Sponsored by: 949 Racing
View Poll Results: What thermostat are the track guys running?
Factory 195 degree themostat
14.29%
Optional 180 degree thermostat
57.14%
No thermostat
4
11.43%
Replace coolant with liquid helium
6
17.14%
Voters: 35. You may not vote on this poll
Track thermostat?
Old May 17, 2012 | 08:32 AM
Boost Joose's Avatar
Bannisheded
Total Cats: -222
Question Track thermostat?
Did some searching with no definative answer. I put mine in yesterday but wanted to see what you guys are running and why. Factory 195, optional 180 or no thermostat? What are you running why you are?
Old May 17, 2012 | 08:37 AM
Why in the f would you not run a thermostat?
I learned a long time ago that running colder than stock was stupid and pointless. But perhaps there's something different about track that I don't know about. Doubt it.
Takes longer to warm up, and if your heat exchangers are not up to task, you'll still overheat.
Reply
Old May 17, 2012 | 08:40 AM
Bannisheded
Total Cats: -222
Ha, I agree but just thought I would throw it out as an option as I know some cars that do not run thermostats (not miatas)
Old May 17, 2012 | 08:51 AM
pdexta's Avatar
Total Cats: 184
NA's actually had a 180 degree thermostat stock. I seem to remember reading that the switch to 195 was emissions related. I've always run a 180 in my miatas, since I feel like that was what it was designed to run.
Old May 17, 2012 | 09:23 AM
I think mine is a 180*f. I never, ever go over 200*f.
Old May 17, 2012 | 09:38 AM
Seefo's Avatar
Total Cats: 48
You should just not run a thermostat (ie, just remove it completely). Its "better" for flow
Reply
Old May 17, 2012 | 09:45 AM
sixshooter's Avatar
Moderator
Total Cats: 3,593
Flow is power.
I only use my thermostat when my engine is cold. After it warms up I turn it off.
Old May 17, 2012 | 10:15 AM
rharris19's Avatar
Gutted thermostat on my track cars with a reroute. I am told it is not the same as no thermostat by people who know more than me about this kind of thing, so I go with it.
Old May 17, 2012 | 10:19 AM
Bannisheded
Total Cats: -222
Wow harris, sounds like you're trying to pass visual inspection or something.....lol. Let's keep the BS to a mimimum guys, dont want the noobs to get confused.
Reply
Leave a poscat -4 Leave a negcat
Old May 17, 2012 | 10:28 AM
So you're getting confused?
Reply
Old May 17, 2012 | 10:33 AM
shuiend's Avatar
mkturbo.com
Total Cats: 1,700
I am pretty sure that you should run the Stant 180 degree thermostat on the miata, no matter what the car is doing.
Reply
Old May 17, 2012 | 11:13 AM
xjdesertfox's Avatar
Can you share why youd run the stant single valve unit over the OEM double valve unit?
Old May 17, 2012 | 11:15 AM
You are "the newbs".
Old May 17, 2012 | 11:18 AM
pdexta's Avatar
Total Cats: 184
Old May 17, 2012 | 11:24 AM
Seefo's Avatar
Total Cats: 48
hahahahaahahahaahahahahaaha....*breath*...hahahaha hahsahhaahhaahhaah!
Reply
Old May 17, 2012 | 11:36 AM
turotufas's Avatar
Run a thermostat. If you don't...
at speed, coolant might flow in and out of the radiator without having time to cool.
Do what you want (because racecar). And *uck you know who.
Last edited by turotufas; May 17, 2012 at 08:26 PM. Reason: i see somebitch went neg crazy
Reply
Old May 17, 2012 | 12:13 PM
Contact hyper...
...He will hook you up so good your engine will freeze
Old May 17, 2012 | 12:35 PM
viperormiata's Avatar
Total Cats: 283
lol @ this thread.
Reply
Old May 17, 2012 | 12:51 PM
bbundy's Avatar
Total Cats: 146
The stock thermostat in my 1990 was 195. The stock thermostat in a 2002 I changed recently was a 180.
I think the 180 reduces thermal spikes on track for me over the 195
Bob
Old May 17, 2012 | 12:58 PM
Total Cats: 2,106
Theseus has a gutted thermostat because it doesn't have any other coolant lines (no heater core, no oil warmer, etc).
Rover has an M-Tuned reroute with the factory oil warmer lines capped, but it still uses a heater core which allows flow before the thermostat opens.
