I can't drive time slip
Old Apr 18, 2009 | 01:55 PM
jtothawhat's Avatar
Default I can't drive time slip
Well last night it was T&T at the local track, so I thought i'd go out and see if I could drive...Well the end result is I CAN'T or it's just the fact that I get no traction. It just sucks knowing your car is so much faster than these other cars yet you put on a poor performance, oh well here is the run down on what I ran. Granted my car is tuned to 28 pounds of boost, but all I could run last night was 20-21 pounds due to spinning at the top of 4th gear at over 110 MPH.
15 PSI run I make about 270 whp at 15 psi
Reaction: .7828
60 foot: 2.6032 <-LOL
330 ft: 6.3774
1/8 ET: 9.234
1/8 MPH: 88.18
1/4 ET: 13.6693 <-Sucks
1/4 MPH: 108.44
20-21 PSI run, even worse performance
Reaction: .6549
60 foot: 2.5700
330 ft: 6.2981
1/8 ET: 9.1602
1/8 MPH: 88.05
1/4 ET: 13.4990
1/4 MPH: 115.9
I think I should have trapped over 120 MPH at that boost level but it felt like I was on ice the whole track, I was on 205/50/15 Falken Azienez about 30 pounds of pressure.
I need to set up my 2 step launch control, and get some slicks...
Old Apr 18, 2009 | 02:22 PM
wes65's Avatar
Yeah, your conclusion is correct. You cant drive. Keep it up, you will get faster.
Old Apr 18, 2009 | 03:16 PM
work on those launches man, a 2.5+ '60 is horrible for a FWD let alone a RWD. your car definitely has some better times in it. trap speeds of 115+ are very impressive in my book
Old Apr 18, 2009 | 03:22 PM
NoCrash's Avatar
What track in IL?
Old Apr 18, 2009 | 03:29 PM
jtothawhat's Avatar
It was Coastal Plains Drag Way in NC, it's where i'm stationed now. The launch is killing me though it seems any higher rpm launch the tires light up, any lower I bog out.
Old Apr 18, 2009 | 03:46 PM
What sort of clutch? You need grippier tires with fewer psi in them.
PS - You said "stationed". What branch?
Old Apr 18, 2009 | 04:19 PM
jtothawhat's Avatar
Marine Corps, getting out in about a month :-D
I have a Spec stage 3+
I was told radal street tires don't really do much when they have less air in them because the sidewalls being so stiff, I really didn't care to find out either.
Old Apr 18, 2009 | 04:24 PM
IIRC Azenis aren't known for having stiff sidewalls. Lowering the psi is worth a shot though, it's free, and you definitely need more traction.
Good luck when you get out, you have a job lined up right?
Old Apr 18, 2009 | 05:16 PM
turbomclovin's Avatar
damn that moves
Old Apr 18, 2009 | 05:41 PM
jtothawhat's Avatar
Good info, it will be worth a shot. What PSI do you recommend?
As far as jobs, I have applied to a few places. You offering a job? lol but i'll be medically retired, it will give me 50% base pay income plus medical and that good stuff and I can pocket the GI bill going to school in IL. So it's a win win situation.
Old Apr 18, 2009 | 06:28 PM
Nope I don't have a job for you, I'm in the Army myself.
I'm no drag expert, I just know that 30 seems a bit high.
Old Apr 18, 2009 | 11:36 PM
ApexOnYou's Avatar
Nice trap speed.
FWIW, try lowering the pressures to 28 or 26, I haven't dragged on Azenis in two years but I am pretty sure I was in the high 20s when I did. Although they have a reputation for getting "slimy" when they are hot, definately put some heat in them, but they have 1.8sec 60ft potential if you can slip the clutch a bit.
Old Apr 19, 2009 | 01:38 PM
jtothawhat's Avatar
I just think I need to work on my launches, after the 60' im good with the exception of me spinning at the top of 4th gear but I really can't do much about that other than get better tires. I would love to be able to cut 1.8X 60's though with them, can you explain how you did that...launch RPM, clutch anything that could help? Thanks!
Old Apr 19, 2009 | 07:33 PM
ApexOnYou's Avatar
I don't remember exactly what I was holding the RPM at, but I believe it was between 4K and 5K, slipping the clutch off the line (1/2 sec max). You'll just have to play with it to see what exactly works for you, I spent some time out on a county road in the middle of nowhere practicing slipping the clutch- it feels horribly wrong at first. I didn't have any issues with wheel hop launching on those tires, but my spring rates are pretty stiff if that even matters any.
Old Jun 4, 2009 | 08:35 PM
JETSWU87's Avatar
need more rubber no doubt, i mean 205's and 300whp dont mix.
Old Jun 4, 2009 | 08:58 PM
mrtonyg's Avatar
Total Cats: -2
Power and no way to put it down = time to go back to the drawing board
Old Jun 4, 2009 | 09:28 PM
ARTech's Avatar
Total Cats: 10
Koto, that may have been a typo, because azenis, DO have a stiff sidewall, that's what makes them good for auto-x. lowering the pressure anymore that 30 may make things worse.
A few things that may help with the launch:
better tires, obviously. I'd try dr's before jumping to slicks
soft rear suspension
removing front sway
Since you have an ems, you can also mess with speed/gear based boost control.
Old Jun 4, 2009 | 09:54 PM
pdexta's Avatar
Total Cats: 184
+1 all the driving skill in the world isn't gonna put that kinda power to the ground with those tires. Nice times though, pretty quick miata you got there.
Zaphod
47
Oct 26, 2018 11:00 PM
Quinn
Cars for sale/trade
6
Oct 23, 2016 07:58 AM
shooterschmidty
8
Sep 30, 2015 10:28 PM
interestedofold
Sep 29, 2015 01:42 PM
