Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!
Old Oct 31, 2013 | 10:19 PM
frostyllama's Avatar
Total Cats: -2
Default Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!
Phone: 530-303-8305
Email: frostyllama@gmail.com
texts and emails preferred
Most of the parts are off of a 90 NA
I cover Paypal transaction Fees!
probably won't ship the "big stuff"
Easy to read list more info below
Big stuff:
Hardtop 750$
Complete 4.1 Torsen Swap 550$
LNC 1.6 engine 275$
Exhaust DP to Muffler 200$
Stock daisy wheels 25$
Lights:
Rears: 25$ each (some light cracks didn't notice leaks)
Rear Lid light: 20$
License plate lights: 15$ set
Electronics:
Gauge cluster 253k odo 30$
fuel pump assembly w/ fuel pump: 45$
Maf w/ box: 35$
fans: 20$ each
Way more down bot ask for pricing
Accessories:
Master brake cylinder: 20$
Power brake booster, 35$
Power steering pump: 25$
Cruise control unit: 25$
charcoal canister: 15$
reservoirs: 10$
Brakes:
FULL set SS lines, Brakes and Clutch 90$ shipped
Speed bleeders external valve: 25$ set
1.8 Brackets full set 60$ shipped
1.6 brackets full set 30$ shipped
1.6 front Calipers 20$ each 35$ set
1.6 rear calipers 25$ each 40$ set
Rear hub assemblies (new studs seals bearings): 65$ set
Axxis ultimates 500 miles: 15$ full set
E brake cables 15$ set
Interior:
tombstone: 35$ screw port on left side cracked off little bent on left, you can see it in the picture
Rearview mirror: 10$
kind of musty visors: 5$ set
eyeball vents: 5$ each
metal steering wheel panel: 10$
plastic cover E-brake: 5$
change dish cover: 5$
cup retainer: 5$
plastic insert for door handles: 5$ each
armrests: 10$ each
Random bits:
PPF 20$
1.6 driveshaft 20$
1.6 half shaft set 20$
rear lower control arms 20$ each
NA 5 speed tranny plate 10$
Heat shield 10$
Fuel pump Cover Plate 10$
Working trunk seal 20$
daisycaps: 5$ each
Big Ticket Items:
Hard top. pictures don't do it justice. This is in good condition, better than a lot out there, just needs paint on the outside.
750$
2001' VVT engine w/ 22,000 MILES! never used by me
SOLD
675$
just discovered BAD THROTTLE GUIDE
no exhaust mani
Everything in the shots and on the engine + 1 free cat
includes sensors, intake manifold, injectors w/ rail, cops and other random bits
LNC 1.6l engine unknown mileage (probably 100-150k PO rebuild)
275$
5% within 160 for all cylinders when I last checked it
BAD THROTTLE GUIDE (shown in pics) only known issue
includes attached accessories in pics
500 miles rear main, 500 miles GATES timing belt kit, 500 miles water pump
2001' 6 speed 22k plus 500 miles!
SOLD
550$
new rear seal, new turret gasket, new shift seal, new pilot bearing. comes with ****, torn upper boot, and metal engine plate thing
Wired for NA Generation car w/ mechanical speedo sensor installed (bolt that sucker in)
Complete Torsen Conversion! 97 4.1 about 70k miles
550$
new gasket, new side seals, new driveshaft bolts, once used hub nuts
Exhaust downpipe to muffler from 1.6
200$
had it smogged tech said the cat was "a little weak" but would last.. passed the test.
Random bits and peices:
PPF 20$
1.6 driveshaft 20$
Heat shield 10$
Stock daisies - tread ranging from non existant to less than 1k miles
25$ set
Caps not included
Attached Thumbnails Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-1esrmid.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-lcui9odl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-f9tbptil.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-ko6kkykl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-49isjptl.jpg
Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-brdb3icl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-yvfgcfll.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-yrfa39ql.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-btka8gol.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-3fhpeiql.jpg
Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-yovyotg.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-umc8ay9.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-f9tbpti.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-rc9ciwp.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-49isjpt.jpg
Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-brdb3ic.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-yvfgcfl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-r9cxy88.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-lcui9od.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-0uzbpd7.jpg
Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-m5kczpp.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-lcui9odl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-49isjptl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-yvfgcfll.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-btka8gol.jpg
Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-3fhpeiql.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-ghujd3jl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-gpjujnhl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-r0mvpbul.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-r9cxy88l.jpg
Old Oct 31, 2013 | 10:20 PM
Total Cats: -2
More easily shippable items:
Prices don't include shipping ladies and gents. I tend to use usps flat rate for smaller items so you won't get screwed:
FM lvl 1 clutch, F1 chromoly flywheel (think around 11 pounds)
Sold
350$ takes the set ~ 500 miles used will consider parting if I get 2 buyers
new flywheel bolts, new PP bolts, new flywheel bearing
Gauge cluster:
30$
odometer reads a whopping 253k!
Brake stuff:
1.8 Brake conversion (1.8 brackets rears and fronts):
65$
if you pick up locally I have some pretty rusty disks you can have for free
Reman 1.6 front brackets:
25$ set
Rear hub assemblies:
500 miles New bearings, New studs, New seals :
65$ set
Pb ultimates or w/e they are called now:
15$ set rears and fronts
about 500 miles bedded
Brake cables:
15$ set
Lotta miles, but they work
Complete set of stainless steel lines:
includes fronts rears AND slave cylinder line:
90$ shipped
Speed bleeders!
