FM3 Turbo Kit minus electronics
Old 03-30-2008, 04:44 PM
Leebo's Avatar
Default FM3 Turbo Kit minus electronics
Complete FM3 Turbo kit 1990-1993 (1.6L) minus ECU/fuel
Includes:
-Garrett T28 turbo
* Rebuilt less than 5,000 miles ago at Limit Engineering. Works great, no problems.
* Journal bearing, oil and water cooled.
* Turbine: 0.49 A/R ratio, 79 trim, 53.0mm wheel diameter
* Compressor: 0.48 A/R ratio
-FM intercooler w/ new black powder coating
-All air pipes (air filter to turbo to IC to thottlebody) w/ new black powder coating
-FM divorced 2.5" downpipe
-Installation and tuning instruction manual
Kit also upgraded with:
-FM's all metal Blow off valve
-Tial 35mm external wastegate (with 9psi spring)
This turbo system runs GREAT and is in very good condition. Several items have new powder coating and many new nuts/bolts are provided. I'm only selling it because I have finally been bitten by the V8 bug and have started an engine conversion. With this turbo kit, I have produced 240hp/228 ft-lbs at the wheels running about 15psi on a local dyno (see dyno page). Very fun and VERY fast. Driven daily and sleeps quietly on the road until you put your foot down... then HOLD ON! It has very good streetable characteristics. This kit was sold by Flyin Miata years ago called the "FM3" kit. This is very similar to the "FM2" kit except that it utilizes an external wastegate (which allows for better top end performance under higher boost conditions). Other than that, it is basically the same kit. This was marketed by Flyin Miata, but several of the parts came from BEGI. The smaller turbine and compressor A/R ratios allow for fast spool-up yet it maintains strong torque all the way to redline. The turbo was rebuilt less than 5000 miles ago for minor bearing issue and still has very little freeplay (like new). This kit in is truly in great condition. I don't like buying junk on the internet from others, so I don't sell junk either unless I fully disclose what you're buying.
Also included are replacement silicone air pipe hoses. The orange ones in the pictures are also included as spares. The blue hoses are more durable and I had intended to swap them out but never got around to it. I went ahead and put the nicer blue ones on the pipes along with new hose clamps when I removed the system from my car. A couple of the air pipes had some chipped powder coating and a little blue paint overspray from when my car was repainted, so I had the pipes and intercooler media blasted and recoated with fresh powder coating. They look brand new. There are two new turbo gaskets and several packets of new nuts/washers. The turbo water jacket has two new silicone water lines. The fresh parts and powder coating should make installation a little easier and look cleaner when done.
As for any negative things to mention, there are two things. The downpipe and exhaust manifold had been originally ceramic coated mostly for cosmetic reasons. Some of the coating has flaked off of the downpipe which now reveals some surface rust. This is normal; the kit normally comes with a painted downpipe. The paint normally burns off and the pipe takes on surface rust. On this downpipe, most of the flaking is down low where the pipe is near the ground so it is not that visible from the engine bay. The other negative thing to report is a small crack in the exhaust manifold. This crack is at the flange where the wastegate joins the manifold. The crack is minor and has been there for years without growing. I do not anticipate this being a problem; it was probably caused by internal stresses that are now relieved with repeated thermal cycles. There is no exhaust soot blowing from the crack.
The wastegate originally included with the FM3 kit was made by BEGI. After repeated problems with the gate sticking, I replaced it with a Tial wastegate, which is what BEGI uses now. It has performed flawlessly ever since. The wastegate has a 9psi spring currently installed and I utilized a Greddy boost controller to reach boost levels above 9psi (I usually ran at 13-15psi max daily). The spring inside the wastegate can be easily changed to provide different levels of baseline boost, however it is optimal if you use a boost controller for levels from 9-15psi.
The main K&N air filter was replaced not long ago and is in very good condition. A valve cover breather K&N filter is also included.
Overall this kit is in great condition. You won't be disappointed with the performance, condition and overall appearance of the kit.
Over $4000 invested...
Asking $2000 o.b.o. for everything.
Please visit my site for more pictures:
http://topdownmx5.com/forsale.htm
Here is a picture of everything (except for the ECU, injectors and heat shield shown in this pic; I need to reshoot a picture but thought I would post this for now. More pics on my site at the link above)
Leebo is offline
Old 03-30-2008, 06:12 PM
Rafa's Avatar
I can vouch for Lee; great seller and his stuff is in tip top shape!
BTW Lee, how's the new project coming along?
Regards,
Rafa
Rafa is offline
Old 03-30-2008, 09:03 PM
Leebo's Avatar
Thanks Rafa. The engine conversion project is coming along very nicely; slow but good so far. Just taking it slow and trying to do it right... once.
