Finally got Dyno Tuned
Old Oct 26, 2007 | 01:16 PM
krayzrac3r's Avatar
Guest
Default Finally got Dyno Tuned
So I finally dyno tuned the car. Too lazy to scan sheets right now or anything but here goes.....
1990 Miata
15G turbo @ 13psi
2.5 turbo back to an OBX muffler
550cc Injectors
Megasquirt PNP
91 Octane
Boost was controlled by a MBC
209whp and 196wtq On a dynapack dyno
I did a compression test on the motor and these were the numbers i got starting from the cylinder nearest to the radiator
150-155-155-170
Does that seem normal guys? Only thing Im complaining about is I was getting full boost by 4500 RPM. That is RIDICULOUSLY LATE for a small turbo. I need to get rid of that muffler and get more runs and take the boost up a notch
Old Oct 26, 2007 | 01:22 PM
Snowsurfer03's Avatar
bigger downpipe!
good luck brother!
Old Oct 26, 2007 | 01:28 PM
krayzrac3r's Avatar
Guest
I originally wanted to get a 3" turboback but everyone clowned me and said that its too big for a turbo thats too small but i still think its that stupid muffler thats robbing power.
Old Oct 26, 2007 | 01:32 PM
post the graph
Old Oct 26, 2007 | 02:01 PM
TurboTim's Avatar
Total Cats: 425
I got 220's compression numbers warm on my 150xxx mileage (turboed for 60xxx miles) 1.6. Never checked the 1.8.
Old Oct 26, 2007 | 02:04 PM
Al Hounos's Avatar
i think yer engine is wore out
Old Oct 26, 2007 | 02:10 PM
Loki047's Avatar
Total Cats: -5
run it till it dies. Thats what I am doing
Old Oct 26, 2007 | 02:13 PM
krayzrac3r's Avatar
Guest
so you guys think my engines about to take a dump? lol I dont mind because i have a 1.8 motor sitting in my garage.
Old Oct 26, 2007 | 02:18 PM
krayzrac3r's Avatar
Guest
btw my mileage is at 125k
Old Oct 26, 2007 | 03:10 PM
Arkmage's Avatar
compression numbers are low... I get roughly 180 across all cylinders and I seem to recall the 1.6s ran slightly higher (190-200).
Do a leak down test... may just need your valves/seats cleaned up.
Old Oct 26, 2007 | 03:14 PM
if i were to guess, i'd say that #4 has bad rings.
Old Oct 26, 2007 | 03:17 PM
Slidin'Miata916's Avatar
Do you say that because since it has bad rings, it let oil through, and thats why it reads a littler higher?
Old Oct 26, 2007 | 03:50 PM
something along those lines.
Old Oct 26, 2007 | 03:56 PM
Loki047's Avatar
Total Cats: -5
Personally all i cared that the numbers were around the same, and they werent spectacularly low. But thats just my rule of thumb.
Old Oct 26, 2007 | 03:58 PM
krayzrac3r's Avatar
Guest
hmm im considering selling my 1.8 motor and buying a used 1.6 motor with low miles to drive aroudn with at 14-15 psi because Im really happy with the cars speed right now. 1.8 motor i will end up spending too much money on the car and bigger turbo and what not....my dream is still to own a z06! lol
JasonC SBB
ECUs and Tuning
11
Oct 27, 2015 04:56 PM
The Gleas
Oct 1, 2015 09:30 AM
