what is easy way to remove front bumper
Old 02-01-2007, 09:17 PM
left field's Avatar
Default what is easy way to remove front bumper
i figure i would ask before i begin. i going to build proper brackets to mount my intercooler to, but before i start unbolting unnecessary things what is the simplest/fastest way to pull off the bumper?
left field is offline
Old 02-01-2007, 09:20 PM
SamS's Avatar
I followed the instructions in my Haynes manual to take mine off. As always, it had a couple of unneccesary steps, but I don't remember what they were any more. It's fairly self-explanatory once you start looking around in and under there.
Hope that helps:gay:
SamS is offline
Old 02-01-2007, 09:29 PM
left field's Avatar
i have no manual. i was feeling lazy and figure i ask instead of figuring it out on my own. so far i have gotten 90% of my diy system done using only the info from this site. scary isn't it.
Old 02-01-2007, 09:37 PM
SamS's Avatar
Here's what I found after a quick search:
Posted by Lola
#10 bolts on the top (There is a black kind of large rail that is holding the top of the cover on - Easier to remove this rail along with the cover).
#10 hex screws on the bottom - Three plugs in the middle at air intake
4 ea. #10 nuts on the inside of wheel well & remove inside braces on the inside of the wheel well.
disconnect your side lights - Remove them if you wish.
remove the front wheels and the inner skirts so you can get to the 4 #10 nuts that hold the bumper cover onto the front fenders
SamS is offline
Old 02-01-2007, 09:41 PM
left field's Avatar
thank you very much
Old 02-01-2007, 09:52 PM
miatamania's Avatar
I've never removed the wheels...
just reach under and get the nuts.
miatamania is offline
Old 02-01-2007, 09:55 PM
SamS's Avatar
I forgot to add that, i didn't remove my wheels either
SamS is offline
Old 02-01-2007, 11:47 PM
SamS's Avatar
Nice work, Mike!
SamS is offline
Old 02-02-2007, 12:24 AM
miatamania's Avatar
Originally Posted by MikeD
Here, hope this helps! Didnt mark screws for the line, or the plastic dealy behind the bumper.
heh, nice.
first time I could not find the second nuts in the fender wells...that was frustrating.
Old 02-02-2007, 01:22 AM
Hard4Hardtops's Avatar
Dude I had the hardest time trying to remove those
Hard4Hardtops is offline
Old 02-02-2007, 09:12 AM
Jefe's Avatar
I found the easist way was to put the car up on the lift and go to town with a 10mm socket and air ratchet...
Sorry, couldn't resist...
Jefe is offline
Old 01-26-2010, 07:49 AM
Krullert's Avatar
Hey so im retarded but pleace help me. I HAVE SEARCHED, cant see any pics.
I tried to remove the front bumper cover on mine but its stuck somwhere.
Those red dots ive removed. The blue one, is screwed from the wrong way, does it need to be removed? In that case how?
Is there any bolts ive missed?
// Nick
Krullert is offline
Old 01-26-2010, 08:26 AM
Antisaint
Vashthestampede's Avatar
Total Cats: 58
// Nick
The fender area where you have the blue mark, should have 2 screws. And they are removed by going in from under the fender. NOTE: At least my Bomex bumper has 2 there. I assume the stocker does as well, but I might be mistaken.
Either way, removing the bumper should be a cake walk. If it starts getting hung up on something, just pull like a **** on it.
Vashthestampede is offline
Old 01-26-2010, 08:29 AM
thagr81 us's Avatar
^ IIRC this is correct. I remember I was able to get to them quite easily with the headlight assemblies out of the car. However, I was completely tearing down the car, so they were coming out anyways...
thagr81 us is offline
Old 01-26-2010, 09:57 AM
Krullert's Avatar
So there shouldnt be anything more but where the blue is?
Yeah i removed a nut from there, i can see a bolt too but it seems like its been mounted from the inside of the bumper :S
Do you mean i can reach it through the wheel well?
Krullert is offline
Old 01-26-2010, 10:01 AM
Gotpsi?'s Avatar
This is the easiest way to remove your bumper. YouTube - pull my bumper off in snow
Gotpsi? is offline
Old 01-26-2010, 10:33 AM
Cococarbine3's Avatar
You are missing 2 nuts in the area where the bumper meets the side panels. They are a little hard to reach, but they are found by going underneath.
That blue nut is one that is needed to remove the side panel. This is a PITA because if you have to remove the side panel, you have to remove the bumper to reach it.
http://s81.photobucket.com/albums/j2...nder%20repair/
EDIT: nvm didn't read Vash's post
Cococarbine3 is offline
Old 01-26-2010, 10:58 AM
Krullert's Avatar
WTH, do i need to remove the front fender/wing to get to them? Ill go and check it out if i can get to them, but one thing is for sure, i dont need to remove the wheels right?
Thanks for the pics id never know about those bults!
Krullert is offline
Old 01-26-2010, 11:10 AM
thagr81 us's Avatar
No need to remove the wheels...
Old 01-26-2010, 11:11 AM
No and no. Just look up from underneath (undertray removed). They're right there, 10mm I believe.
Quick Reply: what is easy way to remove front bumper
