Mouglie's Engine Rebuild
Old 05-25-2008, 01:47 PM
Mouglie's Avatar
Default Mouglie's Engine Rebuild
I plan on getting my engine rebuilt so I can boost it but i have never done this before so i've had several friends give me advice as to what to expect.
I ordered the turbo pistons that flyin miata offers and it says 2mm overbore. Does this mean the cylinder in the block has to be bored 2mm for the piston to fit?
Right now i'm looking around town for machine shops to get some head work and see about getting my pistons installed.
i'd greatly appreciate and ideas or comments about building this engine
the right way to handle some boost...
Mouglie is offline
Old 05-25-2008, 02:48 PM
wes65's Avatar
yeah, they do overbore so that you can clean up the cylinder walls by boring it out 2mm.
wes65 is offline
Old 05-25-2008, 03:49 PM
Saml01's Avatar
Hey Mouglie, are you Russian?
Saml01 is offline
Old 05-25-2008, 03:54 PM
crashnscar's Avatar
Total Cats: 9
You don't know what an overbore is and you are planning on building the motor yourself?
Good luck.
I'd say go to a engine builder near you with a good reputation, give him all the parts and come back with a motor you can drop in. Unless you are willing to spend countless hours reading up on **** and learning, and very possibly pulling it back out to re-do once you figure out something isn't right or you loose compression after a thousand miles.
crashnscar is offline
Old 05-25-2008, 04:15 PM
Total Cats: 3,481
hey sam, are you?
18psi is offline
Old 05-26-2008, 01:58 PM
Mouglie's Avatar
no Sam, i'm hispanic.
but i love the girls from TATU, lol...
crashnscar: i know what bore is, that stuff i'll leave to the machine shops to handle. The only thing i'm taking care of is tightning screws and bolts which doesn't take a genious to figure out (sorry not trying to be rude). I have a main idea of how it works and whatever i don't i will look for help or read. Thats how I learn.
The pistons came out the block yesterday and the main bearing showed signs of wear and tear, not to bad but enough that i have to get so work done to the crankshaft, new main bearing and the piston bearings...
Is it better to buy a new crankshaft or just get mine balanced?
Mouglie is offline
Old 05-26-2008, 02:11 PM
silentbob343's Avatar
You managed to **** up the easy task of using a headgasket repair solution which is what prompted this rebuild. I have to wonder if you are capable of tightening bolts and measuring clearances.
silentbob343 is offline
Old 05-26-2008, 02:15 PM
Mouglie's Avatar
the rebuild was gonna happen for my turbo, this incident just hurried the process. I know about measuring and clearance, you use plastigage for that, i've never used it but i'll get some help putting it back together. I'm being extremly careful now, lol...
Mouglie is offline
Saml01's Avatar
I asked because Mouglie is the name of the main charachter in a very famous Russian children's movie.
Saml01 is offline
Old 05-26-2008, 02:20 PM
Mouglie's Avatar
Sam: we got the bear necessities the big and bear necessities, all of mother natures recipies... lol...
If you guys have experience building up engines, i wouldn't mind any advice right about now... here is some pics of my engine so far... i can't do more because of memorial day weekend, every shop is closed...
oil pan ready to get tapped
pistons are way lighter than i imagined
there's a guy here in town with a 323 and wants to build up his engine so he is interested in buying my stock pistons... i wouldn't know what to price them.
Mouglie is offline
Old 05-26-2008, 02:24 PM
Mouglie's Avatar
a new set of mazdaspeed motor mounts in the mail...
Mouglie is offline
Old 05-26-2008, 03:08 PM
Total Cats: 3,481
comin along nicely
18psi is offline
Old 05-26-2008, 03:14 PM
Mouglie's Avatar
i know there's many that just eliminate the ac but i really want to keep it, so i'll have to place the oil pan on the block and the ac bracket so i can figure out what would be the best location for my oil return line tap. I'm thinking about having two fittings, a 1/2 to 10an and then a 10an to 5/8 barb fitting so i can hook up a rubber line for now. if i ever wanna upgrade to a stainless steel line i just eliminate the barb fitting...
Mouglie is offline
Old 05-26-2008, 03:24 PM
Mouglie's Avatar
another thing is i haven't installed any gauges and i'm not a big fan of the a pillar gauges, nothing wrong with them its just that i wanted to go with a sleeper style... so i plan on having my gauges installed before the turbo goes in... so far here is what i got.
fiberglassed my whole dash and
wrote what i wanted and where... mock up
this is where my gauges will be, all angled towards me
and a little bit closer to me and lower...
here its fiberglassed and i'm just waiting for it
to cure so i can proceed...
Mouglie is offline
Old 05-26-2008, 03:32 PM
Mouglie's Avatar
they are all digital gauges except for the boost, they will be behind a plexiglass piece tinted 50% so you can only see them when they are on. i need to finish the hood for it and i can start sanding it for paint. I'm thinking about Flat black...
Mouglie is offline
Old 05-26-2008, 03:36 PM
You want your V1 shoved into the dash?...
I'll keep mine up in the windshield where it will, like, work and stuff.
kotomile is offline
Old 05-26-2008, 03:40 PM
Mouglie's Avatar
Default V1
the v1 will be mounted behind the rear view mirror, i have a remote view screen that came with my V1 so that one is a radar and the other is a display. so yeah, i want the display lower so ppl behind me don't see it.
they call it the concealed display if you wanna check it out
http://www.valentineone.com/
Mouglie is offline
Old 05-26-2008, 03:46 PM
Stealth97's Avatar
Total Cats: 66
so youre going to block the windshield with gauges?
Stealth97 is offline
Old 05-26-2008, 03:51 PM
Mouglie's Avatar
lol... it looks higher than what it will be. its still a work in progress. Total will be 4 inches from the normal dash.
it was placed there as a mock up to get an idea of what it'll look like but the gauges will be lower and a bit closer. You won't notice them when i'm finished... (well thats my goal)
Mouglie is offline
Old 05-26-2008, 04:05 PM
Pitlab77's Avatar
+1 on the number of gauges
Pitlab77 is offline
Quick Reply: Mouglie's Engine Rebuild
