FS: BNIB FM Wiseco 9:1 pistons for 1.6L
Old Mar 26, 2013 | 06:49 PM
psyber_0ptix's Avatar
Total Cats: 544
Default FS: BNIB FM Wiseco 9:1 pistons for 1.6L
Hey all, I JUST picked these up off a member but was able to land a 1.8 block and crank locally for quite cheap which is changing my entire build.
These are brand spanking new. Never installed. Comes with pistons, rings, wrist pins and corresponding retaining clips
Flyin' Miata : Engine/Drivetrain : Internals : Wiseco forged turbo pistons
$700 shipped (msrp $796)
Attached Thumbnails FS: BNIB FM Wiseco 9:1 pistons for 1.6L-img_2890.jpg   FS: BNIB FM Wiseco 9:1 pistons for 1.6L-img_2891.jpg
Old Mar 26, 2013 | 07:08 PM
illiasfyntanidis's Avatar
Ain't too much bucks,for just the pistons only?
Old Mar 26, 2013 | 11:49 PM
Total Cats: 544
these aren't the normal wiseco drop in pistons...
Old Mar 27, 2013 | 12:16 AM
x808drifter's Avatar
So I'm assuming it's just like those and include the pins and rings also.
Old Mar 27, 2013 | 12:28 AM
Total Cats: 544
These ARE the Wiseco pistons made to Flyin' Miatas specifications.
Not the normal Wiseco off the shelf pistons for Miatas.
Wiseco pistons are widely recognized as some of the finest performance pistons in the world - and they make these exclusively for Flyin` Miata! These are not the same Wisecos you`ll find elsewhere, but are stronger and quieter thanks to years of gradual refinements. We even use higher quality rings for better sealing.
Forged from high-strength 2618 alloy to deal with the abuse of a high-boost motor, these were recently reworked with a strutted design for massive strength. They`re probably going to be the strongest thing in your motor - this is a 1200 hp slug. The profile of the piston is also designed to minimize piston rock, making them much quieter than most forged pistons.
The skirts are given a moly coating for low friction, and there`s a ceramic coating on top of the piston to protect it from the heat of high power. This keeps the heat in the combustion chamber where it makes horses, not in the oil where it makes the baby dinosaurs cry. We also designed them to run without the factory oil squirters, which gives higher oil pressure, lower oil consumption and higher power levels due to a drop in pumping losses.
Perfect for extreme use, such as high boost operation. Use with our Carrillo rods for a bulletproof bottom end. This combination weighs 1/4 lb per cylinder less than stock. Pistons available in 1mm overbore with 9:1 compression ratio for turbo applications. Includes rings and tapered tool steel wrist pins. Sold in sets of four. We can build an engine to your own specifications if you`d like.
Old Mar 27, 2013 | 01:55 AM
vitamin808's Avatar
ooooo good stuff
Old Mar 27, 2013 | 07:52 AM
Total Cats: 544
Save $80!
Old Mar 31, 2013 | 03:47 PM
Total Cats: 544
bump
Old Mar 31, 2013 | 09:23 PM
Sokool's Avatar
Bore size?
Nevermind I see they are offered in only 1mm overbore.
Old Apr 1, 2013 | 06:19 PM
Total Cats: 544
Originally Posted by Sokool
Bore size?
What spec were you looking for?
Old Apr 3, 2013 | 11:16 PM
Total Cats: 544
Old Apr 7, 2013 | 11:29 AM
Total Cats: 544
brandy new; spice up your 1.6L
Old Apr 10, 2013 | 01:06 PM
Total Cats: 544
Price dropped; save nearly $100!
Old Apr 26, 2013 | 01:28 AM
Total Cats: 544
please buy this!
Old May 1, 2013 | 11:23 AM
Total Cats: 544
bump
Old May 11, 2013 | 08:14 PM
Total Cats: 544
bump!
$650 shipped, otherwise it looks like I'll be building a spare 1.6L block.
Attached Thumbnails FS: BNIB FM Wiseco 9:1 pistons for 1.6L-img_9798.jpg
Old May 29, 2013 | 06:43 PM
Total Cats: 544
ttt
Old May 30, 2013 | 02:57 PM
SmokinS4's Avatar
Default Still for sale ?
Originally Posted by psyber_0ptix
bump!
Still available?
Old May 30, 2013 | 06:38 PM
Total Cats: 544
Originally Posted by SmokinS4
Still available?
Yup! boxed up and waiting for a buyer
Old Jun 9, 2013 | 10:52 AM
Total Cats: 544
pew pew
