Terms people use when talking Turbos
Old 10-22-2004, 01:16 PM
White Roadster's Avatar
Exclamation Terms people use when talking Turbos
We should make a thread on the the terms that people use for Turbos. Once it is done we can move it to the archives forum. Please add to the terms, and definitions.
Terms for Turbos:
Spool up (process of the turbine spining up to speed)
Heatsoak (Basically the intercooler gets heated enough that it can no longer do its job well.)
FPR (Fuel Pressure Regulator)
AFPR (adjustible Fuel Pressure Regulator)
Turbo Lag (delay between you pressing the gas pedal, and the turbo spooling up. Commonly confused with Boost Threshold (below), lag refers only to the delay between pedal application and production of boost when the engine is already above the boost threshold. )
Boost Threshold (Simply put, the RPM below which not enough exhaust gas energy is available to spin the turbine and produce positive manifold pressure. Larger turbines with higher A/Rs have higher boost thresholds.)
Bipes (An ACU used to controll timing)
MBC (Mechanical Boost Controller)
Wastegate (Valve on exhaust side used to divert exhaust flow from manifold directy into the exhaust pipe, bypassing the turbine)
IC or I/C (Intercooler)
Link (Full replacement programmable ECU)
ECU (The computer in the car)
HPFP (High Pressure Fuel Pump)
Jim's Pipes (Pipes made by Jim at www.15psi.com for I/C's)
Begi (A brand of AFPR)
Vortech (A brand of FPR, comes stock with the kit)
Disks (Changeable disks inside the Vortech, used to change the fuel pressure)
DP (The Downpipe)
Please add to the definitions, and terms.
Last edited by Joe Perez; 08-29-2009 at 02:59 PM. Reason: Add Boost Threshold, clarify Lag.
White Roadster is offline
Old 10-22-2004, 05:56 PM
MiataNuTca's Avatar
Total Cats: -2
BOV (Blow off valve- releases the leftover pressure in your intake plumbing when your throttle body closes. Keeps the turbo spooling for less lag between shifts.)
VTA (Vent to atmosphere- term used when talking bov's. This usually gives your car a whoosh sound or whistle between shifts. Some benefits are: cool sound, and cooler than "recirculating" temps for non intercooled cars)
Recirculating (Instead of venting to atmosphere the excess pressure flows back to your air fuel meter. Some benefits: better gas milage and very quiet- stealth like.)
MiataNuTca is offline
Old 10-25-2004, 11:35 PM
Boost creep is rising boost due to not enough exhaust bypassing the housing. For example, you're set for 13 psi, and when you floor it, you get a quick rise to 13 or 14 psi. But then as rpm's climb, the boost creeps higher and higher: 14, 15, 16, 17, etc. Enlargening the wastegate hole is one cure for boost creep.
Old 10-27-2004, 10:34 AM
BravoHotel
Guest
Posts: n/a
Clocking the turbo??? Can you explain?
BH
Old 10-27-2004, 10:53 AM
imported_philip_g
Guest
Posts: n/a
BH
more or less just rotating the housing so the outlet faces where you want
Old 10-27-2004, 11:19 AM
BravoHotel
Guest
Posts: n/a
So if someone says "Clocked 15g", what does that mean?
BH
Old 10-27-2004, 11:46 AM
AFM Crusader
olderguy's Avatar
Total Cats: 337
http://whereyou.at/greddyfaq/viewtopic.php?t=17
for the difference in Greddy turbo compressors
olderguy is offline
Old 10-27-2004, 08:39 PM
BravoHotel
Guest
Posts: n/a
Got it. Thanks
BH
Old 10-27-2004, 11:01 PM
Pop VII's Avatar
Just a few comments.
AFPR (Auxiliary Fuel Pressure Regulator). A second regulator added to supplement the stock FPR. Example is the Vortech supplied with the basic kit (where applicable).
Adjustable AFPR. Self explanatory. Rather than a fixed rising rate, has multiple adjustable features for better fuel management. Two examples of this are the BEGI and Vortech Super FMU.
FMU (Fuel Management Unit). If you hang with the Honda people or with Greddy's on other OTMs it is probably called a FMU rather than an AFPR.
BEGI. (Bell Engineering Group Inc.) Formerly known as Car Tech. They also developed a turbo kit to fit the turbo from Aerodyne Dallas. Had several names for this kit which included Aerodyne Stages I, II, and III, Aerocharger, TeamProscreen, and Aeromax.
VATN. (Variable Area Turbine Nozzle). Unique feature of the Aerodyne series turbo. The vanes of the turbo opened and closed for a super fast spool up and maintained a rock steady boost level. Did not use a conventional type wastegate but a series of pistons, spacers, and springs. Not adjustable without taking it apart and adding a different configuration. The system was fairly complicated and did not prove reliable for Miata use. Currently not produced for the Miata.
Pop VII is offline
Old 08-29-2009, 11:54 AM
motion to add "boost threshold" referring to "positive MAP"
clarify "lag" to include "boost threshold"
k, thx, bye
Old 08-29-2009, 02:58 PM
Total Cats: 6,608
dun.
Joe Perez is offline
Old 08-30-2009, 10:21 PM
emilio700's Avatar
Total Cats: 2,376
PTFB Part Throttle Full Boost
IAT Intake Air Temperature
BSFC Brake Specific Fuel Consumption. A measure of fuel consumption against power output. Used to plan the needed fuel supply.
BMEP Brake Mean Effective Pressure. Describes the average psi on the piston through the power stroke. In F/I apps, used to help predict detonation.
EGT Exhaust Gas Temperature
MAP Manifold Absolute Pressure
AFR Air/Fuel Ratio
"Stoich" - Stoichiometric Optimum air fuel ratio for maximum combustion pressure for a given fuel
V Band Method for connecting intake and exhaust piping using interlocking flanges.
OK, Toaster oven just dinged. Pizza is ready. Gotta go!
www.facebook.com/SuperMiata
949RACING.COM Home of the 6UL wheel
.31 SNR
emilio700 is offline
Old 08-31-2009, 02:04 AM
Total Cats: 3,481
necro post is necro lol
18psi is offline
Corky Bell
Prefabbed Turbo Kits
11-22-2016 09:01 PM
jpreston
05-17-2016 12:51 AM
shooterschmidty
8
09-30-2015 10:28 PM
JesseTheNoob
09-30-2015 02:44 PM
Quick Reply: Terms people use when talking Turbos