Leebo is offline
Old 04-05-2008, 04:00 PM
Leebo's Avatar
Here's an updated picture of all the parts in the kit. My first posted picture showed the Link ECU (and associated parts), and heat shield. Those are not included. $1975 or best offer.
Leebo is offline
Old 05-06-2008, 08:06 AM
Leebo's Avatar
Default Reduced!
Bump. Reduced to $1700 obo. Will ship within US for $69 additional. System is ready to ship.
Leebo is offline
Old 05-06-2008, 08:33 AM
Stealth97's Avatar
Total Cats: 66
wow, thats a killer deal.
Stealth97 is offline
Old 05-06-2008, 10:16 AM
levnubhin's Avatar
Start parting it out and I will take the air filter and air box thingy.
levnubhin is offline
Old 05-06-2008, 12:22 PM
spike's Avatar
This is a very sweet deal! I'm suprised this is still around.
spike is offline
Old 05-06-2008, 01:56 PM
Leebo's Avatar
Sorry, I'm not interested in parting this kit out.
Leebo is offline
Old 05-06-2008, 02:05 PM
levnubhin's Avatar
I understand, but if it does come down to that I have dibs on filter and box.
Old 05-07-2008, 07:39 AM
fmowry's Avatar
Bump for Lee. He's been around a long time. Maybe even the Miatapower mailing list days?
Lee, I'm in the midst of a V8 swap (LS6) into my '01. Time for something different, huh?
Frank
fmowry is offline
Old 05-07-2008, 08:35 AM
mike_671's Avatar
This is a good deal. Try ebay since your not getting bites here. Or m.net
mike_671 is offline
Old 05-07-2008, 09:54 AM
Saml01's Avatar
Id be interested in the turbo. I have this nagging feeling mine is going to **** me hardcore.
Saml01 is offline
Old 05-07-2008, 10:14 AM
Leebo did you weld the wg flapper shut to use the external gate or how are you keeping it closed.
Old 05-07-2008, 10:15 AM
Saml01's Avatar
Probably welded, fuggeddaboutit.
Saml01 is offline
Old 05-07-2008, 11:33 AM
Leebo's Avatar
Frank
Thanks Frank. Yep, I did the turbo thing on my miata since about 1997 and although it's been great (absolutely no regrets), it's just time for something different and the V8 bug has bitten. Doing a 331 stroker on mine. Good luck with the LS6! See you on the Engine Conversion forum.
Thanks Mike. I just gave ebay a shot and even started it a hair lower. Got over 600 hits, 35 people watching, a few unacceptably low offers and... zero bids. I've put it on miata.net a couple times and it seems like items don't sell on there as well as they did years ago.
In all honesty, I'm pretty amazed it hasn't gone in a hurry. I'm not sure if I just haven't advertised this right or some folks don't really understand what they are getting with this deal. Except for the electronics, this is a very complete kit (which is a big reason why I don't want to part this out). With all of the electronic options there apparently are today (Megasquirt, Bipes, Link, TEC, etc...) it seems this would be a great kit to have with all those options wide open to the new buyer. Whoever buys this is going to be very pleased.
Yes, it's welded shut. This turbo kit (and most of the other parts) actually came straight from Corky Bell years ago when I was getting out of a BEGI Aerodyne turbo system I used to run. Corky removed the intregal wastegate actuator and welded the door shut. My downpipe also has a bolt hole in the turbo flange with a bolt going up against the wastegate; this is sort of a "belt and suspenders" thing.
Leebo is offline
Old 05-07-2008, 11:53 AM
Rafa's Avatar
Lee, hang in there; you're selling a really good kit for a very good price
If I were a noob with an early NA I'd be all over this!
Guys, I've dealt with Lee; he's well organized and his instructions are top notch. I know you can count on his assistance anytime.
Rafa is offline
Old 05-07-2008, 02:58 PM
Antisaint
Vashthestampede's Avatar
Total Cats: 58
I might be getting this from you if its still around. I just came into some funds and I'm willing, I just need to do some research first. This is too good of a deal....really. You don't know how hard I had to hold back from clicking the bid button on ebay! lol
My only problem is that I would need to somehow make this work with my current emanage and 1.8 injectors. I don't have the time nor money to redo everything. If I could just slap this on in place om my greddy stuff and be done with it...then I might be talking to you soon.
Vash-
Vashthestampede is offline
Old 05-07-2008, 03:09 PM
Leebo's Avatar
Vash-
Send me a PM and let's talk. I'm pretty sure your current fuel system would be a non-issue as all of the parts in this kit are independent of the fuel delivery and management system. Since I am not familiar with your emanage system, does that use a MAP sensor, or do you use the factory mass air flow sensor?
Lee
Leebo is offline
Old 05-12-2008, 12:32 AM
Leebo's Avatar
Sale pending.
Leebo is offline
Quick Reply: FM3 Turbo Kit minus electronics
