Remove
advertisements today by clicking
here and subscribing. Only $3.50 per month. |
Thread Tools |
#1 | ||
Hi All,
Looking for a little edumacation on this. I bought an Built motor/turbo kit and it came with an AEM EMS 30-1710 for 91-95 miata. My car is a 97, are there any mods or harnesses I can buy to make this work? Or is there anyone with a EMS for a 96-97 they want to trade??? |
| Sponsored Links - Subscribe to remove this ad. |
#2 | ||
I would get a hold of this guy:
Boomslang Fabrication - The Performance Wiring Specialists And see if he can make you a harness adapter to go from 97 to 91. I have a 97 motor in my 90 chassis and I'm using the 30-1710. |
#3 | ||
I'm special! Yeah!
Are the harness terminals the same? If so, I would get a 96-97 & 92 harness and move the wires to where they should be. If not, you can either see if Boomslang can make you an adapter harness or make one yourself. You'd need a chassis harness (for the connectors) from a 90-95 car and your oem 96-97 ecu to hack the terminals off of. I've made a few of these adapter harnesses myself; it takes some time, accurate wiring diagrams, and a helper to desolder and solder stuff together.
#4 | ||
wow...I think I'll end up selling it... Boomslang doesn't have anything listed as a harness...
Me and wiring don't get along either.... I think I might end up selling this and picking up adaptronic or something similar...any interest?? |
#6 | ||
I'm special! Yeah!
I found miata 97-94 harnesses on boomslang's site. $150
Custom Work Under extension harnesses they have 97 miatas and 95-90 miatas, so they have the terminals. A simple wiring diagram would be all that's needed for them to make what you need, and they have simple wiring diagrams. It even says "please call for any harnesses not listed". You fail. |
#7 | ||
Generally speaking...
Any ECU that works with a 94-95 will also work with a 96-97. The only significant differences you are going to run into are going to be the order of the pin out. This can be accomplished by moving the pins around on the 96-97's wiring harness, or by building a jumper harness between the 96-97 ecu harness and the 94-95 ECU. |
#8 | ||
....ok.... I fail, and you, Tim, went above and beyond! Thank you!
I will call them Monday to see what they can do...until then...mine is listed for trade... i figured why not... Thanks Ben too! |
#10 | ||
Just got off the phone with Boomslang...
I was told they don't want any part in the conversion harness because there hasn't been much luck in the past with it. So i guess my EMS is still up for trade. |
#13 | ||
It wasn't too bad once you figured out how to. Personally I would just call boomslang up and see if they would sell you connectors/pins and make your own adapter harness if they refuse to. Its much easier to sit on a bench and build it, than hunch over behind your seat repining.
#15 | ||
Red94....that...i will definately do... I was in garage this weekend imagining myself doing this and it hurt thinking about it.
dustinb - Found EMS manuals for the 30-1710(90-95) & 30-1720(96-97). I'll order a female 96-97 connector and a Male 90-95 connector with wires and pins to go into both. Hopefully, all this info will be enough to create a harness on my own from the bench in my basement (and not in the freezing cold garage) if anyone disagrees or has anything else they feel I need.... LET ME KNOW! I heart mt.net
Call me Alex...97 Miata, built bottom end, 1710 AEM EMS, AEM UEGO Wideband, AEM Tru-Boost, GT3076, RC750s, FM cast manifold & downpipe and more THANK YOU MT.NET FOR MAKING THIS BUILD A REALITY! Couldn't have done it without all your help! |
| Thread Tools | |
Clubs |
Import |
Domestic |
Other |