I remember doing some research and settling on these because they were supposed to have fewer problems external valve or something
25$
Accessorize!
Power brake booster, actually much better shape than it looks, rubber boot on back looks really good: 35$
A/C compressor: 25$ Sold
Cruise control: 25$
Interior furnishings:
seatbelt buckle: 10$ each Sold both
cup retainer: 5$
armrests: 10$ each
suspension stuff:
All Sold
-Stock 1.6 NA springs:
45$ set
ebay springs
350/450
25$ set
Summit QA1 350's: 70$ pair
NA rear struts Bilstien hard S?
about 11k miles comes with adjustable perches
80$ set
na rear hats:
20$ set
fcm bumpstops for rear:
15$
Maf w/ box: 35$
reservoirs: 10$
fans: 20$ each
Exterior Lights:
Fronts: 10$ each Sold
Rear Lid light: 20$
electronic **** / latches just ask for pricing or make an offer:
(I already list below average for most things so we could probably work out a good deal)
carpet and paneling:
speaker panels: 10$ each
carpets meh shape: 15$ set
door trim panels (one is a little rough the other is just fine): 20$
trunk carpet: 5 $
soft top cover. some stains underneath top looks good: 35$
large daisy caps various condition
5$ each:
Attached Thumbnails Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-pccyyio.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-kerzyhx.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-wcppeyc.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-zddd7hr.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-pccyyiol.jpg
Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-kerzyhxl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-zddd7hrl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-wcppeycl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-2xhjggml.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-a4qjhdjl.jpg
Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-o4nuobwl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-6ccd5oll.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-pccyyiol.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-kerzyhxl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-zddd7hrl.jpg
Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-wcppeycl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-2xhjggml.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-a4qjhdjl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-o4nuobwl.jpg   Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-6ccd5oll.jpg
Frosty's Mega Part-Out: Hardtop, VVT engine, 6speed, and much more!-bunraywl.jpg
Old Nov 2, 2013 | 02:13 PM
Total Cats: -2
Updated! More to come this afternoon!
Old Nov 2, 2013 | 02:22 PM
aaronc7's Avatar
Total Cats: 43
Good stuff here. If you were closer, I'd be tempted to get that VVT motor.
Old Nov 2, 2013 | 03:29 PM
scenturion's Avatar
Total Cats: 61
emailed you about the 01 motor. would be a good starting point for my build.
Old Nov 2, 2013 | 06:05 PM
supercooper's Avatar
Total Cats: 35
That '90 Motor you have... is that the original motor FROM the '90? it looks to have the 8 slot crank pulley, making it a LNC engine, as opposed to the 4 slot SNC engines.
Old Nov 2, 2013 | 06:59 PM
Total Cats: -2
I can't remember what the PO said about the rebuild but I do remember that it is in fact a LNC it's possible they did some work on the old head and put a new bottom on it which would make sense. either way, good compression LNC engine right hur.
respond in a sec
Old Nov 2, 2013 | 07:32 PM
TurboDSM's Avatar
I'd be allover the 6speed if you were local to michigan, all the good deals are in cali :(
may want the stainless lines if you still have them this Friday.
Old Nov 2, 2013 | 07:40 PM
AZboost's Avatar
Total Cats: -2
Ill take the fm lvl 1 clutch. I dont want the flywheel. I cant send pms.
If you had another buyer for the flywheel how much for the clutch shipped?
Spgarcia@live.com
Old Nov 2, 2013 | 10:11 PM
connor's Avatar
Darn, AZboost beat me to the punch!
If you end up not separating the clutch and flywheel, I'll take both.
Old Nov 2, 2013 | 10:23 PM
AZboost's Avatar
Total Cats: -2
Hey if you want both go ahead. Id rather see the whole kit sell. I just didnt need the flywheel.
Old Nov 2, 2013 | 10:47 PM
connor's Avatar
All right, thanks!
Old Nov 3, 2013 | 09:31 PM
GV1390's Avatar
OP, shot you a text earlier today on the rear end setup.
Old Nov 5, 2013 | 02:08 PM
Total Cats: -2
Loads more shiz, responded to all messages. Listing more phone friendly. GOOD PRICES GUYS
flywheel clutch combo still up for grabs!
Lets get these parts movin!
Old Nov 5, 2013 | 02:26 PM
connor's Avatar
How much for the clutch/flywheel shipped to 92055?
Old Nov 6, 2013 | 04:39 PM
Total Cats: -2
Clutch flywheel combo sold and shipped
Old Nov 6, 2013 | 10:04 PM
isleeptill12's Avatar
Braided brake lines still available? Whats up with all the extra fittings in the picture with the brake lines?
Old Nov 6, 2013 | 11:23 PM
mx594m's Avatar
I'll take the A/C compressor for $35; and all the suspension stuff for $200
need shipping to 37918
PayPal?
Old Nov 7, 2013 | 06:00 PM
Total Cats: -2
Still available, the extra fittings are designed specifically for the lines, stock ones don't work. If I remember correctly the lines are goodwins
it looks like the set would be 96 shipped
PayPal?
Alright I think I can do that.
I'll check out which boxes I can fit them into. The struts might not work in a flat rate box
Old Nov 7, 2013 | 07:16 PM
mx594m's Avatar
I will reimburse you for shipping in the paypal payment - I find UPS has the best ground rates - will PM you my shipping address
