sent
Old Feb 14, 2013 | 02:28 AM
boedhiman's Avatar
Total Cats: -2
Interested on your exhaust, sending pm...
Old Feb 14, 2013 | 02:07 PM
Fireindc's Avatar
Total Cats: 915
PM's replied.
Old Mar 4, 2013 | 08:51 PM
jfsmiata's Avatar
Interested in the 550cc "red top" rx7 injectors, please email me at
<jfsmiata@gmail.com>
Old Mar 6, 2013 | 09:29 AM
MX5RACER's Avatar
Total Cats: 9
Is the exhaust still for sale?
Old Mar 6, 2013 | 12:03 PM
heyitznosaj's Avatar
Total Cats: -2
Ill take those rx7 injectors if you still have them. Shoot me a pm with your Paypal and price shipped to 02171.
Old Mar 6, 2013 | 12:09 PM
Fireindc's Avatar
Total Cats: 915
Exhaust is still available, let me box it and get a shipping quote for someone else who inquired about it, then you are next on the list mx5racer.
550's are sold, sorry - let me update the ad.
Old Mar 6, 2013 | 05:03 PM
BoostedSmurf's Avatar
Total Cats: 65
Thanks for the injectors, picked them up a few days ago from the post office. A+ seller, had them shipped out the next morning after payment was sent.
Old Mar 6, 2013 | 05:41 PM
Fireindc's Avatar
Total Cats: 915
Thanks Paul, you were great doing business with.
Old Mar 7, 2013 | 12:42 AM
skyfox2003's Avatar
how about that exhaust still available?
Old Mar 21, 2013 | 11:35 AM
codex's Avatar
Interested in the exhaust, if it's still available.
Old Mar 21, 2013 | 02:07 PM
Fireindc's Avatar
Total Cats: 915
2nd in line
3rd in line
4th in line
I'm sure it will go to one of you guys, I've since cleaned it up and packaged it. PM me for a shipping quote, I can tell you it will be somewhere in-between $65-$75 for shipping depending on where it goes though. Here are some pics I took when after i cleaned it up a bit and packaged it.
Cleaned and ready to ship:
Wrapped up:
Madd custom box, yo.:
I'll get back to you guys who showed me interest, or will udpate this thread as sold once it is. Thanks again for your interest guys.
Attached Thumbnails Garage clean out! 2.5&quot; straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-iuoxwvz.jpg   Garage clean out! 2.5&quot; straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-hfpv6mh.jpg   Garage clean out! 2.5&quot; straight exhaust, 550cc rx7 inj, 99 alternator, AC stuff, etc.-se5xe6n.jpg
Old Mar 27, 2013 | 04:10 PM
Fireindc's Avatar
Total Cats: 915
BUMP. Still have everything but the 550's.
Mods: why can't I edit this thread? Am i retarded?
Old Mar 28, 2013 | 12:16 PM
codex's Avatar
I'm still interested in the exhaust. I cannot reply to PMs because my post count is too low. Send me a PM with your email address and I'll send you one back.
Old Mar 28, 2013 | 12:25 PM
Fireindc's Avatar
Total Cats: 915
PM'd
Old Mar 29, 2013 | 03:33 PM
ciacciojon's Avatar
Total Cats: -5
I'm in the same boat. Can you PM me with your email?
Old Apr 1, 2013 | 06:38 PM
Fireindc's Avatar
Total Cats: 915
Lots of interest on the exhaust, but nobody has sent payment yet. This will be sold to whoever comes up with the money first. PM me with your zip code for a shipping quote.
ALSO, bump, I have a 90-93 alternator($35+ shipping) for sale now as well as a 94-97 valve cover (40+ shipping).
Old Apr 3, 2013 | 01:22 AM
Noxiousb4c's Avatar
Total Cats: -2
Message count too low I'll take a quote on the exhaust though if you pm me
Old Apr 3, 2013 | 02:13 AM
Fireindc's Avatar
Total Cats: 915
Give me a zip code and I'll get you a quote.
