Stuff FS: OEM, aftermarket, etc.
Old Sep 20, 2014 | 11:44 PM
EO2K's Avatar
Total Cats: 1,924
Default Stuff FS: OEM, aftermarket, etc.
Lets get right to this...
NIB Timing belt leftover from a couple timing belt changes. Purchased from Rosenthal some time ago. This should fit 90-05, but do your homework and confirm before purchasing.Belt only, idler pictured is already sold.
Belt: $20
Random belts! New! Never installed! Again, do your homework and confirm specific fitments before purchasing. I'm guessing alternator, and NB with AC & PS
K040372: SOLD
K040338: $5
4PK 945: $5
NIB SINGLE (1) Mazda Comp motor mount. Not sure how I ended up with this TBH.
Comp mount: $35
Used angled 3 gauge single din mount. Super flimsy until you get gauges in it, then it stiffens up a bit.
3 gauge mount: $5 with something else
Used Wilwood BP-10 brake pads, Dynalite 7112 fitment. These should work with any of the Miata Big Brake Kits (Goodwin, 949, TSE, older FM) that use the Dynalite Wilwood 4 piston calipers. These are fine for street use but I wouldn't get them anywhere near an HPDE event.
BP-10: $20
Used NB stock throttle body. No IACV, no TPS, comes with free oxidation and grime. Seals fine and no real damage anywhere, its just ugly. Not sure what you are going to do with this thing.
NB TB: $15
Turbosmart IWG75 adjustable internal wastegate actuator. I purchased this "used" but the thing looks like its never been mounted. I scarred up the locking ring eversoslightly while trying to remove the ring to open it up and check the spring. Includes box, mini disc, sticker, nuts, etc. This should have enough throw to work with a BEGI or FM turbo kit once you fabricate a mount. Its preloaded with a 7psi spring so perfect upgrade for a 2560 w/EBC. Get a bigger spring and run ALLOFIT. This thing has a long enough arm and enough throw that it would probably work just fine for most Garrett IWG turbos, after you fabricate some sort of bracket. These sell for about $170~$180 new. I paid $150 so you pay $150.
IWG-75: $150
NIB Innovate Motorsports LC-1 wideband. NO GAUGE! As you can see, its never been installed. Everything is in the box including the pesky serial cable and terminator. Wideband sensor itself still has the factory silver anti-seize compound on the threads. NO GAUGE!
LC-1: $120
NIB: Innovate Motorsports AutoTimer. Its like a turbo timer, but does a bunch of other crap as well. Such as being an AFR display for the above listed LC-1. hint-hint.
AutoTimer: $50
AutoTimer + LC-1: $165
Before you ask, I'm located in the Peoples Republic Of California.
Terms and Conditions:
All prices are OBO but don't get crazy. Go look things up on Amazon or something before you try to lowball me. Buy multiple things and I'll consider knocking off a little bit here or there.
Caveat emptor. Know and understand what you are buying before you commit. I've attempted to photograph things or describe them as best I can, but do your own research and ask questions. Knowledge is power.
I don't mind you calling dibs but you better be prepared to follow through. Post up in this thread if you want something, I don't want eleventybillion PMs to sort through. I'll update the OP as things sell.
I ship at buyers expense. I tend to send things via USPS Flatrate because its cheap and easy and there is a post office across the street from my place of business. If you want FedEx or UPS I can accommodate, but its going to take me a little extra time to get things shipped out. I'm not interested in shipping to Canada unless you make it worth my while. I'll supply tracking or reference numbers as they are available.
I accept payment via Paypal. Send it as a gift or add 3% to cover fees. The choice is up to you. I tend to ship to the address on the Paypal invoice and I may ask you to verify this information before something goes in the mail.
I expect you to leave iTrader feedback. Good/Bad/Indifferent I don't care just made sure you do it. I will definitely be leaving you feedback one way or another.
I reserve the right to ignore you or discriminate against you based on your post count, props score, iTrader feedback, etc. If you are an *** then I probably don't want to put up with you. Postwhoring n00bs will be reported.
