Help: Oil leak above oil sender (video)
Total Cats: 196
Please help me identify this leaking part and how to fix it, as it seems almost impossible to get to from under the car.
The leak seems to come from a big nut looking part right above the oil sender on the passenger side of motor.
video below:
video below:
Total Cats: 196
Thanks!
The more i look at this, the more i think its not oil sipping down...
Probably black sealant inside the knock sensor melted and leaked down, if it was oil, the stream would not be as neat.
Now i need to fix my other leaks... (cap on exhaust side rear engine, and front main seal).
I really hope my oil pan is not leaking, but its so wet under the engine, i cant really pin point the source of leaks. but i know for a fact the rear cap is leaking and probably front main and maybe cam seals.
jpreston
06-17-2016 01:43 AM
bradybunz
02-12-2016 06:41 PM
dwink
01-17-2016 09:23 PM
