Manual or depower rack?
Old 05-22-2009, 07:54 PM
mojoriffic1's Avatar
Default Manual or depower rack?
I am installing my Energy Suspension bushings (THANKS EMILIO!) on my turbo NA this weekend, and while I have it on the rack I am going to:
A. Depower the rack using the loop method (done it before)
B. Install the manual rack I have off another car
I have read on both, but I have never seen the question asked like this.
Which do you prefer, and why?
mojoriffic1 is offline
Old 05-23-2009, 12:29 AM
I like the power rack's ratio, so depowered power rack for me.
kotomile is offline
Old 05-23-2009, 12:33 AM
I'm a terrible person
FRT_Fun's Avatar
Total Cats: 180
I just purchased a manual steering rack. The reason I went with the manual steering rack is that it is smaller/lighter then the depowered rack, also from what I have read, there is less resistance then a depowered rack.
I don't have any first hand experience, this is all just what I have heard, I can tell you for sure in about 2 weeks.
FRT_Fun is offline
Old 05-23-2009, 12:35 AM
UrbanSoot's Avatar
Total Cats: 18
i like power steering personally
UrbanSoot is offline
Old 05-23-2009, 01:54 AM
miatamania's Avatar
This.
What do you mean lighter/smaller...?
miatamania is offline
Old 05-23-2009, 02:00 AM
FRT_Fun's Avatar
Total Cats: 180
I was told by the shop that I bought it from that it was smaller, as in diameter I think, as well as lighter, and that he will ship the mounting brackets that was used on the car because the p/s rack ones will not work. Like I said this is all what I have heard, I will have some comparison pictures when I have both out.
I can't imagine that a manual rack would be the same size/weight as the powered one. So this made sense to me. We will see I guess.
FRT_Fun is offline
Old 05-23-2009, 12:00 PM
Thanks guys. From looking at the two racks, the manual one looks like it would be lighter b/c the housing is smaller, and fewer internal parts. I will try to take comparison shots too.
But I have decided my course of action. I am going to remove my power rack and most likely send it to Maval Mfg. to get it depowered. That is if they will weld the pinion gear when they depower it. I am doing this b/c I spoke with Emilio and he suggested that when depowering the rack you will get ultimate steering response when the pinion is welded b/c otherwise there is a small amount of "slop". This, and I am paraphrasing, is b/c the pinion in a power rack actuates a valve to direct fluid according to which way you are turning. Since you no longer need to direct fluid one way or the other, it is best to remove that from the steering system. I hope that makes sense.
Old 05-23-2009, 12:23 PM
I and all my friends run depowered racks and love it. Take caster out if the wheel is too hard to turn. I run 4* and I've driven 6* cars before and it was much more of a work-out.
Old 05-23-2009, 02:17 PM
So far fate has not let me depower a good rack, so I can't comment on the difference in feel between looped and truly depowered, but my new looped '97 rack (which I couldn't depower, but packed full of grease anyway) feels much better than my dirty '93 rack.
My caster's around 5.5*, I don't think it's all that difficult.
kotomile is offline
Old 05-23-2009, 02:24 PM
you have to consider that our arms are like a glorious mountain range and most faegs on here rock spaghetti wimpy ****.
Old 05-28-2009, 08:18 AM
Doppelgänger's Avatar
Total Cats: 71
I loved the de-powered rack on my 96....and that was with a 320mm steering wheel. It truely felt like a go-cart.
Doppelgänger is offline
Old 05-28-2009, 09:53 AM
gospeed81's Avatar
Total Cats: 26
Depower....just do it....never look back.
Unless you just don't like to listen to what your car is trying to tell you about the road.
I had PS, so was used to the ratio, and just looped the lines. At first a little tough under 5mph, but you learn to automatically turn the wheel just a little as you are rolling up to a stop, and a little time in the gym doesn't hurt when it comes to parking effort.
gospeed81 is offline
Old 05-28-2009, 12:42 PM
nicacus's Avatar
Depower.. I've had both looped and "proper" I couldnt tell the difference.
Having depowered steering also keeps people from wanting to drive your car, mostly because they are pussies. This alone is worth depowering.
nicacus is offline
Old 05-31-2009, 05:44 PM
BlownRoadster's Avatar
Another vote for depower. Love the quicker ratio.
BlownRoadster is offline
Old 05-31-2009, 08:34 PM
Cspence's Avatar
Is this a pic of you hussla??
Cspence is offline
Old 06-01-2009, 08:59 AM
adamf's Avatar
I de-powered mine by the FM method (cutting the seals out inside and plugging all the fittings) and I'm very happy with it.
adamf is offline
Old 06-01-2009, 10:17 PM
l_bader's Avatar
And yet another vote for depowering...
l_bader is offline
Old 06-01-2009, 11:13 PM
tann3r's Avatar
I'll put another vote for the depowered rack. I did the FM method and plugged the holes.
I'm running 6.5* of caster and its on the heavy side on the street (skinny azenis), but awesome on the track (big NT01s).
tann3r is offline
Old 06-01-2009, 11:20 PM
cardriverx's Avatar
Man, im excited to get my car back on to its wheels and try out the depowered rack.
cardriverx is offline
Old 06-06-2009, 04:30 PM
zxc4's Avatar
my old NA was looped and I did not like it. Why do you want to take out the PS?
zxc4 is offline
Quick Reply: Manual or depower rack?
