Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!
Old Sep 30, 2015 | 03:18 PM
StratoBlue1109's Avatar
Default Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!
Well guys, it's time to bow out of the Miata game. After running ALL of the boost.... I've had WAY too much fun, embarrassed a lot of other "faster" cars, and gone through two motors.
But alas, my wife and stepson are nearing the end of their green card process, and they will be moving here from Brazil, very soon. So, fun must take a back seat to practicality as I trade the Miata in on something with a back seat. So, I look to you, my Miata Turbo brethren, to carry on the "little car with too much power" legacy.
So, I am parting out all of my go fast bits. I have pulled a few things off the car, but there are a few things left to pull. I will list everything, and post pics of everything as it's pulled. I may be adding a few other things as I tear the current engine down, and see what is salvageable.
All prices are PLUS shipping, but I have a shipping account through my shop, so shipping charges will be slightly discounted. I am also willing to put together "package pricing" if anyone is interested in several pieces together. For example, if someone wants the whole turbo hot-side set-up.
On to the goods!
---Precision Turbo 350 hp Intercooler - $150 - has been drilled and tapped for GM air temp sensor, can be plugged with 3/8 NPT plug if you want to run your sensor elsewhere. -SOLD!
---Rev built MS2 Enhanced - $550 - Includes EGT sensor, GM ACT sensor, Includes VVT Tuner(internal). This unit is plug and play for 01-05 cars. I will also include the email instructions I received from Reverant when I bought it. This MS2 also has my current tune installed. It was tuned up to 18 psi with RX8 yellow injectors and made a little over 300 whp. -SOLD!
---Flying Miata V1 Turbo Manifold - $175 - This an earlier FM manifold. It is cast iron, and has relief cuts. I also had this manifold ceramic coated prior to install. -SOLD!
---RX8 "Yellow" Injectors - $100 These are the "go to" injectors for NB1/2 cars. 465cc and stock idle. I made just over 300 whp on these with a Walbro 255. They were cleaned and flowed before I installed them, that was bout 2 years ago. They should be ready to drop in and go. -SOLD!
---Turbosmart BOV - $100 Freshly cleaned and re-lubed. There is a tiny mark on the body from where it rubbed on my fan shroud. Also includes pipe with flange. I mounted this pipe just before the throttle body. SOLD!
---Godspeed Ebay 2871 Turbo - $150 This turbo is awesome spools great, makes great power,super reliable, and CHEAP. I have about 15k miles on the turbo and there is almost zero shaft play, and no smoke. Also including Glowshift sandwich plate, stainless oil feed line, and -10 oil drain line. -SOLD!
---BEGi Separated Gases Downpipe - $200 Mild steel, include O2 bung. This down pipe has a 2.5" V-band exit. I can include a portion of the exhaust that includes the other half of the v-band flange. I have also welded a tab on the flange of the turbo to separate the gases, since my turbo did not have this built into the turbine housing. This can also be removed pretty easily. -SOLD!
---Momo Steering Wheel with Hub - $150 Wheel is in great shape. - SOLD!
---AEM UEGO - $75 Includes alternate face plates. SOLD!
---Autometer Sport Comp II Boost Gauge - $74- Up to 20 PSI, and LED back lighting. Includes Auto Tech ePod steering column mounted gauge pod (-SOLD!
---FM V-Maxx Classics (modified) - $450 Hyperco 400 lb 8 inch front springs with ISC top hats. Rear is stock NB V-Maxx. These rode GREAT and handle very well, for a budget set-up. With the longer springs, these will work on Mazdapeeds and 01+ cars without coil binding. (Pics Soon) -PENDING
That's the list for now, but I may have other parts soon. Thanks in advance!
Attached Thumbnails Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0061.jpg   Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0062.jpg   Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0063.jpg   Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0065.jpg   Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0068.jpg
Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0069.jpg   Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0073.jpg   Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0075.jpg   Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0081.jpg   Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0083.jpg
Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0085.jpg   Back to Stock Part Out!! Turbo Parts, MS2 Enhanced 01-05, Suspension, and MOAR!-img_0072.jpg
Last edited by StratoBlue1109; Oct 2, 2015 at 04:39 PM. Reason: Items sold, made easier to read
Old Sep 30, 2015 | 03:36 PM
Big_gumby's Avatar
still have the ms2?
