FS: PART OUT! 1999 Black Turbo NB
Old 01-19-2011, 04:01 PM
Marc D's Avatar
Default FS: PART OUT! 1999 Black Turbo NB
Heres the parts I got up for sale that will be parted out from the car.
New Items added!
Vishnu Dual Feed Frame Rail for NB, includes lines and FP dampener for NBs. - $120
- Bought, but never installed on the car.
AVO Turbo Kit - $1100
- Includes GT2554R ball bearing turbo (water, oil cooled) with slight shaft play, piping, Intercooler, Lines for water and oil, Return lines. Return fitting for oil pan not included (for obvious reasons). Hole on the side of the intercooler coldside for BOV and IAT sensor.
440CC SL9-440 RC Injectors - $160
-Been flowed and cleaned by WitchHunter to ensure proper function.
TrackDog Single Din Angle gauge Pod - $40
- All gauges are sold.
MBC - $10
- Regular ball and spring setup.
EBC - $40
- a MAC Valve that can be used as an EBC solenoid. Good up to 100 psi, if you want to boost that much. Same **** that AEM boost controllers use.
MSKnocksense - $40
No knock sensor included in this one, my NB stock sensor was used.
Genuine 37mm Koyo for NB miatas - $180
- With the trade of your stock NB radiator.
FRONT 4pot Wilwood Kit - $530
- Like new, less than 2000mi. Includes Stainless Steel Brake Lines, Hub centric rings, TRACKSPEED Engineering Brackets, and 11" VW Corrado Rotors. Proportioning valve is NOT included.
Supertech Pistons (3) Bore 83.5mm (overbore 0.5), 9.5:1 Compression - $100
- Bought from someone used, 3 pistons are in excellent condition, but one blew due to failure to WI system. Machinist checked out, good.
2001+ Headlight Conversion (painted black bezel) - 250
Projector Bezels from a Mercedes - $20
- Perfect for a custom retrofit.
Spare MSII
- Pending to Urban Garage
Spare Complete Short Block - 150
- Self explanatory
COPs - $110
Includes harness clips, and 10,000µF Caps.
SOLD:
COPS Mounting plate - Sold to dima88 - Shipped!
RoadsterSport3 Exhaust - Sold Locally
M-tuned Rods - Sold to Astroboy - Shipped!
DAIKEI Hub w/ Airbag Delete - Sold to KJR50 - Shipped!
Rear Cannon Brace - SOLD to RotorNutFD3S - Shipped!
Roadster Sport Midpipe - Sold to Slidder - Shipped!
Jeff's FirstGen KnockBox - SOLD to MiniMe - Shipped!
Replica Nardi - SOLD to a local buyer
HID 9006 35W 6000k - SOLD to TheHak - Local Buyer
Boss Frog Fender Arms- SOLD to justslow - Shipped!
Megasquirt II PNP 1999 - Sold to Jahoo - Pending eCheck - Clears on Jan 31.
FM Frame Rails - Sold to aballonflies - Local Buyer
AEM Wideband - SOLD to Local Buyer
Sticky Pod /w two extensions - Sold to Astroboy - Shipped
Wilwood Proportioning Valve w/ FM fittings - SOLD to Astroboy - Shipped
Ebay Strut Bar - Sold Locally
Glow Shift EGT and Boost Gauges - SOLD to delturcious - Shipped!
NRG Gold Quick Release Hub version 2.0 - Sold to chokeasphyxia - Shipped!
Shipping is not included in prices, unless stated.
Marc D is offline
Old 01-19-2011, 04:15 PM
RotorNutFD3S's Avatar
Total Cats: 30
Shot you a PM on the Cannon Brace.
RotorNutFD3S is offline
Old 01-19-2011, 04:38 PM
yellowihss's Avatar
Pic of the cops mounting bracket please.
yellowihss is offline
Old 01-19-2011, 05:29 PM
tsuyoshi's Avatar
Default like the Roadster sport exhausts.
Hi.
Very interested in the Roadster sport exhaust and mid pipe. As long as it's the roadster sport 3 with 2.5inch pipes.
The mid pipe has a functional Cat. converter right?
Possibly the Turbo kit as well... How'd you get by with CARB regulation?
I'd like to fit this on a 99 NB.
tsuyoshi is offline
Old 01-19-2011, 05:35 PM
lazyguy's Avatar
Does the wideband have a lead for megasquirt?
Very interested thanks
lazyguy is offline
Old 01-19-2011, 06:18 PM
Marc D's Avatar
Ill get pics for some of the ite4ms tonight as well. Still at work typing this!
Originally Posted by tsuyoshi
Hi.
Hey,
The Midpipe does have a functional cat and has a bung on the end so you dont throw any codes. Will require a relocation kit for the O2 sensor.
Never passed CARB on the turbo kit. Smogged through other means. Been pulled over before, but I have a good "excuse" that couple of cops just let me go.
The wideband just has a wire that will be connected to the MS. The other ones are for serial connection, power, and ground connections. The serial connections i believe for AEM specific stuff. Dont quote me on that though cause I'm not sure.
Marc D is offline
Old 01-19-2011, 06:56 PM
Marc D's Avatar
Added an item - Spare MSII.
Marc D is offline
Old 01-19-2011, 07:25 PM
turotufas's Avatar
Pics of strut bar? I need to make a MC brace.
turotufas is offline
Old 01-19-2011, 07:41 PM
BigChris's Avatar
Picture of the headlights?
BigChris is offline
Old 01-19-2011, 07:45 PM
Faeflora's Avatar
Total Cats: 130
Someone buy this shortblock and buy my VVT head to put on it
Faeflora is offline
Old 01-19-2011, 08:04 PM
Marc D's Avatar
THe easily removed parts will be posted with pictures tonight, other stuff that require a bit more time for removal - i.e. turbo kit will come later.
So ill have that strut bar pic up tonight
Marc D is offline
Old 01-19-2011, 11:17 PM
newold_m's Avatar
If the deal with RotorNutFD3S does not work out on the Cannon brace I'll take it. I'm in San Jose so we can meet locally at your convenience.
Good price on the frog arms; too bad I ordered mine a few days ago
newold_m is offline
Old 01-19-2011, 11:49 PM
wittyworks's Avatar
Total Cats: 23
Pmed you on the frame rails. I'm local.
wittyworks is offline
Old 01-20-2011, 02:41 AM
tsuyoshi's Avatar
Default roadster sport exhaust
Ok, I'll take the muffler (if it looks to be in reasonable condition in picture) and the mid-pipe if the other deal falls through. Thanks
tsuyoshi is offline
Old 01-20-2011, 11:43 PM
Marc D's Avatar
Parts updated, pictures up soon.
Marc D is offline
Old 01-21-2011, 04:02 AM
Got91Miata's Avatar
Are you in norcal?
Got91Miata is offline
Old 01-21-2011, 04:11 AM
Marc D's Avatar
Yess sir. Northern california.
Just realized my last post was my 1,000th post. What a way go huh?
PICTURES ADDED, SOME ITEMS ADDED!
Marc D is offline
Old 01-21-2011, 08:27 PM
Marc D's Avatar
Bump, sold items list updated.
Marc D is offline
Old 01-21-2011, 08:37 PM
dima88's Avatar
PIC OF COPS Mounting plate?
dima88 is offline
Old 01-21-2011, 08:53 PM
Justslow's Avatar
great seller. thanks Marc again.
Justslow is offline
Quick Reply: FS: PART OUT! 1999 Black Turbo NB
