Moving Sale
Old Aug 4, 2015 | 01:07 PM
Midtenn's Avatar
Total Cats: 311
Default Moving Sale
My wife and I are closing in on putting our house on the market. I'm lazy and would like to move a few boxes into storage as a I have to. I have parts for NA, NB, and NC cars. A lot of them were pulled off Spec Miata and MX5 Cup car builds. Prices below are before shipping. Smaller items will be shipped via USPS flat rate boxes, everything else with whoever is cheaper.
Pictures:
NA Parts: NA Parts by Andrew Cowden | Photobucket
NB Parts: NB Parts by Andrew Cowden | Photobucket
NC Parts: NC Parts by Andrew Cowden | Photobucket
Misc Parts: Misc Generations by Andrew Cowden | Photobucket
Performance
NA Control arm set w/ polyurethane Bushings - SOLD!
Used VVT 10:1cr Pistons - $50.00
90-97 Chassis
AC delete tube - $30.00
Air bar - Drv. Side - $40.00
90-93 Air bag module - $40.00
Center Console - $40.00
Charcoal canister - $30.00
Chrome vacuum hose - $20.00
90-93 Coil pack - $60.00
90-93 Combination switch - $30.00
Console hinges and latch - $20.00 per set
Door handle cups - $20.00 per set
Door handles (ext) - $20.00 per set
Door handles (int) - $20.00 per set
90-93 Door panels - $80.00 per pair
94-97 Door pulls - $20.00 per pair
90-93 Door pulls - $20.00 per pair
Driver Side Door - $60.00
Passenger Side Door - $60.00
90-93 ECU - $30.00
Gauges - $30.00
Grill insert - $30.00
Headlight lids - $30.00 per pair
90-93 Injectors - $30.00 per set
Knee panel - $30.00
Marker light (front) - $20.00
Marker light (rear) - $20.00
1990 Owners manual - $20.00
Power steering pump - $30.00
Radio cubby - $20.00
Side Mirror (manual) - $30.00
Side Mirror (power) - $50.00 per pair
90-93 Speaker covers - $20.00 per pair
4.30 Speedo sender - $30.00
Starter - $40.00
Steering column cover - $20.00
Power Steering Rack - $90.00
Driver side tail lights - $30.00
Passenger side tail lights - $30.00
Throttle Cable - $30.00
90-93 TPS - $30.00
Driver side turn signal - $30.00
Window regulator (pass. side, manual) - $50.00ea
Windsheild trim - $20.00ea
Wiper arms - $30.00 per pair
99-05 Chassis
10th Anniversary Edition Steering Wheel: $150
Passenger air bag - $40.00
Alternator - $60.00
Battery Tray - $30.00
Door lock ECM - $30.00
Fog light harness - $60.00
Overflow tank - $30.00
Side Mirror (power) - $30.00
99-05 Rear Subframe brace - $30.00
Window regulator (power) - $60.00
90-05 Chassis
OEM Windblocker (black or tan) - $50
A piller covers - $30.00 per pair
AC compressor - $90.00
Axles 1.8l 1pc - $120.00 per pair
Brake master cylinder - $30.00
Brakes 1.8 Rear - $50.00 per pair
Clutch master cylinder - $40.00
Clutch slave cylinder - $30.00
RX7 Differentail mount - $60.00
1.8 Differential (open, diff only, not in carrier) - $20.00
4.10 Final Drive gear set - $60.00
Floormats - $40.00 for pair
Frankenstein bolts - $20.00
Interior trim - $20.00 per pair
90-93 Oil Pressure Sender - $40.00
Rubber Pedal Covers - $20.00 per pair
Proportion valve - $20.00
NB Radiator hose (lower) - $20.00
Stock connecting rods - $10.00
90-93 Seat belt receivers - $50.00 per pair
Sunvisors - $30.00 per pair
Trunk seal - $30.00
Vents - $30.00 per set of 4
Visor blanking plates - $20.00 per pair
Window cranks - $10.00 per pair
NC Parts
Enginge/Transmission
Air box - Used - $30
Alternator - New OEM - $180
6spd Clutch disc - New OEM - $100
Clutch pressure plate - Used, less than 1k mi - $100
Engine cover - Used - $30
Exhaust manifold w/ gutted cat - Used - $50
Flywheel - Used - $30
Fuel rail w/ Injectors - Used - $120
Motor mounts - New - $70 per pair
Radiator - Used - $90
Radiator shroud w/ fan - Used - $60
Radiator shroud w/o fan - New - $30
Interior
Bose radio and amplifier: $150
Center console - Used - $30
Clutch and brake pedal assembly - Used - $40
Combination switch - Used - $40
Cup holder - Used (black or saddle)- $30
Door seals - $120 for a set
Door switch panels - New, Piano Black - $50
Door Card - 06-08, black - $75ea
Foot rest - Used - $10
Gas pedal - Used - $30
Wire Mesh Grill - New NC1 - $30
OEM Grill - Used NC1, - $30
Rubber Pedal covers - Used - $20
Shift boot - OEM - $30
Tail light - NC1 - $90 per side
Trunk light - Used - $20
Suspension and Brakes:
Brake master cylinder - New - $75
Front hubs (used) - $100 for pair
Brake disc - New, Front - $50ea
Brake disc - New, Rear - $50ea
NC ABS pump - Used - $120
Shocks - Standard, Used - $75 for set of 4
Springs - Blue/White & Red/Yellow - $80 for set of 4
Sway bars - Sport - $90 for pair
Sway bars - Standard - $75 for pair
Old Aug 5, 2015 | 01:32 PM
fivehundredton's Avatar
Bannisheded
Zerk fittings mounted in NA control arms w/ polyurethane Bushings?
