Can someone teach be about the EBC?
Old 12-31-2007, 01:55 AM
cardriverx's Avatar
Default Can someone teach be about the EBC?
Ok, I get the KPA table, that just what boost you want it to achieve vs RPM. What I dont get is the duty cycle table? What dose that change? What should I have it set at? Thanks for the help guys.
cardriverx is offline
Old 12-31-2007, 03:20 AM
Set Closed Loop kPa to 0(it might default to 20), this uses the duty cycle targets to control boost, the kPa targets have been known to not work as well as that part of EBC is considered experimental. The higher the % in the row, the higher the boost. 100% keeps the valve closed completely which doesn't let the wastegate open.
I do not recommend using this Duty table, it could possibly damage your car. 100% duty will allow your turbo to spool itself to death as well as your motor. Start low and work up, slowly till you know what you're doing.
Old 12-31-2007, 07:29 AM
paul's Avatar
this is what i use but my setup spools like a mother ****** with no boost control
i'll probably make it smoother from low to high TPS but that was my first attempt, i was in a rush
paul is offline
Old 12-31-2007, 10:24 AM
photoeye0's Avatar
What solenoid are you guys using? I know most people recommend using the GM one off of the 4.3 turbos, but have a few leftover mazda solenoids. I was wondering if anyone has ever used them.
photoeye0 is offline
Old 12-31-2007, 12:10 PM
Saml01's Avatar
Originally Posted by cjernigan
How come you can change your ambient KPA. Mine is grayed out.
Saml01 is offline
Old 12-31-2007, 01:05 PM
We're using the GM solenoid from a Typhoon.
No idea why you can't change yours Sam.
Old 12-31-2007, 01:25 PM
cardriverx's Avatar
Ok, thanks a ton guys.
Old 12-31-2007, 01:30 PM
photoeye0's Avatar
Damn Ok. What is the part # on the soleniod.
Old 12-31-2007, 10:45 PM
elesjuan's Avatar
Total Cats: 43
http://www.diyautotune.com/catalog/p...kit-p-160.html
http://www.diyautotune.com/catalog/b...02642216f86f5f
Great install article:
http://forums.turbobricks.com/showthread.php?t=80599
elesjuan is offline
Old 12-31-2007, 11:46 PM
photoeye0's Avatar
Cool thanks. I'm going to try crossing the GM number at work so I can rock the discount. So hopefully I can get a Borg-Warner number for anyone that wants it.
Old 12-31-2007, 11:49 PM
I bought a solenoid at my local dealer. It was $27 plus tax.
Old 01-01-2008, 12:44 PM
Saml01's Avatar
Its even grayed out in the PNP msq that I just downloaded.
So weird.
Probably a configurator setting, thats locking it out.
Saml01 is offline
itsMikey
MSPNP
09-28-2015 06:40 AM
Baxgordum
09-04-2015 11:42 PM
jayc72
Insert BS here
13
12-21-2007 07:43 PM
krayzrac3r
6
11-28-2007 08:25 PM
Braineack
102
09-10-2007 10:11 AM
Quick Reply: Can someone teach be about the EBC?
