Torsens, clutch pack, and a six speed!
Contact: PM, ph# 540.429.7702
List:
$550 - REBUILT 3.9 Torsen Type I. New OEM Pinion and halfshaft seals. Comes with Rx7 carrier with NO bushings. Can and will install poly bushings for an extra $100 and a deposit for work.
$450 - REBUILT 3.9 FC Rx7 Clutch Pack diff. New OEM Pinion and halfshaft seals. Comes with Miata carrier with NO bushings. Can and will install poly bushings for an extra $100 and a deposit for work.
$650 - 2001 6 speed with 115k. Has Shifter, NPS, RPS, and factory electronic VSS. Used with Motorcraft GL4 75w-90.
I don't think that pictures are necessary as we all know what these look like. But, if someone wants some of a particular item - Let me know.
Thanks!
List:
Thanks!
A good question.
Yes, for the NA and NB with the Miata bushings installed. The major pro of the Rx7 FC carrier is that it doesn't have the relief cut on the passenger ear of the carrier which is preferred for cars that see a lot of AutoX and track.
Bump.
Also, I suppose I should have been more specific: The clutch pack is ready for a NA or NB Miata drop in. It's the FC clutch pack LSD in a Miata housing with Miata carrier.
graexodus
Oct 26, 2015 01:48 PM