Old Aug 5, 2015 | 01:49 PM
psyber_0ptix's Avatar
Total Cats: 544
Did you have pictures for the control arms and the condition of bushings? How much shipped to 22201?
Old Aug 5, 2015 | 04:22 PM
Midtenn's Avatar
Total Cats: 311
There are zerk fittings in the front control arms only. They came off a still born project car and are brand new. I can get some pictures and shipping estimates this evening.
Old Aug 5, 2015 | 09:22 PM
deezums's Avatar
Total Cats: 206
How much would the AC delete tube be to 66046?
Thanks for the clutch, by the way. It's working great!
Old Aug 5, 2015 | 10:10 PM
Midtenn's Avatar
Total Cats: 311
Shipping would be $15
Old Aug 6, 2015 | 10:18 AM
Total Cats: 544
Payment sent for control arms
Old Aug 11, 2015 | 01:31 PM
Midtenn's Avatar
Total Cats: 311
Shipped out the control arms yesterday.
Old Aug 12, 2015 | 01:57 PM
Liquidog's Avatar
Interested in the following, any pics available?
Side Mirror (manual) - $30.00 (per pair?)
Maybe we can work out a package deal with shipping to 60625. Let me know.
Old Aug 18, 2015 | 01:04 PM
Midtenn's Avatar
Total Cats: 311
Many parts still need a good home.
Old Aug 23, 2015 | 02:43 PM
Bodhimeister's Avatar
Total Cats: -7
Instrument cluster with defroster light for a '92 available? I'd need it to 49424. Thanks.
Old Aug 24, 2015 | 01:24 PM
Midtenn's Avatar
Total Cats: 311
Let me check. I might be out of 90-93 gauge clusters.
Old Aug 24, 2015 | 01:32 PM
Total Cats: 544
Do you have a passenger side interior door handle/latch? My lever broke by someone hamfisting it somehow. They didn't realize how to unlock it and just kept pulling harder. Also need the little screw for the cup.
-_-
Old Aug 28, 2015 | 07:57 PM
my90's Avatar
Do you still have the heater controls for the NA ?
Old Aug 31, 2015 | 10:22 AM
x_25's Avatar
Total Cats: 144
The 90-97 manual mirrors, is that $30 each or per pair?
Reply
Old Aug 31, 2015 | 04:25 PM
Midtenn's Avatar
Total Cats: 311
Each
Old Sep 28, 2015 | 01:43 PM
Midtenn's Avatar
Total Cats: 311
Bump
Old Oct 1, 2015 | 03:17 PM
rburrow87's Avatar
I'm interested in these shipped to 92154 if they're still there:
90-97 Chassis
90-05 Chassis
Frankenstein bolts - $20.00 (what's included in this?)
Old Oct 5, 2015 | 01:41 PM
Midtenn's Avatar
Total Cats: 311
90-97 Chassis
90-05 Chassis
I have the power mirrors for sure. I'll get a shipping quote soon. The Frankenstein bolts are the plates and bolts that are just in front of the trunk to latch the hardtop to. I will have to double check that I have a set left.
Old Oct 6, 2015 | 08:11 PM
Midtenn's Avatar
Total Cats: 311
90-97 Chassis
90-05 Chassis
I don't have any Frankenstein bolts. Shipping on the pair of mirrors to 92154 will be $20.
