do it once, do it right.
Old 06-22-2006, 04:41 PM
kung fu jesus's Avatar
Default do it once, do it right.
this is how to dress a turbo.
no leaks, no cracked rubber tubing.
just have to cut and flare my aluminum tubing for the coolant lines.
kung fu jesus is offline
Old 06-22-2006, 05:13 PM
dc2696's Avatar
Total Cats: 21
looks good.
dc2696 is offline
Old 06-22-2006, 05:32 PM
bripab007's Avatar
What size is that return line?
bripab007 is offline
Old 06-22-2006, 05:35 PM
nester's Avatar
looks like a -8 or 10.. aka, pretty big.
nester is offline
Old 06-22-2006, 05:48 PM
F20turbo's Avatar
thats pretty nice. I use a regular old rubber hose for my return and it never leaks on me though.
F20turbo is offline
Old 06-22-2006, 06:43 PM
the return is -10an.
the rubber lines will harden and crack over time from the heat. i helped a friend replace his a few weeks ago. they looked alright but when we flexed them, the split. no worries on this one.
Old 06-22-2006, 07:10 PM
Loki047's Avatar
Total Cats: -5
If you use garden hose or something, but I cant imagine a problem using a rubber hose rated for the temp.
But Pretty Turbo.
Loki047 is offline
Old 06-22-2006, 07:18 PM
no, the hose was heat rated and triple ply.
Old 06-22-2006, 07:44 PM
dv/dt's Avatar
Don't use solid aluminum tubing for your lines. It'll stress fracture.
Stainless tubing is the way to go, but it's really hard on the flaring tools.
FWIW,
Jon
dv/dt is offline
Old 06-22-2006, 08:01 PM
druz's Avatar
Why not SB hose for the coolant lines also?
druz is offline
Old 06-22-2006, 08:36 PM
dv/dt's Avatar
That wouldn't be a problem either. However, KFJ said he was using aluminum tubing.
dv/dt is offline
Old 06-22-2006, 09:10 PM
druz's Avatar
Cool, I forgot to ask when seeing the pics of your setup and wondered if there was a particular reason why you didn't use it. Seeing another setup without it I figured I better make sure there wasn't a good reason.
druz is offline
Old 06-22-2006, 09:30 PM
dv/dt's Avatar
I'm just lazy. I only wanted to do it once, and not have to worry about it for 60K miles...and stuff and junk.
dv/dt is offline
Old 06-22-2006, 10:20 PM
bripab007's Avatar
Kewl...it looks small for 5/8" to me for some reason. Maybe the turbo's just really big
Old 06-22-2006, 10:38 PM
rmcelwee's Avatar
Nice WG can bracket. Where'd ya get it? What brand/part#/etc?
I took a straight aluminum bracket and beat the hell out of it for a day or two to get it to fit right.
rmcelwee is offline
Old 06-22-2006, 10:59 PM
i'm using aircraft grade, mil-spec aluminum tubing. the tubes are probably ~ 4" each, far enough away from the turbo to keep the rubber lines from cracking. i don't want to use SB on the coolant lines because of where they run and their abrasiveness. maybe down the road, i'll consider it...when i make SB fuel lines. swapping SB on the coolant lines will be a snap with teh AN fittings.
that's a t25r (gt2554r), it's not that big of a turbo.
the actuator mount is from ATP turbo. i didnt' know if it was going to work with my compressor orientation, but is worked perfectly. i'm happy with it.
Old 06-22-2006, 11:32 PM
Loki047's Avatar
Total Cats: -5
Well obviously misrated or POS hose. Coolant hoses see probably similar temps, specially those for turbo.
Loki047 is offline
Old 06-22-2006, 11:53 PM
bripab007's Avatar
Humor not getting across on the ol' intarweb, huh?
Old 06-23-2006, 06:54 AM
feh. looong week. sorry.
Old 06-23-2006, 08:14 AM
bripab007's Avatar
It's all good Looks great, man!
Quick Reply: do it once, do it right.