Old Sep 30, 2015 | 04:27 PM
itslegendddd's Avatar
Is the manifold t25 or t3/t4?
Old Sep 30, 2015 | 05:08 PM
acedeuce802's Avatar
Total Cats: 175
Pics of the Momo steering wheel? Do you know what kind of hub it is?
Old Sep 30, 2015 | 05:16 PM
T25 flange. I've already received quite a few PM's for turbo parts, and the MS2. So, it might go quick.
Old Sep 30, 2015 | 05:18 PM
This is the exact wheel. I bought it from 18psi a few months ago. It's still in the exact same condition.
https://www.miataturbo.net/miata-par...-wiring-77818/
Old Sep 30, 2015 | 05:44 PM
deezums's Avatar
Total Cats: 206
Is that turbosmart valve a 38mm v-band one?
Old Sep 30, 2015 | 06:15 PM
I think you might be thinking wastegates, but no this valve is not a v-band flange.
Old Sep 30, 2015 | 06:25 PM
deezums's Avatar
Total Cats: 206
Nah, not wastegate. Turbosmart is the only one who makes a 38mm v-band BOV except the china ebay copies AFAIK, I guess that's not one of these.
http://www.turbosmartusa.com/product/dual-port
Old Sep 30, 2015 | 07:58 PM
ihiryu's Avatar
Total Cats: -11
Are those prices shipped?
Old Sep 30, 2015 | 10:03 PM
cale saurage's Avatar
On to the goods!
---RX8 "Yellow" Injectors - $100 These are the "go to injectors for NB1/2 cars. 465cc and stock idle. I made just over 300 whp on these with a Walbro 255. They were cleaned and flowed before I installed them, that was bout 2 years ago. They should be ready to drop in and go.
---BEGi Separated Gases Downpipe - $200 Mild steel, include O2 bung. This down pipe has a 2.5" V-band exit. I can include a portion of the exhaust that includes the other half of the v-band flange. I have also welded a tab on the flange of the turbo to separate the gases, since my turbo did not have this built into the turbine housing. This can also be removed pretty easily. (Pics soon)
---Momo Steering Wheel with Hub - $150 Wheel is in great shape. (Pics soon)
---AEM UEGO - $75 Includes alternate face plates. (Pics soon)
---Autometer Sport Comp II Boost Gauge - $74- Up to 20 PSI, and LED back lighting. Includes Auto Tech ePod steering column mounted gauge pod (Pics soon)
I will buy the manifold
Old Sep 30, 2015 | 10:36 PM
Old Sep 30, 2015 | 11:24 PM
Jorge Ruiz's Avatar
Does the intercooler come with all the piping?
And will the RX8 injectors fit a 91 1.6L?
Old Oct 1, 2015 | 01:32 AM
nbdooey's Avatar
Correct me if I'm wrong, but aren't the RX8 yellow top injectors 420cc?
GLWS!
Old Oct 1, 2015 | 08:51 AM
Total Cats: 175
I'll take it.
Old Oct 1, 2015 | 09:31 AM
Total Cats: 175
Heads up, this is most likely a 1.8 manifold.
Old Oct 1, 2015 | 09:46 AM
UPDATED!
Some items have sold... Some items are pending.
Thanks to everyone that has bought my parts so far!
Old Oct 2, 2015 | 09:39 AM
MS2 Enhanced has sold!
Turbo kit is pending.
Suspension will be pulled and photos taken this weekend.
Old Sep 29, 2018 | 08:00 PM
achervig's Avatar
Total Cats: 18
Congrats on getting the family home with you, brother. Nothing outperforms family! Nothing costs more either!
Old Sep 29, 2018 | 10:18 PM
borka's Avatar
Total Cats: 197
What is the reason you felt compelled to reply to a 3 year old thread?