Don't quote images back to me when responding that you want something. This will most likely trigger the above discrimination clause.
Thanks for looking!
Old Sep 20, 2014 | 11:51 PM
in for discrimination
Old Sep 21, 2014 | 12:24 AM
HHammerly's Avatar
Total Cats: 63
I would like the fuel rail and defrost pigtail. PM sent
Old Sep 21, 2014 | 10:02 AM
Miatacrazy716's Avatar
You have a pm
Old Sep 21, 2014 | 11:31 AM
HHammerly's Avatar
Total Cats: 63
Oops did not realize that the previous post was for the seller
Old Sep 21, 2014 | 05:18 PM
zossy1's Avatar
Total Cats: 22
Pretty sure that harness is NA8 (94-95).
Old Sep 21, 2014 | 08:53 PM
T0mmy's Avatar
PMd you, I'm interested in the LC1 and gauge plate for $130. I have low post count but been here for years. I can PayPal asap.
Old Sep 21, 2014 | 11:08 PM
turbofan's Avatar
Total Cats: 1,091
Daammmmmit... I am second in line for the fuel rail unless someone tells me I don't need this. Why don't you need this?
Ed@949Racing/Supermiata
www.949racing.com
Old Sep 22, 2014 | 12:05 AM
TheBandit's Avatar
Total Cats: 57
Interested in the fuel rail if Hammer doesn't follow through.
Old Sep 22, 2014 | 12:51 AM
CompleteXen's Avatar
Ill take the gates K04372 + Idler Pulley
My email is lancewhitehead995@gmail.com if you can send me your paypal info since I cannot PM yet.
Old Sep 22, 2014 | 02:44 AM
99mx5's Avatar
Total Cats: 526
Good deals! Bump for you man!
Old Sep 22, 2014 | 05:37 AM
HHammerly's Avatar
Total Cats: 63
I need the fuel rail, still waiting for a reply form the seller
Attached Thumbnails Stuff FS: OEM, aftermarket, etc.-6317233e-7628-449a-bace-f7a7a724c266.jpg
Old Sep 22, 2014 | 08:39 AM
slammed200's Avatar
Total Cats: 30
I'll take the following shipped to 47201, PM me a total shipped price for payment good sir.
NB FPR: $40
NIB Miata OEM fuel filter: $10
NIB Innovate Motorsports weld-in wideband bung: $5
3 gauge mount: $5
NB38-67-080 Mystery harness: $20
Old Sep 22, 2014 | 11:13 AM
EO2K's Avatar
Total Cats: 1,924
Sorry guys, boss surprised me with a surprise trip to Arizona, and now I'm sitting on a runway in a broken Lear jet (balla!)
I'll sort through the posts & PMs tonight. Sorry for the chaos!
Old Sep 22, 2014 | 11:23 AM
No problem life happens.
Old Sep 22, 2014 | 02:31 PM
T0mmy's Avatar
Rich people problems =)
Old Sep 22, 2014 | 02:51 PM
EO2K's Avatar
Total Cats: 1,924
that would be my boss. i was forced to fly like a peasant in the king air instead. did i ever tell the story about when our network engineer drove to tahoe to reboot his router?
ive got like a billion pms now. when i can sit down this evening i'll make sure to reply to everyone. i'm flying back tomorrow late so the earliest things can go in the mail is going to be wednesday.
sorry for the delay, i appreciate everyones patience with me.
Old Sep 25, 2014 | 12:13 AM
EO2K's Avatar
Total Cats: 1,924
Potential buyers responded to via PM and email, OP updated. Lets move some more stuff!
Old Sep 25, 2014 | 07:51 AM
HHammerly's Avatar
Total Cats: 63
Payment sent this morning for my things.
Old Sep 25, 2014 | 02:15 PM
EO2K's Avatar
Total Cats: 1,924
Got it! I'll go in the mail this afternoon. Thanks Harold!
In fact everything is packed up and ready to go.
HHammerly, slammed200 and CompleteXen (provided he gets me a shipping address) will have packages in the mail before the end of the day.
