Cars for sale/trade List cars for sale here. Buy, trade or sell your Mazda Miata.
1989 Mazda Miata - $$4200 OBO
Old 05-17-2011, 05:51 PM
!!! NOT CONFIRMED !!!
willie_miata's Avatar
Default 1989 Mazda Miata - $$4200 OBO
Category: Import
Status: Clean Title
I have a 1989 Mazda Miata for sale, in USA - California.
Mileage: 100,000 miles
VIN: JM1NA3518L0113513
Engine Size: 1.8
Asking price is $$4200 OBO
For Sale:
-1989 Mazda Miata Turbo.
-VIN# JM1NA3518L0113513
-100K on chassis / ODO. Much MUCH less mi on all else
Specs.
Engine:
-1995 bottom end with a 1999 BP4W top end & intake manifold.
-Cut Cam cover (Black crinkle finish) 323 GTX PCV valve.
-2554 Garret Turbo.
-Flyin Miata Turbo manifold, Outlet manifold, Down-pipe; All hardware fresh & new.
-Custom heat shields(BEGI), I.C., Pipes (black crinkle finish), Matching Couplers(blue) & T Bolt Clamps.(all new)
-Mitsubishi 1G BOV.
-2.5" Exhaust , Magnaflow Muffler.
-550cc RX-7 injectors.
-Link ECU with key pad.
-Greddy EVBC
-Wide-Band o2 with PLX AFR gauge/Auto gauge boost gauge.
-Dual feed fuel rail with Y-block.
-Stack and plate oil cooler with remote mount oil filter housing, Mobil1 oil.
-All turbo lines & oil cooler lines are custom SS AN to AN.
-Mazdaspeed motor mounts. (New)
-Ultra spark plug wires.
-Stainless steel oil catch can.
-Koyo double core aluminum radiator with 14" slim fan.
Drivetrain:
-99 NB 5-speed trans.
-1.8 Fidanza flywheel.
-1.8 ACT Xtreme clutch.
-4.3 torsen, (99NB) with energy suspension bushings.
-Stainless Steel clutch line.
Chassis:
-Energy Suspension upper ball-joint and outer tie-rod end boots.
-Mazdaspeed suspension. (shock,spring,bump,boot,top hat)
-New Cam bolts.
-Welded rear sub-frame. (tubes)
-Flyin Miata frame rails. (no x section)
-Racing Beat hollow front sway bar with matching adjustable end-links.
Wheel/Tires/Brakes:
-949 Racing 6UL's, 15x8, +36 offset, nickel black finish. (Includes 949R lug nuts and valve stems)
-225/45/15 Nitto NT01 tires front, 225/50/15 Kumho V700 tires rear.(1/3 tread all around)
-Hawk HP+ F/R Brake pads w/ ATE blue brake fluid.
-Willwood Prop valve.
Interior: (Gutted minus dash)
-Corbeau bucket seats (clean&new) Black.
-G-Forces seat belt harnesses (clean&new)5pt, 3in wide, Blue.
-Razo shift ****.
-Grant Hub / GT 330mm steering wheel.
-HardDog Xtreme roll-bar with harness bar.
-Gutted doors with spec miata window brackets.
-Odyssey dry-cell racing battery.
Exterior:
-GT200 replica wing.
-Custom stationary lazy eye set-up, includes 4-point lighting.
-Bolt-in tow bar set-up.
-Front and rear tow hooks. (Red)
-Rally mud flaps. (rear uninstalled)
Asking $4,200 or best offer, eager to sell, pink slip in hand.
If interested call Erik Hendricks at 909 732 8451
Roadsters & Rally cars 5112 w mission blvd Ontario CA 91762
Attached Thumbnails 1989 Mazda Miata - $00 OBO-turbo-na.jpg   1989 Mazda Miata - $00 OBO-turbo-na-2.jpg
willie_miata is offline
Old 05-17-2011, 06:11 PM
viperormiata's Avatar
Total Cats: 283
Put some pics up of what matters. No one cars about the outside when you list a **** ton of motor work.
Your car looks like it is ready for some serious off roading.
viperormiata is offline
Old 05-17-2011, 06:26 PM
samnavy's Avatar
Total Cats: 322
^Yah, and how about some decent sized pictures... the ones you posted are micro.
samnavy is offline
Old 05-18-2011, 01:21 AM
jeff_man's Avatar
Total Cats: 103
Car looks like it's ready to go off roading, for the money you wasted on tires you should have picked up some real coilovers.
jeff_man is offline
zephyrusaurai
Meet and Greet
09-28-2015 10:59 PM
ScrapinMX5
Meet and Greet
8
09-28-2015 01:04 PM
ihiryu
09-28-2015 10:22 AM
drumman83
09-25-2015 07:03 PM
Quick Reply: 1989 Mazda Miata - $$4200 OBO
